Help with usb retrofit (audi Q3 MIB2+)
#21
It's not LVDS. LVDS is a signaling protocol used for high speed data transfer such as the video signals; it's not a physical interface. The cable/plugs/pins are called HSD. And they are in this case imply transferring USB 2.0 data.
Yeah, I'd get a cable like that, just run it from the USB hub leaf green jack to the J794 nut brown jack.
You should run a wire from the J1146 pin 6 to the J519 73 black pin 14 as I listed. Where is the J519 in a Q3, no idea.
#22
I've seen where is the J519, I will do as you said.
A Big thanks for all your time and help, i'll update you when i'm all done if that's okay.
A6DRiFTKiNG1990
26
11-11-2006 05:33 AM
Quatime
09-27-2002 01:56 PM
Pat-SoCal
29
03-29-2002 09:55 AM
