hlp pls: recently got a CEL so decided to get a hex+can cable
car 2001 A4 1.8T (AWM) Tip
The CEL comes on rarly only when the car is sill cool, and you give enough gas to try to merge.
The person that had the car before me had K&N air filter, which I replaced with OEM Audi filter.
The car's requested/actual boost get close to 2200 mbar from block 115 so I am guessing that it's chipped... ?
From Block 30 I get x11 and x10 where x varies from 0 to 1 at idle and full temp, so my guess would be that oxugen sensors might be faulty.
But on the other hand the MAF readings are a bit low too (I think)
So I am having a hard time deciding if the MAF is DEAD or the O2 sensors..
Any help will be greatly appreciated !!!
Control Module Part Number: 4B0 906 018 M
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 16251
Work Shop Code: WSC 30415
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Now I did a bunch of loging today in 2'nd gear
group: 001, 002, 031, 032, 115, 118
5 Faults Found:
P1128 - 35-00 - -
<ul><li><a href="http://www.ross-tech.com/vag-com/cars/fuel-trim.html">http://www.ross-tech.com/vag-com/cars/fuel-trim.html</a</li></ul>
http://www.Ross-Tech.com
<center><img src="http://pictureposter.audiworld.com/87073/group002.jpg"></center><p>I read that already...
The engine load is quite low, don't you think ?
RPM 5640
Engine load 118.8
Inj On time 19.04
Air Mass In 128.58
RPM 5640
Engine load 118.8
Inj On time 19.04
Air Mass In 128.58
I am going to make an attempt at cleaning it, soking it in 99% alcohol.
I already tried spraying it with circuit cleaner but no change.
DWP
01-24-2009 08:01 PM
camikazi2k
02-18-2006 07:51 PM
