I still can't clear the engine codes!!!(see 16th post down) This is what I have...
I turned off all anti-vir. firewalls. I do have REVO software loaded but I have switched back and fourth between chipped and not with no diff. on the clearing of codes. These are the codes:
VAG-COM Version: Release 504.1-UD
Chassis Type: 8E - Audi A4 B6
Scan: 01 02 03 08 09 15 16 17 26 36 37 45 46 55 56 63 76 77
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
18339 - Coolant Fan Control Module (J293): Malfunction
P1931 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Address 01: Engine
Coding: 0016701
Shop #: WSC 63351
4 Faults Found:
I wish I could tell you why.
2002 A4 1.8T's are not exactly rare. We have plenty of customers with that exact ECU and never had a report of "Can't clear fault codes".
As mentioned previously, I have that exact ECU here on the bench and it clears fault codes just fine.
My conclusion is that there's either:
* A previously unknown interaction between VAG-COM, your interface, and your PC which gives us some sort of timing problem that your ECU doesn't like, or
* An internal problem in your particular ECU causing it to fail to clear fault codes.
FWIW, switching your Revo software to "stock mode" does not make your ECU "stock". It switches to maps which emulate stock performace, but the ECU is still running Revo's code (otherwise you wouldn't be able to switch back to "chipped mode"). Note: I am not saying that Revo's software is the cause of the problem, although if you had a truely stock ECU that was matched to your car, I'd certainly suggest trying it. I might also suggest contacting Revo to see if they have any known issues or updates to their code for your ECU.
I'd also like to have a look at the data being exchanged between VAG-COM and the car when you (attempt to) clear fault codes. In order to do that, you should e-mail me privately.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
JNormS4
06-04-2013 05:19 PM
franklinstower
10
03-06-2007 02:21 PM
