Getting DTC code #17356 and going into LIMP
System Too lean, making me go into Limp mode constantly on my 2001.5 A4 1.8T. Thought it was the N75, then a line that was bad, but still doing it. Could it be the MAF? Thanks
i would assume that if your maf was bad you would get the MAF DTC eventually
you might check your primary 02 sensor....
i just replaced both because they were both bad and i was running terribly lean, replaced the o2 sensor and it was fine. MAF just helped my idle and MAF readings. you might try and log blocks 002 and 115 and see what your airflow readings are...
kkii9
12-03-2005 08:46 AM
kkii9
12-02-2005 05:21 PM
BaysideRS4
07-25-2003 06:10 PM
quattroatl
06-06-2002 08:28 AM
