When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
KR: I need help with 2014 Audi A7 C7 Fault Codes and warning lights
Hello all members !
it has been a while that I'm posting issues here!
so here is the problem with my car A7 C7 2014
1. Passenger Door window power button / lock & unlock button / memory seat buttons / ambient light / door logo light is not working !!! ( it works when it is controlled by driver side buttons...!!)
2. this is a bigger problem than #1 I think...?
so i have turned off the car to check the fuses (no disconnect with battery) so i have took one fuse out and check the condition and i have put it back in the right position.
I have gone threw those with all 3 fuse boxes (driver side / Passenger side / Trunk )
after I replaced the fuses and when I did Auto-Scan with VCDS suddenly these codes were showed up
and I cleared all DTC but it keep still shows up.
on the cluster the warning light showed up ( Air suspension / TPMS / Traction / ABS ETC )
◆ this is not my car's photo but it appears same warning lights. ◆
there is no problem with using those functions.
Could anybody help me to fix this problem please..!!???
1 Fault Found:
0876 - Terminal 15
U1405 00 [137] - Implausible signal
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
1 Fault Found:
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
1 Fault Found:
1049600 - Databus
U1121 00 [137] - Missing Message
1 Fault Found:
U1113 00 [009] - -
1 Fault Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
◆◆◆◆◆◆◆◆◆◆◆ Full Codes ◆◆◆◆◆◆◆◆◆◆◆◆
Monday,06,September,2021,12:31:44:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0 www.Ross-Tech.com
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 44A7DF0322E5FBC0CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3B7582EBB265A953D6-806E
1 Fault Found:
0876 - Terminal 15
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:50
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: 9D
Uz: B4
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7C04010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 285F4DA753F312CBAB-807C
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:50
Control Module temperature: 71 캜
Voltage terminal 15: 13.807 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s?
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00FRRM0
Coding: 3031453032314E303038554A304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 366393DF8947743B29-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB400A50MESGGO%
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB405522V209H5T
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB400G50OCCQHBQ
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB400250OCCF19R
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400G50P7AH222
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400G50P7AKA2E
1 Fault Found:
1049600 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:51
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001178618
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72EB6FCFA5AF281BC5-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 1869341703
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1309100000000000037A
1 Fault Found:
4228 - No Communication with ABS Brake Control Module
U0121 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:51
Voltage terminal 30: 13.8 V
Voltage terminal 15: 13.8 V
Control Module temperature: 68 캜
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0783
Coding: 008002
Shop #: WSC 31337 128 28888
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F6DA6BB761D45F36A-807A
1 Fault Found:
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:51
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F5E025E00628202080402
VCID: 4487F917C79BD6ABA7-8010
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7C04010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 2643439F59E704BB99-8072
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:50
Voltage terminal 15: 14.018 V
Velocity_vehicle_reference: -0.00 m/s
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000621702157
Coding: 0380AB180111
Shop #: WSC 00070 123 12345
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2C57B1B7470B3EEB4F-8078
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 104308 km
Date: 2021.09.06
Time: 17:27:51
Outside temperature: 33.0
Control Module temperature: 47.0
I had the same problem with same issue . I pull out the fuel then return them back after that same light on my dashboard .what did you do .did you fix it
