Help with engine fault code
I just pulled the following code from my engine. Can't find it in my Bentley manual and have never seen it before. Is it anything to be concerned about? Thanks
VAG-COM Version: Release 704.1
Data version: 20070422
Tuesday,24,April,2007,17:07:51:24623
Chassis Type: 01 - My C6A6
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 72 77
VIN: WAUDG74F95N077591 Mileage: 47860km/29738miles
Address 01: Engine Labels: 06E-910-559-BKH.LBL
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0070
Coding: 01050106190F0120
Shop #: WSC 01405
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 87.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
55 56 61 62 72 77
Shop #: WSC 01405
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 87.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
I don't know how old this fault code is. For a frame of reference, you could try clearing the code and run the car for a day or two to see if it comes back. My B5 A4 has this code, and it may be indicative that your alternator was replaced in the past. Have you had any battery or alternator failures since codes were last cleared?
I last checked codes about 2 weeks ago and this one was not there. No battery or alternator work since then. I cleared the code and checked battery terminals for tightness and hope it doesn't return. I might just need a new battery (after only 2 years?).
How about 61-Battery Regul? Measuring blocks in there can tell you a lot about the batter and charging system.
FWIW, most 2005 A6's came with software in the Battery Regulation module that had some issues. There was an update for this that resolved most of these issues. Post the ID data from your Battery Regulator so we can see what software it has in it. Best way to do that is: Select -> Drivetrain tab -> 61-Battery Regul. -> Fault Codes -> Copy Codes. Then paste the results here (or to an intermediate file if the PC you're using to scan with doesn't have internet access. It doesn't matter if there are no fault codes in that module.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Sorry for the belated response, the wife had the car yesterday. Here's the battery reg data:
Friday,27,April,2007,08:08:29:24623
Address 61: Battery Regul.
Control Module Part Number: 4F0 910 181 E
Component and/or Version: ENERGIEMANAGER H11 0400
Software Coding: 0000000
Work Shop Code: WSC 01405
Additional Info: 4F0915105C von VA0 2411120479
Additional Info: Geraet 58827
No fault code found.
The battery meter in MMI has always show full, and I have already explored the measuring blocks in battery regulation and all the values seem OK. I'm not sure if the module software has been updated, WSC shown is my dealer's . Is it odd that the original falt code would show up somewhere else, but the battery reg module shows everything OK? Thanks for the info.
I don't remember what the flaky version number was, but it was often down to 5 or 10% after the car sat for a few days -- which was just plain wrong -- and of course it was asking numerous other systems to shed load.
If it was me, I'd clear that code from the engine and not worry about it unless it keeps coming back.
-Uwe-
-Uwe-
