Help and thoughts with misfire problems..
I have swapped the ignition coils between cylinder banks and the misfires have not moved with the ignition coils. I have changed my sparkplugs as well with no changes. I have tried a new ICM as well.
I am still getting misfires (always now) on cylinder bank 3 ONLY, before it was intermitten and was driveable... not anymore :-(
Well here is the log info.. i wouldn't worry about the other cylinders since after I cleared them they only logged in cylinder 3 (I had to drive home like this, wasn't fun).
I also measured them live below the initial log. HELP!
I'm thinking it is the FUEL INJECTOR.. thoughts?
Monday,01,March,2010,23:06:20:21909
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 216780km/134700miles
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Part No: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
Shop #: WSC 06335
7 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
P0300 - 35-00 - -
P0303 - 35-00 - -
Readiness: 0000 0000
live:
467 Misfire Sum Counter
0 Misfires Harmful to Emiss Cyl 1
0 Misfires Harmful to Emiss Cyl 2
470 Misfires Harmful to Emiss Cyl 3
0 Misfires Harmful to Emiss Cyl 4
0.0° Cylinder 1 Timing Retard
0.0° Cylinder 2 Timing Retard
0.0° Cylinder 3 Timing Retard
0.0° Cylinder 4 Timing Retard
01110000 Crankshaft Pos Status
-0.038°KW Section Correction Factor
Coding: 06201
Shop #: WSC 06335
7 Faults Found:
P0300 - 35-00 - -
P0303 - 35-00 - -
P0300 - 35-00 - -
P0303 - 35-00 - -
live:
Got my VAG COM Cable today from Ross Tech... so far so good.. used my buddies prior, but he had an older version for his VW and I wanted to change some things on my A5 as well (CAN). the misfires just happened to expedite my purchase!
Although the ICM was replaced with a new OEM one, it failed again with about 1000 miles on them. This caused the problem again along with some intermittent car starting problems when warm.
Cold starts were not a problem.
There are two ingition modules mounted on the air filter assembly. Swap them and see if your misfire moves to a different cyl. If thats the case, make sure you use fresh heat sink silicon lube when you replace the module.
Sparkster, I am curious if you found what was going on with your car? I believe that I am having the exact same issue as you and wondering if you found the cause.
Either way that you for your help,
Carlos
Carlos
myers1.8TQ
09-22-2008 02:52 AM
EuropaA4Quattro
04-19-2007 02:42 PM
