Lean at idle and misfire on cyl 2 at idle! :(
Hi,
I've got the following code:
VAG-COM Version: Release 504.1-UD
Control Module Part Number: 8P0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI G00 0050
Software Coding: 0103001018070160
Work Shop Code: WSC 06314
1 Fault Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - Intermittent
I've had a look at the fuel trim and they look ok. Idle around 1.3 - 2%, Partial around -3.5%
I also tried to do the carb cleaner vacuum leak test and the car did not react when I sprayed it near the boost pipes etc.
What I did however notice is a constant misfire on cyl 2 when at idle....VAG registers around 7 times (per minute I assume). When driving there are no misfires!?!?!?!? WTF?
HELP PLEASE!
Went to Audi and the main techie said he has never seen a lean at idle code Wonder why I even bothered to visit the Audi dealer!!!
1 Fault Found:
HELP PLEASE!
My lean at idle problem can be found here:
http://audifans.com/pipermail/a4/2006-January/001680.html
Doesn't seem like your situation though.<ul><li><a href="http://audifans.com/pipermail/a4/2006-January/001680.html">http://audifans.com/pipermail/a4/2006-January/001680.html</a</li></ul>
Audi is now replacing the MAF...not sure that that will aoso fix the misfire on cylinder 2 but they say it will solve all my problems. I disagree but I guess we'll see
I saw this in the newsgroups and assumed it was you. Might want to check it out. --Art
----- Original Message -----
Newsgroups: alt.autos.audi
Sent: Friday, February 17, 2006 5:57 PM
Subject: Re: audi a4 misfire
> hi have a audi s4 1.8t i have a problem i have tried everything from the
> coil packs to the computer and cylinder no2 has no spark???
If it is an early 1.8T (AEB) then this is probably the fault :
http://www.robsaudiworld.com/ignition.htm
Rgds<ul><li><a href="http://www.robsaudiworld.com/ignition.htm">http://www.robsaudiworld.com/ignition.htm</a</li></ul>
Silence
04-21-2008 01:20 PM
S4@last!::Now B7 RS4
05-02-2005 08:50 AM
