How do I reset the service reminder on a 2000 A4? I have searched and come up with nothing...
if you want to change the interval you need to use vag-com but for a simple reset see the link<ul><li><a href="https://www.audiworld.com/tech/elec26.shtml">service interval reset</a></li></ul>
1. Insert your key into the ignition.
2. Push in the odometer reset button, hold it in, and turn the key to the first click.
3. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
4. To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
here they are again said a little differently
while holding the odo button turn key to on. then *push* the clock button.
I swear I'm not making this up. Check your owner's manual, look in the index in the back of the book for service reminder...
