I need a little help figuring out what some codes mean.
In the middle installing gauge rings, I had to drive my car with the cluster out. As expected this left me with a CEL.
After finding someone to VAG my car, we pulled the attached codes. I assume the "Vehicle Speed Sensor: Implausible Signal" and "Electrical Malfunction" are from driving the car without the cluster in but the rest leave me guessing.
If someone has a minute and knows the meaning behind these codes, I would appreciate knowing.
Thanks, Adam
ps. I have a new apprecation for the VAG-COM unit, it's now next on the mod list...what a fun toy!
Control Module Part Number: 4B0 907 551 K
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06612
Work Shop Code: WSC 00000
7 Faults Found:
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-10 - - - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-10 - - - Intermittent
18028 - Engine Coolant Temp Signal: Open or Short to Plus
P1620 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
des.
Thanks, Adam
7 Faults Found:
des.
clear them all and don't worry about them unless they come back.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
NogaroPR
10
05-29-2006 08:38 PM
Milpitas2.7T
19
11-30-2005 11:08 PM
Marc911
11-18-2005 12:10 PM
