a little help with some symptoms and codes, pretty please.
Vehicle: 2005 allroad 4.2
Symptom: Today, Wife found that the trunk of car was not properly shut and left that way all night. She closed it and drove to work. No problems.
While driving home, about 45 minutes into commute, the battery light illuminates on dash, and windshield wipers start slowing down. She makes it home the last 3 miles with no problem after turning off wipers and radio.
I pulled codes and found these faults below. Also found these posts related to the Engine Fault I found.
Thx all.
Monday,09,March,2009,18:47:00:23099
VCDS Version: Release 805.1
Data version: 20081017
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WA1YL64B25N024717
Address 01: Engine Labels: None
Part No SW: 4D0 907 560 DC HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Revision: 00000000 Serial number: AUZ7Z0D2693955
Coding: 0007755
Shop #: WSC 02334 785 00200
1 Fault Found:
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 4Z7 927 156 AA
Component: AG5 01V 4.2l5VT USA 0505
Coding: 0001002
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D66
Coding: 06387
Shop #: WSC 02334
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00110
Shop #: WSC 02335
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 N
Component: Airbag 8.4EP 1000
Coding: 0000607
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02334
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 F
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 20283
Shop #: WSC 05419
WA1YL64B25N024717 AUZ7Z0D2693955
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 02334
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15949
Shop #: WSC 02335
1 Fault Found:
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
Address 37: Navigation Labels: None
Part No SW: 4B0 035 192 R HW: 4B0 035 192 R
Component: RNS-E US3 H53 0110
Revision: 03S Serial number: AUZBZ7D1600171
Coding: 0509137
Shop #: WSC 02335 785 00200
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
Address 56: Radio Labels: None
Coding: 0509137
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 02334
End ---------------------------------------------------------------------
Thx all.
76 77
Coding: 0007755
1 Fault Found:
Coding: 0001002
Coding: 06387
Shop #: WSC 02334
Coding: 00110
Shop #: WSC 02335
Coding: 0000607
Coding: 01002
Shop #: WSC 02334
Coding: 20283
Shop #: WSC 05419
Coding: 25500
Shop #: WSC 02334
Coding: 15949
Shop #: WSC 02335
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
Coding: 0509137
Coding: 00030
Shop #: WSC 02334
Coding: 0509137
Coding: 01186
Shop #: WSC 02334
Just ran car for a half hour, driving around at different speeds. Volt meter on dash indicated less than 12volts. Seemed to hold steady. I stopped, ran VAG-COM, got a fault for low voltage to Suspension Leveling. I was idling length of AutoScan.
I took off driving and watched the voltage drop....quickly. Car went into limp mode, but thankfully made it into drive way.
Crap, either a really bad battery(from inside lights being on all day) or alternator.I am guessing alternator. Battery Charged up to 12.45 volts rather quickly. While on, car is showing less than 12 and dropping between battery terminals.
Accepting donations to my paypal.
Coding: 25500
Shop #: WSC 02334
1 Fault Found:
01400 - Suspension Level Control
53-00 - Supply Voltage Too Low
Coding: 25500
Shop #: WSC 02334
1 Fault Found:
Out of curiosity, how old is your battery? I found out (the expensive way) that, when a battery gets old (4-5 years), it is likely to become "worn-out", needing constant charging and therefore puts a huge strain on the alternator, causing that to fail. Solution is to change batteries sooner, before they wear out the alternator.
the charger. I tested the voltage at 12.25 across the batt. terminals. When I started it, the battery voltage did not drop much. But then, watched the voltage go from 12v and slowly tik down. i have been told that if the alternator was working, you'd get 14.5v across the terminal.
Going to Lewis today. Should be covered under CPO.
cutchemist42
06-07-2013 04:19 AM
Tonytza
VAG-COM Discussion
04-14-2008 07:14 AM
