have had 2 codes for 2 days now car in limp mode:(
2001.5 A4 1.8t AWM
manifold pressure boost sensor(G31)signal too low
P0237
manifold barometric sensor(G71)/(F96)implausible signal.P0106
As soon as I clear them they come right back instantly. Without even turning on the car, it has to be something electrical, just got a new MAF from the dealer could it have gone bad already?
P0237
Group115:charge pressur control(boost)
Engine speed-760/min
Engine Load-20.3%
spec.Boost-990.0 mbar
actual Boost-30.0 mbar
Group113:
idle speed-760/min
Engine load-20.3%
throttle drive-2.0%
Air pressure-995.0 mbar
Do those numbers seem normal? this is at idle.All of my connections are ok.
Engine Load-20.3%
Group113:
idle speed-760/min
Engine load-20.3%
throttle drive-2.0%
manifold pressure boost sensor(G31) is really too low. It should be around 1000 mbar.
So, you should check the connector and the wiring and the sensor(G31) itself. I think the best way is to swap the sensor(G31) with the other car.
