Most of the ECU cannot be reached
Hello everyone,
I'm sorry if you find some English mistakes because I don't speak English fluently.
For a little problem, I disconnected the battery to check all fuses.
All fuses are OK.
I reconnect the battery and when I turn key a big problem append:
When I turn the ignition, the dash does not light, no signal lamp.
If you try to start the car, it starts then cut (block) in the second after startup.
Many fittings do not work:
Ceiling lights does not work when the door opens.
The power windows do not work from another door that is located the command.
The remote has no effect on the car (open / close).
Hence the problem can come from?
See vagcom scan :
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect.-- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Default 0010
25-Immobilizer -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
46-Central Conv -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
4F-Centrale Elect. II -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Please help me.
All fuses are OK.
See vagcom scan :
Please help me.
What Audi model is this, and what is the model year? Since you have the address 05-Acc/Start Auth. module I'm thinking a A6 or A8 of some type. The 05 module will shut all communication down if a problem is present.
Are you sure all of the fuses are reinstalled in the proper locations? What was wrong with the car that made you disconnect the battery and check fuses?
If you have a scan from before the car died please post the entire thing.
Thanks for your answer Dana.
My car: Audi A6 Avant C6 (year: 2006)
I will check this evening.
I start the bootloader from hidden menu MMI. Once launched, the bootloader runs continuously (even if the ignition off). When I made this mistake, I did not the CD update required by the bootloader. I had disconnected the battery while waiting for buying CD. When I reconnected the battery, (15hour later), all ECU on MOST(optical) bus “Cannot be reached”.
If MOST bus is down, bootloader cannot read CD in CD player (CD changer).
For this reason, I tried to see if a fuse did not have blown by reconnecting the battery
Yes, I perform scan before disconnected the battery:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect-- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv -- Status: OK 0000
4F-Centrale Elect. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
1 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 44
Controller Electrical / Optical
19-CAN Gateway ERROR / ERROR
07-Control Head ERROR / ERROR
0E-Media Player 1 ERROR / ERROR
47-Sound System ERROR / ERROR
56-Radio ERROR / ERROR
When I erase faults found on ECU 19 (CAN Gateway), it appears again when I turn ON/OFF/ON ignition key.
Hi,
That's the Gateway Installation list, not the Auto-Scan. Please see this video:
http://www.youtube.com/watch?v=4jt3lYLy4UU
Or, the interactive manual explanation:
http://www.ross-tech.com/vcds/tour/autoscan.html
My interface is not in English -> I translated results of the auto scan.
I forgot to translate:
00384 - Bus de données optique
011 - Coupure
by
011 - Open Circuit
to complete my post, here you are optical test result :
"Controller Electrical / Optical
011 - Coupure
by
011 - Open Circuit
You're using an outdated version of VCDS which is no longer supported by us. Please update to the latest Release 10.6 or the new Beta 11.2. As usual the update is free, so there is no reason to use outdated versions...
downunder
12
10-01-2006 09:12 AM
bostoned
10-11-2005 10:15 AM
