How do I adjust the idle speed on an D3 A8?
There are no engine fault codes being thrown. Also another symptom is that during a cold start, fast idle feels like it's missing(?) a wee bit - not dead smooth. Idle seems to jump between 700-600 with it being nearer to 600 in the past few weeks causing vibration. Just got my vag-com yesterday and I was really hoping to find something.
Thanks!
Thanks!
Everything else is dead smooth until engine speed drops to about 600 then there is a slight "lumpiness". So slight, only I the driver notices it. Plus the idle is jumping around between 750-600. If I just touch the pedal and raise the rpms above 650 it's glass smooth.
other ECUs have idle speed adjustment via adaptation channel 001. (ECU PN and firmware version dependant,) The default setting is 128, +001 increases idle speed by 10 rev/min up to 135. -001 decreases idle speed by 10 rev/min steps, minimum 125(?).
