I think my VAG-COM cable is broken (I've only owned it for two months)...
I bought a new USB VAG-COM cable about a month or two ago. It worked fine up until two days ago. I've tried it on three different cars and two different laptops since then, always with the same results. After a few seconds of logging data, it pops up with an error message saying that it is "unable to sync baud rate". I've tried logging out of the module, and even out of the program, but it just keeps bringing up the error message saying the cable is not connected until I disconnect it from the computer and reconnect it. Then I go through the same thing again, with it only working for a few seconds before I have to exit out and disconnect it again. Like I said, I've tried using it on different cars and different laptops, I keep having the same problem. Is my cable shot, and if so, I am assuming there must be some sort of warranty on these things, right?!?
I need my VAG-COM this weekend. If it helps, I'm only about 45 minutes from your company's listed address (I live in Allentown, PA).
