Lap Timer & MMI 3G installed
I set out to enable lap timer on my Q5 after seeing this pic: http://i559.photobucket.com/albums/s...s/IMG00064.jpg
I just had to have the boost and oil temperature indication. I didn't care at all for the lap time.
See my long coding:
![](http://img203.imageshack.us/img203/3990/vcds17.jpg)
Two questions:
1) I've ticked Bit 3 "Lap Timer active" but while the lap timer works there is no boost or oil indication
I also tried a mmi restart, didn't help.
2) While I'm not sure about key warning (my car warns me when the key is not in car/etc., I have advance key) I'm 100% sure my car has mmi 3g with hd nav. Why aren't Bit 6 and Bit 7 Enabled? By clicking do it, without these options ticked have I overriden and disabled something I shouldn't?
Thanks!
See my long coding:
Two questions:
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Thanks!
What was your original coding before you started changing stuff?
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Just to make sure we are on the same page, did you have boost and oil temp shown before you made the change or not?
As far as I understand this you did not and mistakenly interpreted the linked image that the lap timer would enable both, which it doesn't.
No I did not have boost or oil temp or lap timer before I made the change.
My reasoning was that the lap timer was used on track so the driver also keeps an eye on boost/oil temp.
So is there another coding for the boost/oil temp? I know the sensors are in the car and I know the software is already there (see pic I think it was from an A6) so there must be a way to enable this.
Could you please post an Auto-Scan from your vehicle so that we can actually see what is installed in terms of part numbers and software versions? Just because the sensors are there it doesn't mean the function can easily be activated, some stuff has always been limited to special models like Ausi's S and RS series.
Mine says the same thing, bit 6 is unchecked even though I have 3G MMI with the HDD. Because of that I didn't dare to check bit 0 (Needle Sweep) if I would override something. So, I just did hit Cancel .....
Theresias I've send you an email with the Auto-Scan. Thanks.
hankoman, what a relief. I'm glad I'm not the only one. Is "bit 7" disabled on yours as well and do you Advance Key? Needle Sweep is certainly one of the coolest things you can do with vcds and it is first to do on my list after the warranty runs out. My dealer is old fashioned and the dials are too in your face to miss them. He won't notice the other mods.
My mind was telling me to hit the "Cancel" button as well but at the same time I was looking at the photo of the boost indicator and the flesh (hand) was too weak. I clicked the "Do it" instead.
Porkibear
08-30-2004 03:28 AM
Toronto B6 -OnEighty
07-20-2003 08:58 PM
Howard Kim
01-07-1999 09:52 PM
