Multiple warning lights
Hi . I hope someone in the forum can help me. I have multiple warning lights in my Audi A3 8V .ABS,ESC, Hill hold, I've replaced the rear left ABS sensor and sensor ring and tried resetting the faults with VCDS but no success .Diagnostic reads as follows. Anyone any suggestions please.01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: Malfunction 0010
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6546
Revision: 84H22--- CVN: 2D99C26C
Coding: 02190032030501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002011
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 6FEA7536B699D1F726-803A
VINID: 9D196AAAA2260954411072021476F8ADFE
2 Faults Found:
17158 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
4714 - Steering Column Control Module
U0212 00 [032] - No Communications
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 60374000000E87
Coding: 12F18AA224240A73017F060241C82548512450806082A4F2F4 41F0080608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BF25166F2E1BD579A-802E
3 Faults Found:
0071 - Rear Left Wheel Speed Sensor
C101C 4A [137] - Incorrect Component(s) Installed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:43:57
8309 - Engine Control Module Incorrectly Coded
P1612 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 236
Date: 2022.06.18
Time: 16:43:56
32994 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000245865
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 326CBC42652BBC1F09-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 16688F07000000000001
1 Fault Found:
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 236
Mileage: 141499 km
Date: 2022.05.23
Time: 16:29:43
Outside temperature: 18 °C
Engine RPM: 814.50 /min
Compressor current: actual value: 0.000 A
Temperature downstream of evaporator: 27.1 °C
Refrigerant pressure: 1.0 bar
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 3 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011404403539
Coding: 07040A42C24122FD03844004B31C07A8000000000000000000 0000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140126 041 0580
Serial number: 140203053251
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22252318
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 22 11 2013 00000868
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140230W7S
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028939791
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 190
Mileage: 141070 km
Date: 2022.05.12
Time: 10:55:03
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.3 V
Outside temperature: 12.0 °C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 B HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0033
Revision: -------- Serial number: 61131403402497
Coding: 0110060041
ASAM Dataset: EV_EPHVA2CAU3700000 003015
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 3E749872A173687FFD-806A
4 Faults Found:
13637409 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
13637422 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
13679388 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 24011476510459
Coding: 00200301FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 366480528943A03F25-8062
7 Faults Found:
1067 - Brake Temperature
C10DF 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
Control Module temperature: 23 °C
Voltage terminal 15: 11.7 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1056 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
0269 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 141160 km
Date: 2022.05.14
Time: 14:53:25
Control Module temperature: 38 °C
Voltage terminal 15: 11.8 V
1118 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 236
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1081 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 236
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R056TPX
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4B92C1A6E2C1CDD76A-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 102 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000218C0EE0-
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 001 102 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000418C0EE0$
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 400 702 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C713013F2A10Y
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 400 702 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502A112AB1B1F268
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 901 14
Component: FrontSensor_D 001 6149
Serial number: 3556502B313013E4E295
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 402 001 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A712FAE260118
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 400 302 14
Component: PedP_Sensor_P 001 6149
Serial number: 22965029B13013F570D8
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 400 302 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502B313013F5B13W
Coding: 2D2D2D
No fault code found.
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BR HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 27011408491381
Coding: 8408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 0B1201A6A2418DD7AA-805E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 Q HW: 8V0 920 970 Q
Component: KOMBI H03 2220
Coding: 27840A002E9046000180A800100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 4A9CC4A2EDBBD4DF51-801E
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001576545
Coding: 030100040B0876005B000258080B0000000100000000000000 0000000000
GVL: 01543C0000000000400C900000004800000000000000000000 00000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3F8AE576A6796177F6-806A
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 22 01 2014 E0327960
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 2512762503
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 28011401100742
Coding: 00108E204001040000001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4088E68ADB871E8F8F-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8303
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 418EE38ED08D178780-8014
2 Faults Found:
20228 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Reset counter: 21
Mileage: 141160 km
Date: 2022.05.14
Time: 14:45:19
Motor status: 01
System status: Driving mode
Supply voltage: 11.75 V
Temperature: 38.0 °C
KFC: 4F
KFA: 00 04
Freeze frame conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 11.69 V
uAdSensI_SwitchedKl30_xdu16: 11.69 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 21
Mileage: 141160 km
Date: 2022.05.14
Time: 14:45:19
Motor status: 01
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 11.81 V
uAdSensI_SwitchedKl30_xdu16: 11.82 V
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 26011403111502
Coding: 001086204001040000001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 018E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E6475ED4C5EB27EC-8020
1 Fault Found:
13705985 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 84
Reset counter: 236
Mileage: 141160 km
Date: 2022.05.14
Time: 14:24:57
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F00902141305
Coding: 01730301FF00000021111101000A00002F0001460100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B729166B2617D57DA-806E
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9DY3017DX
Multimedia system control head:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000023011400010160
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 02021403110109
Coding: 000086204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 428CEC82D58B0C9F99-8016
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0025
Serial number: 02021404080107
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
3 Faults Found:
65578 - Motors for Central Locking
B122B 12 [008] - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 21
Mileage: 141360 km
Date: 2022.05.20
Time: 19:57:47
65579 - Motors for Central Locking
B122B 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 88
Reset counter: 236
Mileage: 141066 km
Date: 2022.05.12
Time: 10:45:33
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 234
Mileage: 141066 km
Date: 2022.05.12
Time: 10:45:34
End-------------------------(Elapsed Time: 04:18)--------------------------
ReplyForward
2 Faults Found:
17158 - Databus
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:43:57
P1612 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 236
Date: 2022.06.18
Time: 16:43:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 236
Mileage: 141499 km
Date: 2022.05.23
Time: 16:29:43
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 190
Mileage: 141070 km
Date: 2022.05.12
Time: 10:55:03
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.3 V
Coding: 0110060041
4 Faults Found:
13637409 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
13637422 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
13679388 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 141870 km
Date: 2022.06.18
Time: 16:48:48
7 Faults Found:
C10DF 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1056 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
0269 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 141160 km
Date: 2022.05.14
Time: 14:53:25
1118 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 236
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
1081 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 236
Mileage: 141066 km
Date: 2022.05.12
Time: 10:28:04
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 8408
Generator:
Coding: 8303
2 Faults Found:
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 21
Mileage: 141160 km
Date: 2022.05.14
Time: 14:45:19
Motor status: 01
KFC: 4F
KFA: 00 04
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 21
Mileage: 141160 km
Date: 2022.05.14
Time: 14:45:19
Motor status: 01
KFC: 4D
KFA: 00 04
1 Fault Found:
13705985 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 84
Reset counter: 236
Mileage: 141160 km
Date: 2022.05.14
Time: 14:24:57
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 21
Mileage: 141360 km
Date: 2022.05.20
Time: 19:57:47
Freeze Frame:
Fault Priority: 3
Fault Frequency: 88
Reset counter: 236
Mileage: 141066 km
Date: 2022.05.12
Time: 10:45:33
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 234
Mileage: 141066 km
Date: 2022.05.12
Time: 10:45:34
Hobbes29
05-12-2022 03:13 PM
