Hi, help with Adaptive headlight fault code please.
Hi, I followed the instruction on http://www.ross-tech.com/vag-com/cars/xenonalignment.html
to adjust my xenon. But after I press Go at 001, it just keep displaying Wait in the first box for a long time, then it says no response from the auto-leveling. I get this fault code:
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 4F0 910 357 F
Component and/or Version: AFS 1 H01 0020
Software Coding: 0000020
Work Shop Code: WSC 06314
Additional Info: 8E0941329A AFS-Modul links H03 0020
8E0941329A AFS-Modul rechtsH03 0020
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 138
Mileage: 4472 km
Time Indication: 0
Date: 2007.02.17
Time: 02:02:29
How do I fix this problem so the the xenon range relearns?
Thanks.
Jack ****
Burnaby, B.C
Registered@Ross-Tech VAG-COM
2007 Audi A3 3.2Q
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 138
Mileage: 4472 km
Time Indication: 0
Date: 2007.02.17
Time: 02:02:29
Thanks.
Jack ****
Burnaby, B.C
2007 Audi A3 3.2Q
...first it disables the adjustment by the control module for the time you aim the headlights manually and afterwards it learns the new values.
Since your basic setting does not seem to work well, it raises the question if you made any mods?
<a href="http://wiki.ross-tech.com/index.php/01539" target="_blank">Ross-Tech WIKI: 01539 - Headlights Not Adjusted: No or Incorrect Basic Setting / Adaptation</a>
One reason for your problem could be a lowered suspension and that often brings the level sensors on the axles out of range.<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A3_%288P%29_Headlight_Aim_Control_%28Adaptive _Light%29">Ross-Tech WIKI: Audi A3 (8P) Headlight Aim Control (Adaptive Light)</a></li></ul>
Hi, I followed the
Ross-Tech WIKI: Audi A3 (8P) Headlight Aim Control (Adaptive Light) instructions, and the new position is learned and fault code cleared!!
Thanks.
Jack ****
Thanks.
Jack ****
Bob 2KS4
10-18-2022 11:16 PM
JoePGT5S
12-10-2017 02:27 PM
