Measuring Value Blocks (MVB) to Check Timing Chain??
I am getting code 17748 Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
and according to the Ross tec wiki I am supposed to Use Measuring Value Blocks (MVB) to Check Timing Chain but I have no idea how to do this.
I go under control module/ then engine/ then Meas. Blocks -08?
am I even looking in the right place?
thanks!
thanks!
<ul><li><a href="http://www.ross-tech.com/vcds/tour/autoscan.html">http://www.ross-tech.com/vcds/tour/autoscan.html</a</li></ul>
Andy
Andy
VAG-COM Version: Release 409.1-S
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 01236
TRUWT28N111XXXXXX AUZ5Z0YD153167
1 Fault Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00 - -
Readiness: 0010 0101
Address 03: ABS Brakes
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
49-00 - No Communications
Address 08: Auto HVAC
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D52
Coding: 07244
Shop #: WSC 00000
TRUWT28N111028131 AUZ5Z0YD153167
Address 22: AWD
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
3 Faults Found:
01312 - Powertrain Data Bus
37-00 - Faulty
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01314 - Engine Control Module
Address 35: Centr. Locks
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D05
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00957 - Key 3
Address 45: Inter. Monitor
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
1 Fault Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49)
28-00 - Short to B+
Address 01: Engine
Coding: 06710
Shop #: WSC 01236
1 Fault Found:
P1340 - 35-00 - -
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
Coding: 00140
Shop #: WSC 01236
Coding: 07244
Shop #: WSC 00000
Address 22: AWD
3 Faults Found:
37-00 - Faulty
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
00957 - Key 3
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 01236
1 Fault Found:
28-00 - Short to B+
GTA_Driver
02-02-2012 07:25 AM
CvTech
09-03-2008 07:27 AM
