VAG-COM Discussion
Sponsored by:
Sponsored by:
Getting SKC
Old 03-31-2003, 02:36 PM
DroidAkty's Avatar
Default Getting SKC
According to the FAQ the follwing step is required to exchange the ECU
NEW
3. Take that 14-digit Immobilizer ID number (along with your VIN number) to your dealer and request your seven-digit SKC, along with the workshop code and importer number (all this information can be found in the upper-right corner of the Administration screen of the dealer's VAS 5051).
USED
4. Bring both 14-digit ID numbers to your dealer and request both your seven-digit SKC's Keep track of the SKC for ECU#1 and the SKC for the ECU#2, as well as the Date on which each SKC was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number.
Does the vehicle have to be plugged into the VAS5051 to get the SKC? Is the SKC fixed to the ECU or will a new one be generated when required?
Old 04-01-2003, 05:51 PM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Default Re: Getting SKC
Use VAG-COM to read the VIN (17 digits) and Immo-ID (14 digits) from your car. Take these numbers to the dealer. Your car does not have to be connected to the dealer's tool. However, the Admin Screen of the dealer's VAS-5051 tool is a handy place to get the WSC and Importer Number that you also need for VAG-COM to be able to decrypt the 7-Digit SKC.
-Uwe-
http://www.Ross-Tech.com
Old 04-02-2003, 03:29 AM
DroidAkty's Avatar
Default Re: Thanks Uwe...One more question
Is the SKC hashed with the WSC, Import Number and Date? In which case does the SKC change or is it permanenet with each ECU?
Old 04-02-2003, 04:19 AM
<center><img src="http://www.ross-tech.com/vag-com/tour/screens/I_pin-skc_2081.gif"></center><p>The 7-Digit code is an encryption of the 4 digit code, using the WSC, the Importer Number and the Date as "seeds". The 7-digit code will change every day and from every dealer. But once you have it, you can use it forever with VAG-COM, since VAG-COM allows you to enter the date it was generated.
Old 10-26-2003, 03:08 AM
New Member
Terence's Avatar
Hello
What if someone has a VAS 5051 at his home could he do anything with that...
Terry
usafpilotruss
11-12-2009 04:52 AM
AuditudeRS4
9
03-30-2007 06:02 AM
BSK auf Arbeit
09-30-2005 02:34 AM
Vortec4800
VAG-COM Discussion
08-07-2005 06:13 PM
DroidAkty
03-31-2003 02:37 PM
Quick Reply: Getting SKC
