Hi, needs help with another fault code!
Hi, just did a full scan, and came up with 1 fault code.
Chassis Type: 8P - Audi A3
Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: WAUKD78P87A091351
Address 01: Engine
Part No SW: 022 906 032 JF HW: 022 906 032 GP
Component: MOTRONIC ME7.1.1G 9407
Coding: 0000178
Shop #: WSC 06314
1 Fault Found:
001110 - EVAP System: Very Small Leak Detected
P0456 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 3847 km
Time Indication: 0
Freeze Frame:
RPM: 1699 /min
Load: 33.7 %
Speed: 66.0 km/h
Temperature: 41.0°C
Temperature: 20.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Could you tel me what's the leak about? Something serious??
Thanks.
Jack ****
Address 01: Engine
Coding: 0000178
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 3847 km
Time Indication: 0
Freeze Frame:
RPM: 1699 /min
Load: 33.7 %
Speed: 66.0 km/h
Temperature: 41.0°C
Temperature: 20.0°C
Voltage: 14.224 V
Thanks.
Jack ****
Not particularly serious
Possibly the gas cap not sealing well. Should have no effect on engine performance, but makes you car out-of-spec emissions wise.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
If the car is under warranty, I would let the dealer do proper diagnostics
with a smoke machine.
-Uwe-
-Uwe-
