Measuring Block 90 - AHA engine ('98 A4 V6 30V)
I have two very weird things going on with my readings in this block (camshaft position & adjustment).
First, while my normal positions are 0 on both banks, they do intermittently jump to -3 or +3 and then fall back to 0. While those values are still within spec., that is really weird, isn't it? What could I have checked to figure that one out?
Second, camshaft adjustment is never activated, even when driving in 2nd gear at 4000+ RPM. It just never changes to ON. While the car seems to be running fine, that doesn't seem right, does it? What could I have checked to figure that one out?
As always, thanks for your thoughts...
Here is a WOT to the redline test of my 6-cyl. car with measuring blocks open on the camshaft positions and misfire counting on bank 1 (bank 2 can be implied to have had no misfires). The test resulted in a flashing CEL and 5 fault codes thrown.
Measuring blocks
Group A: '090 (Camshaft adjustment)
Group B: '014 (Total misfire counter)
Group C: '015 (Bank 1 misfire counters)
TIME STAMP|Engine RPM|Adj ON/OFF|Adj resp Bank1|Adj resp Bank2|TIME STAMP B|Engine RPM|Engine Load|Total misfires|TIME STAMP C|Misfires Cyl 1|Misfires Cyl 2|Misfires Cyl 3
56.39| 680|Cam Ctrl. OFF| 00|-1|56.67|680 |2.00|0 |56.11|0 |0 |0
57.22| 680|Cam Ctrl. OFF| 00|-1|57.49|680 |1.95|0 |56.95|0 |0 |0
58.03| 680|Cam Ctrl. OFF| 00| 2|58.31|680 |2.00|0 |57.77|0 |0 |0
58.87| 680|Cam Ctrl. OFF| 00| 2|59.14|1320|5.25|0 |58.59|0 |0 |0
59.69|1880|Cam Ctrl. ON |-12|14|59.97|1960|5.15|0 |59.42|0 |0 |0
60.52|2320|Cam Ctrl. ON |-21|23|60.79|2560|5.85|15|60.24|0 |0 |0
61.34|3160|Cam Ctrl. ON |-21|20|61.62|3520|6.45|78|61.07|12|12|12
62.17|4120|Cam Ctrl. ON |-21|23|62.46|4440|6.30|85|61.89|28|27|30
63.10|5080|Cam Ctrl. ON |-21|23|63.48|5440|6.60|85|62.76|28|27|30
64.14|5480|Cam Ctrl. OFF| 00| 2|64.46|5240|0.75|85|63.81|28|27|30
65.03|4840|Cam Ctrl. OFF| 00|-1|65.30|4640|0.80|85|64.77|28|27|30
65.85|4280|Cam Ctrl. OFF| 00|-1|66.18|4080|0.80|85|65.57|28|27|30
Address 01: Engine
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR AT D01
Software Coding: 06251
Work Shop Code: WSC 06335
5 Faults Found:
17746 - Camshaft Position Sensor (G40): Open or Short to Plus
P1338 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
Readiness: 0000 0000
The spec. for camshaft positions is -3 to +6 in normal mode, and 16 to 25 in shifted mode (adjustment active). On Bank 1, I got -12 and -21 when adjustment was active (completely off spec.), which obviously totally baffled the computer and caused it to fault the camshaft position sensor itself! (though I never understood why the G40 camshaft position sensor 1 is mounted onto the back of bank 2) On Bank 2, the only questionable thing about the results is the initial position at 14degrees, which is too low (<16) for when camshaft adjustment is active.
What do you folks make of this? Did bank 1 just totally lose compression once adjustment was active. How could it have adjusted the wrong direction like this? What possibly could be wrong with my engine's setup?
Measuring blocks
Address 01: Engine
5 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0303 - 35-00 - -
P0302 - 35-00 - -
cparke
09-26-2008 10:17 AM
FixedWing
33
11-02-2005 12:21 PM
swett
VAG-COM Discussion
09-20-2003 09:22 AM
