Most problem
I have attempted installing bluetooth module instead of onstar on my 2005 a8. I did it by disconnecting XM module and using Most connection from it along with + - ring diagnostic wire.
After starting the car my MMI system is not working as I found out due to break in most ring. I connected XM module back, but still can not get MMI along with bunch of other to work. Here is one of my first MOST tests
![](https://lh3.googleusercontent.com/-gJAwEtO5IrU/T1VC3USsxdI/AAAAAAAAAr8/dEZCHJRUxKo/s640/IMAGE_BEDC1EA5-5D63-41BA-9515-768F554CB700.JPG)
then I found bad fuse for navigation in trunk department, after replacing that I got
![](https://lh4.googleusercontent.com/-sBzcuL58KLc/T1VLJ8JLsBI/AAAAAAAAAsE/hTBHD70Hx2o/s640/IMAGE_C319CA0F-5082-4B54-81D6-28E8BA59DE6B.JPG)
after that I disconnected XM module, connected it again and now get Errors for radios again. Its really strange to me, seems like problems are jumping from one to another. Does anybody have a suggestion?
Monday,05,March,2012,22:25:49:19379
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1F 25 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 72 76
VIN: WAUML44E65N001344 Mileage: 125220km/77808miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1F-Sat. Tuner -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number: AUX3Z0D4742119
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2855D7EA9BE83A3
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0010
Revision: --H01--- Serial number: 0036891
Coding: 0000002
VCID: 32613582AD34403
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2241C5C2FDD4D03
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0D4742119
Coding: 0410624
Shop #: WSC 03200 444 54293
VCID: D8B5272A6B08CA3
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234FC0C6E2CED9B
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000121073
Coding: 1085761
Shop #: WSC 08353 444 54346
VCID: 1C3DFB3ADFB0E63
2 Faults Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 11
Reset counter: 64
Mileage: 124566 km
Time Indication: 0
Date: 2012.02.24
Time: 00:15:05
01308 - Control Module for Roof Electronics (J528)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 64
Mileage: 125222 km
Time Indication: 0
Date: 2012.03.05
Time: 21:46:39
Freeze Frame:
Bin. Bits: 00001111
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E1 955 113 B
Component: ILM Fahrer H12 0190
Coding: 0123111
VCID: 2F673CF6BE066DB
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00146247
Shop #: WSC 02313
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 244DC3DAE7C0DE3
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
Shop #: WSC 02311 785 00200
VCID: E5CB1EDE2C7A67B
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H47 0200
Revision: D02 Serial number: AUDID3D4000896
Coding: 0016208
Shop #: WSC 03200 444 59238
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005044041AF7
Coding: FCFE7BDD1B2906
Shop #: WSC 01814 444 59304
VCID: 2649D9D291FC2C3
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 125222 km
Time Indication: 0
Date: 2012.03.05
Time: 22:22:19
Address 1F: Sat. Tuner
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0010110
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory FS H02 0010
Coding: 4063330
Shop #: WSC 00000 000 00000
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000411300226
Coding: 0003477
VCID: 1D3BF63EC4AAEFB
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRMH01 0060
Coding: 0028204
VCID: 2045CFCAF3D8C23
3 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 64
Mileage: 124560 km
Time Indication: 0
Date: 2012.02.23
Time: 22:43:24
01705 - Selection Switch for Mirror-Adjust (E48)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 53
Mileage: 124720 km
Time Indication: 0
Date: 2012.03.01
Time: 10:57:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:22
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040405270021
Coding: 0065086
VCID: 2757D4D696F635B
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000040240
Coding: 0010111
VCID: 1E39F132C9ACF43
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0028204
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:22
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 03200 444 82880
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 254
Time Indication: 0
Freeze Frame:
Voltage: 9.42 V
Count: 61
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C105C23D54103
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000001074
Shop #: WSC 03811 444 90176
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 3103066183
Coding: 303030393135313035444C56413033313033303636313833
Shop #: WSC 12345 128 00289
1 Fault Found:
02255 - Voltage Measuring Lead from Vbat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 25
Mileage: 125222 km
Time Indication: 0
Date: 2012.03.05
Time: 22:18:02
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028204
2 Faults Found:
02110 - Window Regulator Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 53
Mileage: 124704 km
Time Indication: 0
Date: 2012.02.29
Time: 20:37:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:22
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0202224
Shop #: WSC 65793 000 00000
VCID: DFC70C360E263DB
1 Fault Found:
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 25
Mileage: 125177 km
Time Indication: 0
Date: 2012.03.05
Time: 16:19:08
Freeze Frame:
Speed: 0.0 km/h
Temperature: -3.0°C
Error Code: 64
Pressure: 2.62 bar
Pressure: 2.50 bar
Pressure: 2.67 bar
Pressure: 2.70 bar
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028204
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:24
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730413301379
Coding: 0001208
VCID: 2143CACEF8D2CBB
End ---------------------------------------------------------------------
Chassis Type: 4E0
Coding: 0007773
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
Coding: 3940448
Cannot be reached
Coding: 1085761
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 64
Mileage: 124566 km
Time Indication: 0
Date: 2012.02.24
Time: 00:15:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 64
Mileage: 125222 km
Time Indication: 0
Date: 2012.03.05
Time: 21:46:39
Freeze Frame:
Bin. Bits: 00001111
Coding: 0123111
Coding: 00000035
Shop #: WSC 02313
Coding: 00146247
Shop #: WSC 02313
Cannot be reached
Cannot be reached
Coding: 0530707
Coding: 0012241
Coding: 0016208
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 125222 km
Time Indication: 0
Date: 2012.03.05
Time: 22:22:19
Cannot be reached
Coding: 0410624
Component: ELV XXXX
Coding: 0010110
Coding: 4063330
Cannot be reached
Coding: 0003477
Coding: 0028204
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 64
Mileage: 124560 km
Time Indication: 0
Date: 2012.02.23
Time: 22:43:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 53
Mileage: 124720 km
Time Indication: 0
Date: 2012.03.01
Time: 10:57:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:22
Coding: 0065086
Cannot be reached
Coding: 0010111
Coding: 0028204
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:22
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 254
Time Indication: 0
Freeze Frame:
Voltage: 9.42 V
Count: 61
Coding: 0000001
Address 56: Radio
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 25
Mileage: 125222 km
Time Indication: 0
Date: 2012.03.05
Time: 22:18:02
Coding: 0028204
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 53
Mileage: 124704 km
Time Indication: 0
Date: 2012.02.29
Time: 20:37:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:22
Coding: 0202224
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 25
Mileage: 125177 km
Time Indication: 0
Date: 2012.03.05
Time: 16:19:08
Freeze Frame:
Speed: 0.0 km/h
Temperature: -3.0°C
Error Code: 64
Pressure: 2.62 bar
Pressure: 2.50 bar
Pressure: 2.67 bar
Pressure: 2.70 bar
Coding: 0028204
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 65
Mileage: 125216 km
Time Indication: 0
Date: 2012.03.05
Time: 21:47:24
Coding: 0001208
