help with error address 46
hello everyone.
i was retrofitting my reverse camera on my a4 all road 2009 with mmi3g .after i striped the can bus diagnostics plug to insert the can bus cabled from the controller i had the terminator unplugged and tried to start the engine. after i realised my mistake and plug it back in ,i erased all faults however i have the following error :
Address 46: Central Conv. Labels: 8K0-907-064-46.clb
Control Module Part Number: 8K0 907 064 BQ HW: 8K0 907 064 BQ
Component and/or Version: BCM2 1.1 H90 0247
Software Coding: 01000E20203904150330020000000000
Work Shop Code: WSC 00003 207 91381
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 26599 km
Time Indication: 0
Date: 2010.02.19
Time: 19:07:45
i rechk all cables and plugs ,all is good except this problem.any ideas?
also has any one calibrated the reverse camera only with vag com ?
thanks
ARI
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 26599 km
Time Indication: 0
Date: 2010.02.19
Time: 19:07:45
thanks
ARI
