Lable file update?
Just loaded up VCDS 805, and for the climate on mine it does not show a lable file - says redirect fail I think...
This is on a 01.5 A4, the last of the B5 - 2.4se.
It was something that Seb was looking at a while back, not sure where we got to...its on 8D0-820-043-Q
Is there one for this unit?
..the redirect (i.e. determination which type of climate control unit is installed) is already implemented, but the actual label file is not which is why VCDS comes up with redirect failed.
Saturday,31,May,2008,08:55:45:41917
VCDS Version: Release 805.0
Data version: 20080529
Chassis Type: 01 - V6LAF Audi A4 B5
Scan: 01 02 03 08 15 17 35 45 56
VIN: WAUZZZ8DZ1A021256
Address 01: Engine Labels: 078-907-552-AMM.lbl
Part No: 3B0 907 552
Component: 2.4L V6/5V G01 0002
Coding: 11551
Shop #: WSC 01128
WAUZZZ8DZ1A021256 AUZ7Z0Y1484545
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 8D0-927-156.lbl
Part No: 8D0 927 156 DG
Component: AG5 01V 2.4l5V RdW 1111
Coding: 00003
Shop #: WSC 06435
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00031
Shop #: WSC 06435
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 06435
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 01104
Shop #: WSC 06435
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 K
Component: B5-KOMBIINSTR. VDO D12
Coding: 02462
Shop #: WSC 00340
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 16234
Shop #: WSC 00350
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195
Component: Radio D00
Coding: 00012
Shop #: WSC 06435
1 Fault Found:
00850 - Control Output Active; Radio Amplifier
29-10 - Short to Ground - Intermittent
End ---------------------------------------------------------------------
Coding: 11551
Shop #: WSC 01128
Coding: 00003
Shop #: WSC 06435
Coding: 00031
Shop #: WSC 06435
Coding: 00061
Shop #: WSC 06435
Coding: 01104
Shop #: WSC 06435
Coding: 02462
Shop #: WSC 00340
Coding: 16234
Shop #: WSC 00350
Coding: 00101
Shop #: WSC 06435
Coding: 00012
Shop #: WSC 06435
1 Fault Found:
Hillbilly
01-06-2008 07:30 PM
