just got my new vag cable. I'm trying to recode my trans module 05 S4 to hold gears any help
The only coding I can get to work is the stock coding xxxxx2 xxxxx1 is obviously 6 speed because after I change it you can see a back lit PRNDS..Is this just a trial and error thing. The bata version I have has coding suggestions but it said nothing for the trans.
I would like to turn off the auto shift feature similar to the old 000032 coding on the A6 4.2 that will let you hold the gear all the way to red line
Start by posting data from your tranny so we know what you've got.
http://www.Ross-Tech.com
VCDS Version: Beta 803.4
Address 02: Auto Trans
Control Module Part Number: 8E0 910 156 R
Component and/or Version: AG6 09L 4.2L5V RdW 0060
Software Coding: 0000001
Work Shop Code: WSC 63351
The software code of 1 didn't work. Any help would be awesome. If this helps I have the paddles on the steering wheel. I am open to any and all ideas you have... . I am open to any ideas you may have. If there is some info that you might not be able to share online or need to send info please feel free. Because if you don't know Im sure no one else will
Thanks
justincredible099@yahoo.com
Thanks
have the car shift at 7k. after taking it to the dealer this no longer happened. I am open to any idea to get this thing to hold the gears longer
