Lighting error
OK - was doing a little coding yesterday...
Turn DRL's on - Scandinavia setting - all good
Fog lights as DRL's - all good.
Dimming DRL's (fogs are pretty bright) entered 0 value - no go.
Anyway this morning the DIS is throwing up an error for left & right turn bulb.
But....the indicators are working fine.
It's possible I've somehow changed a setting but everything looks ok.
Any one have any suggestions?
Cheers
Cheers
I suppose we should just guess what kind of car you have, and exactly what coding changes you've made? ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Car is Aydi TT 8J MY07
Here's the auto scan - it only scans about half the data and then quits...
Saturday,19,June,2010,22:55:49:23651
VCDS Version: Beta 10.3.0
Data version: 20100324
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 57 77
VIN: TRUZZZ8J771009819 Mileage: 36260km/22530miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8J0 907 115 HW: 8J0 907 115
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH15--- Serial number: AUX7Z0F8FNT0AC
Coding: 011300431C070160
Shop #: WSC 31250 822 92138
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1163
Revision: 04507000 Serial number: 00000608230245
Coding: 0000020
Shop #: WSC 01236 785 00200
Address 03: ABS Brakes Labels: 8J0-614-517.lbl
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0017424
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 R HW: 8J0 820 043 R
Component: J255 Klima 1 Zone 0060
Revision: 00H07002 Serial number: 00000001012689
Coding: 1573956
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 H HW: 8P0 907 279 H
Component: Bordnetz-SG H46 1802
Revision: 00H46000 Serial number: 00000006215851
Coding: E1041E8380141C00000000031800000000097E0700210802
Part No: 8J2 955 119
Component: Wischer AU354 H06 0060
Coding: 00064784
Shop #: WSC 01236
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH12 0090
Coding: 00149804
Shop #: WSC 01236
3 Faults Found:
01834 - Bulb for Side-Blinkers; Left (M18)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 36035 km
Time Indication: 0
Date: 2010.06.13
Time: 10:27:00
Freeze Frame:
ON
Voltage: 11.80 V
OFF
ON
OFF
OFF
ON
01835 - Bulb for Side-Blinkers; Right (M19)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 36035 km
Time Indication: 0
Date: 2010.06.13
Time: 10:27:00
Freeze Frame:
ON
Voltage: 11.75 V
OFF
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 181
Mileage: 36264 km
Time Indication: 0
Date: 2010.06.19
Time: 13:54:00
Freeze Frame:
ON
Voltage: 11.90 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K0008FFO
Coding: 0011634
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014141
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY7.lbl
Part No SW: 8J0 920 930 C HW: 8J0 920 930 C
Component: KOMBIINSTR. VDO H20 0070
Revision: D0H20003 Serial number: 2248F003010867
Coding: 0000718
Shop #: WSC 03122 822 96270
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 3200106906813B
Coding: 3F0F03DA07004101
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H20003 Serial number: AUX7Z0F8FNT0AC
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8J0 035 192 HW: 8J0 035 192
Component: RNS-E HIGH EU H10 X---
Revision: 01S Serial number: AUZBZ7F0004943
Coding: 0614716
Shop #: WSC 00000 000 00000
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 31743 km
Time Indication: 0
Date: 2010.01.30
Time: 15:37:09
Freeze Frame:
Mileage: 31740 km
Count: 3001
Clock: 15:36
Address 42: Door Elect, Driver
Cannot be reached
Uwe
Still trying to track down this globe out warning...
Here's a full scan
Thanks
Saturday,26,June,2010,11:41:08:23651
Chassis Type: 1K0
VIN: TRUZZZ8J771009819 Mileage: 36440km/22642miles
Coding: 0000020
Revision: 00H52001
Coding: 0017424
Coding: 1573956
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 36035 km
Time Indication: 0
Date: 2010.06.13
Time: 10:27:00
Freeze Frame:
ON
Voltage: 11.80 V
OFF
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 36035 km
Time Indication: 0
Date: 2010.06.13
Time: 10:27:00
Freeze Frame:
ON
Voltage: 11.75 V
OFF
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 181
Mileage: 36264 km
Time Indication: 0
Date: 2010.06.19
Time: 13:54:00
Freeze Frame:
ON
Voltage: 11.90 V
OFF
ON
OFF
OFF
OFF
Coding: 0011634
Coding: 0014141
Coding: 0000718
Coding: 0614716
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 31743 km
Time Indication: 0
Date: 2010.01.30
Time: 15:37:09
Freeze Frame:
Mileage: 31740 km
Count: 3001
Clock: 15:36
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J8 959 801 C
Component: Tuer-SG H02 0050
Coding: 0000533
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 8J2 909 143 B
Component: EPS_ZFLS Kl.156 H07 1807
Address 46: Central Conv. Labels: 8J0-959-433.lbl
Part No: 8J0 959 433
Component: KSG H06 0070
Coding: 9890300201182D290F0D489A0167
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 HW: 8J0 035 223
Component: J525 Amp Std H02 0100
Revision: 00H02003 Serial number: 93801000776405
Coding: 0006117
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8J8 959 802 C
Coding: 0000533
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0614716
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 31743 km
Time Indication: 0
Date: 2010.01.30
Time: 15:37:09
Freeze Frame:
Mileage: 31740 km
Count: 3001
Clock: 15:36
Address 57: TV Tuner
Cannot be reached
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005035663
Coding: 0011422
End ---------------------------------------------------------------------
Here's a full scan
Thanks
Chassis Type: 1K0
Coding: 0000020
Revision: 00H52001
Coding: 0017424
Coding: 1573956
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 36035 km
Time Indication: 0
Date: 2010.06.13
Time: 10:27:00
Freeze Frame:
ON
Voltage: 11.80 V
OFF
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 36035 km
Time Indication: 0
Date: 2010.06.13
Time: 10:27:00
Freeze Frame:
ON
Voltage: 11.75 V
OFF
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 181
Mileage: 36264 km
Time Indication: 0
Date: 2010.06.19
Time: 13:54:00
Freeze Frame:
ON
Voltage: 11.90 V
OFF
ON
OFF
OFF
OFF
Coding: 0011634
Coding: 0014141
Coding: 0000718
Coding: 0614716
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 31743 km
Time Indication: 0
Date: 2010.01.30
Time: 15:37:09
Freeze Frame:
Mileage: 31740 km
Count: 3001
Clock: 15:36
Coding: 0000533
Coding: 0006117
Coding: 0000533
Coding: 0614716
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 31743 km
Time Indication: 0
Date: 2010.01.30
Time: 15:37:09
Freeze Frame:
Mileage: 31740 km
Count: 3001
Clock: 15:36
Cannot be reached
Coding: 0011422
SMOOOV
9
02-27-2007 05:17 AM
LiQuuS4
9
10-11-2004 07:53 AM
amiro
05-30-2004 11:36 AM
