I think I bought the D3 the Army tested their EMP weapons on...
Hi guys, popping in from the D3 forum. I have a 2005 D3 4.2 shorty. I've bought VagCom and done a couple of jobs on the car with it, like lowering etc, but feel there is so much more to learn, and many jobs on the car to do.
Most pressing: Low beam range.
Ok, so I've changed both low beam bulbs as one was dull (still is, more later) but on reassembly, having had to remove drivers side range motor in order to re-establish disconnected 'ball and socket' joint at the xenon carrier, the drivers low beam is now aimed WAY low. Lamp assembly is in place, and not pointing downwards.
I thought I found a VagCom process to move the lights (channel 55), but that had no effect, and the VagCom 'Light left' and 'Light right' channels both give a 'controller not responding' message. (do these even relate to the headlights?)
I also have a headlight range error message on the dash now that will not reset.
Help please guys!
K9
Help please guys!
![Confused](https://www.audiworld.com/forums/images/smilies/confused.gif)
K9
Maybe post an Auto-Scan so people can see the state of the car?
-Uwe-
http://www.youtube.com/watch?v=RCBt6d42-Fc
-Uwe-
http://www.Ross-Tech.com
Thanks Uwe, here's teh latest scan. I had some success today, and mechanically moved the drivers side low beam up to match the passenger side, and I managed to get some help from the D3 forum and cleared the headlamp dashboard warning that had popped up. I still have 'odd' low beams though, in as much as the don't both look the same. One is brighter.
Here's the latest complete scan, ignore the address 55 DTC's... incidentally, the 'Auto-Scan' almost always hangs up on the Digital radio address....
Thanks so much,
K9
Tuesday,13,March,2012,18:54:36:40451
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E35N015651 Mileage: 230070km/142958miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E1759901
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2855C9C39BE83A3
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0054165
Coding: 0000002
VCID: 32612BABAD34403
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2241DBEBFDD4D03
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E1759901
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B539036B08CA3
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 230000 km
Time Indication: 0
Date: 2012.03.11
Time: 14:04:44
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234FDEEFE2CED9B
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346BD057520412
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 244DDDF3E7C0DE3
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
5 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 12
Mileage: 229951 km
Time Indication: 0
Date: 2012.03.05
Time: 13:47:25
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 230009 km
Time Indication: 0
Date: 2012.03.09
Time: 15:58:57
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 229951 km
Time Indication: 0
Date: 2012.03.05
Time: 14:10:05
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 1000000
Bin. Bits: 000
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 229951 km
Time Indication: 0
Date: 2012.03.05
Time: 14:31:50
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 1
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000062155
Coding: 1052993
VCID: 1C3DE513DFB0E63
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No HW: 4E0 907 279 L
Component: RLS NO RESPONSE
Coding: 0123123
VCID: 55ABB037FC1A77B
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
2 Faults Found:
02510 - Steering Column Adjustment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 21
Reset counter: 11
Mileage: 0 km
Time Indication: 0
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Serial number: AUZ4Z7E3008695
VCID: 2649C7FB91FC2C3
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 21
Mileage: 230076 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 075
Raw, Form. N/A: 000 000 000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: E5CB00F72C7A67B
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Revision: D05 Serial number: AUDID3E1004444
Coding: 0016233
Shop #: WSC 08126 444 85715
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 1900305217004F
Coding: FCFE7BDD1B7904
VCID: 2757CAFF96F635B
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 187
Reset counter: 21
Mileage: 229705 km
Time Indication: 0
Date: 2004.03.31
Time: 00:06:52
02076 - Media Player Position 1 (R118)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 136
Reset counter: 21
Mileage: 229705 km
Time Indication: 0
Date: 2004.03.31
Time: 00:07:47
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 60
Mileage: 229774 km
Time Indication: 0
Date: 2012.02.17
Time: 20:49:06
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 230000 km
Time Indication: 0
Date: 2012.03.11
Time: 14:04:44
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0011310
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 C
Component: MNS US H44 0960
Revision: 00000000 Serial number: 378B-057517397
VCID: 2E593FDBB90C643
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000433500111
Coding: 0003477
VCID: 1D3BE817C4AAEFB
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028204
VCID: 2045D1E3F3D8C23
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503010007
Coding: 0065086
Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 21
Mileage: 155710 km
Time Indication: 0
Date: 2008.07.29
Time: 18:42:25
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000011673
Coding: 0000016
VCID: 254BC0F7ECFA27B
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000056576
Coding: 0010111
VCID: 1E39EF1BC9ACF43
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0028204
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 08126 444 83438
VCID: 1F47D21FCEA6FDB
2 Faults Found:
02442 - Function Lamp in Control Head
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 6
Fault Frequency: 31
Reset counter: 61
Mileage: 229944 km
Time Indication: 0
Date: 2012.03.05
Time: 13:54:23
Freeze Frame:
Voltage: 13.04 V
Count: 65
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 247
Time Indication: 0
Freeze Frame:
Voltage: 9.52 V
Count: 61
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C11BEB3D54103
3 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:42:44
02235 - Stationary Cornering Lamp (Left) (M51)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:42:45
02236 - Stationary Right Cornering Lamp (Right) (M52)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:42:45
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396CP057505073
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000001930
Shop #: WSC 08126 444 00568
Subsystem 1 - Part No: 4E0 910 181 C
Component: von VA0 0000000204
Coding: 344530393130313831432056413030303030303030323034
Shop #: WSC 12345 128 00289
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 55
Mileage: 230009 km
Time Indication: 0
Date: 2012.03.07
Time: 00:36:06
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028204
Address 65: Tire Pressure
Cannot be reached
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000502180131
Shop #: WSC 12336 024 394758
VCID: 346D2DB357204E3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028204
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720504000144
Coding: 0001208
VCID: 2143D4E7F8D2CBB
2 Faults Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 57
Mileage: 229774 km
Time Indication: 0
Date: 2012.02.19
Time: 16:26:57
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 229739 km
Time Indication: 0
Date: 2004.04.06
Time: 00:28:25
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007516957
Coding: 0010900
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0F: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 61: DTCs cleared
Address 62: DTCs cleared
Address 67: DTCs cleared
Address 72: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
Chassis Type: 4E0
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Readiness: 0110 1101
Coding: 0000002
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
Coding: 3940448
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 230076 km
Time Indication: 0
Date: 2012.03.13
Time: 18:54:42
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 1
Coding: 1052993
Coding: 0123123
Coding: 00000036
Shop #: WSC 02313
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 11
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Cannot be reached
Component: SDAR
Revision: 0000000 Serial number: AUZ4Z7E30
Part No: 4E0 910 593 B
Component: SDAR
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 0530707
Coding: 0012241
Coding: 0016233
Coding: 0410624
Component: ELV XXXX
Coding: 0011310
Coding: 4071530
Coding: 0003477
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 21
Mileage: 155710 km
Time Indication: 0
Date: 2008.07.29
Time: 18:42:25
Coding: 0000016
Coding: 0010111
Coding: 0028204
Revision: A32C0220
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 247
Time Indication: 0
Freeze Frame:
Voltage: 9.52 V
Count: 61
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:57:01
Coding: 0000002
Coding: 0028204
Cannot be reached
No Faults Found
Coding: 0028204
Coding: 0001208
Coding: 0010900
Part No: 4F0 910 336 A
No Faults Found
Thanks so much,
K9
Chassis Type: 4E0
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Coding: 0000002
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 230000 km
Time Indication: 0
Date: 2012.03.11
Time: 14:04:44
Coding: 3940448
Coding: 0000000
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 12
Mileage: 229951 km
Time Indication: 0
Date: 2012.03.05
Time: 13:47:25
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 230009 km
Time Indication: 0
Date: 2012.03.09
Time: 15:58:57
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 229951 km
Time Indication: 0
Date: 2012.03.05
Time: 14:10:05
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 1000000
Bin. Bits: 000
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 229951 km
Time Indication: 0
Date: 2012.03.05
Time: 14:31:50
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 1
Coding: 1052993
Coding: 0123123
Coding: 00000036
Shop #: WSC 02313
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 11
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Cannot be reached
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 21
Mileage: 230076 km
Time Indication: 0
Freeze Frame:
Coding: 0530707
2 Faults Found:
Coding: 0012241
Coding: 0016233
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 21
Mileage: 229705 km
Time Indication: 0
Date: 2004.03.31
Time: 00:06:52
Freeze Frame:
Fault Priority: 3
Reset counter: 21
Mileage: 229705 km
Time Indication: 0
Date: 2004.03.31
Time: 00:07:47
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 60
Mileage: 229774 km
Time Indication: 0
Date: 2012.02.17
Time: 20:49:06
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 230000 km
Time Indication: 0
Date: 2012.03.11
Time: 14:04:44
Coding: 0011310
Coding: 4071530
Coding: 0003477
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 21
Mileage: 155710 km
Time Indication: 0
Date: 2008.07.29
Time: 18:42:25
Coding: 0000016
Coding: 0010111
Coding: 0028204
Revision: A32C0220
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 61
Mileage: 229944 km
Time Indication: 0
Date: 2012.03.05
Time: 13:54:23
Freeze Frame:
Voltage: 13.04 V
Count: 65
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 247
Time Indication: 0
Freeze Frame:
Voltage: 9.52 V
Count: 61
Coding: 0000001
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:42:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:42:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:42:45
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 55
Mileage: 230009 km
Time Indication: 0
Date: 2012.03.07
Time: 00:36:06
Coding: 0028204
Cannot be reached
Coding: 0028204
Coding: 0001208
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 57
Mileage: 229774 km
Time Indication: 0
Date: 2012.02.19
Time: 16:26:57
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 229739 km
Time Indication: 0
Date: 2004.04.06
Time: 00:28:25
Coding: 0010900
Chassis Type: 4E0
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Coding: 0000002
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
Coding: 3940448
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 230076 km
Time Indication: 0
Date: 2012.03.13
Time: 18:54:42
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 1
Coding: 1052993
Coding: 0123123
Coding: 00000036
Shop #: WSC 02313
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 11
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Cannot be reached
Component: SDAR
Component: SDAR
No Faults Found
Coding: 0530707
Coding: 0012241
Coding: 0016233
Coding: 0410624
Component: ELV XXXX
Coding: 0011310
Coding: 4071530
Coding: 0003477
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 21
Mileage: 155710 km
Time Indication: 0
Date: 2008.07.29
Time: 18:42:25
Coding: 0000016
Coding: 0010111
Coding: 0028204
Revision: A32C0220
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 247
Time Indication: 0
Freeze Frame:
Voltage: 9.52 V
Count: 61
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 230072 km
Time Indication: 0
Date: 2012.03.13
Time: 18:57:01
Coding: 0000002
Coding: 0028204
Cannot be reached
No Faults Found
Coding: 0028204
Coding: 0001208
Coding: 0010900
No Faults Found
-Uwe-
-Uwe-
Your headlights aren't adjusted, both auto levelling and cornering functions will be disabled. To fix it you will need to park on level ground, log into computer 55, and then follow these instructions from the ross tech website.
http://wiki.ross-tech.com/wiki/index...Adaptive_Light)
You will have to do the security log in first.
....and then follow these instructions from the ross tech website.
There is currently no text in this page. You can search for this page title in other pages, search the related logs, or edit this page.
Thanks!
-Tom
Forum dropped the close parenthesis on the link. If you manually put it back, the link works fine.
-Uwe-
-Uwe-
I think I can get to grips with that, but the high beams are still wayyyy up high in the trees. Can they be adjusted separate from the low beams?
thanks so much,
K9
thanks so much,
K9
In my case, the high beams looked like they were quite high as well, compared to my lesser cars'; but then I realized they just make a cone of light and so the trees do indeed catch some, you get used to it. The cut off from the shutter keeps one from being blinded by reflections from road signs (as well as protecting other drivers),
I understand that some markets have a halogen high beam, the innermost bulb in the housing. Here in the USA that bulb is only for flash-to-pass (and perhaps DRL, although I haven't confirmed that yet). If UK uses the inner halogen bulb for high beams, then my info above does not apply.
That inner bulb drove me nuts as I could not get it to light and just KNEW it should! Then I flashed to let someone over and saw the pattern of the reflector projected onto their car and the (2cp) bulb in my head went on as well!
Tom
Tom
HKsupastar
11-08-2003 08:56 PM
Gjaime
12-16-2001 09:13 AM
