Interace: Not Found! I checked FAQ's
Help, I connected my KKL-USB cable to my laptop which only has one USB port and did the test and failed!! I tried on USB port and says Ross-Tech USB interface Not Found! Although when i try com port 4 it takes a while and then pops up saying Port Status: OK and Interface: Not Found!--- What in the world am i doing wrong?!?! Any help much appreciated.
The vag-com version is 409, but i did try the 512. As for the interface vendor I bought the wire off of eBay... Maybe that wasn't a good idea? On the wire at the very end on the other side of the LED's there's a little sticker that says "USB KKL" thats it.
I downloaded the vag-com software and installed it, then downloaded the device driver for the wire and i thought that would be it, but yet I still have problems.
I also went into the device manager to check to the see properties of it, and its listed under COM & LPT and also USB...? is that normal? The wire's com port is com 4, when yet its a USB.. I'm so LOST!! help?
The FAQ is your friend...<ul><li><a href="http://ross-tech.com/vag-com/faq_3.html#3.3">http://ross-tech.com/vag-com/faq_3.html#3.3</a</li></ul>
Ever read the release notes?<ul><li><a href="http://ross-tech.com/vag-com/download/current.html">http://ross-tech.com/vag-com/download/current.html</a</li></ul>
2) Questions about design and construction of home-made interfaces are Off-Topic, as are connection problems if you're using a home-made interface or a 3rd party interface.<ul><li><a href="https://forums.audiworld.com/vag/msgs/6768.phtml">https://forums.audiworld.com/vag/msgs/6768.phtml</a</li></ul>
Andy
Andy
Mr. Z
VAG-COM Discussion
11-14-2008 05:07 PM
englsh
08-07-2007 08:27 AM
wiinky
VAG-COM Discussion
01-23-2006 08:58 PM
