I GOT FAULT CODES, HOW SHOULD I FIX
HOW SHOULD I FIX THEM?
(2000 A6 2.7T 6spd)
MISFIRE : change spark plug only????
ABS : I don't know
AIRBIG : I DON"T KNOW
EGT : I DONT KNOW, maybe replace sensor??
CENT. LO : I DONT KNOW
HELP ME OUT!! PLZ~~~~
AND ADVICE~~
THIS IS MY FIRST TIME USING VAG-COM
I HAVE TO LEARN
THANKS
VAG-COM Version: Release 512.1-UD
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 4B0 907 551 K
Component: 2.7l V6/5VT G 0003
Coding: 06612
Shop #: WSC 02387
5 Faults Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 15: Airbags
Part No: 4B0 959 655 F
Component: Airbag Front+Kopf 0002
Coding: 00406
Shop #: WSC 02335
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
Address 35: Centr. Locks
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D32
Coding: 15949
Shop #: WSC 05211
4 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
(2000 A6 2.7T 6spd)
ABS : I don't know
AND ADVICE~~
I HAVE TO LEARN
THANKS
Address 01: Engine
Coding: 06612
Shop #: WSC 02387
5 Faults Found:
P1606 - 35-00 - -
P1457 - 35-00 - -
Address 15: Airbags
Coding: 00406
Shop #: WSC 02335
1 Fault Found:
Coding: 15949
Shop #: WSC 05211
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Plugs....change if over 40k miles.
EGT sensor 2.....replace left EGT sensor (it's a bitch)
is your airbag light actually on?
don't worry about the contral lock codes
THANKS for help
BUT I REPLACED SPARK PLUG about 6 months ago
CAN SPARK PLUG GONE IN SHORT PERIOD like 6 months? ALSO, MY AIRBAG LIGHT STILL ON
HOW CAN I DO WITH AIRBAG??
don't be concerned about the misfires, unless they recur after clearing the code. You still need to change the EGT sensor though. Misfires....maybe a touch of bad fuel, water in the fuel, or other minor issues.
Airbag, if there is a problem with the ignitor, then the whole drivers airbag needs to be replaced. In the meantime, removing the airbag, and using a contact enhancer, such as Stabilant, on the airbag connections could help.
franklinstower
10
03-06-2007 02:21 PM
2point7LI
12-29-2006 05:29 AM
