Help with my fault codes... Please :)
<b>A local VWvotex friend found all these fault codes. What do they mean, and what can I do to fix them? I don't like driving a faulty car ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
The main one I'm worried about is the AirBag as the light is on...</b>
Address 0F: Digital Radio Labels: 8E0-035-593-XM.LBL
Part No: 8E0 035 593 A
Component: SDAR XM 0010
1 Fault Found:
00003 - Control Module
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63251
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 12076
Shop #: WSC 22129
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0204
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0204
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 1204
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 1204
6 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
1 Fault Found:
Coding: 0010607
Shop #: WSC 63251
1 Fault Found:
Coding: 12076
Shop #: WSC 22129
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
the one in the seat. The connectors to those, usually located under the seat are often problematical.
As far as faults in the central convenience system, I would just clear those and not worry about 'em.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
vtraudt
04-10-2011 06:04 AM
OldSchool AG
12-15-2004 08:53 AM
