My key remote doesn't lock or unlock the doors.
I've tried using the Ross tech instructions for re-syncing the remotes but they don't seem to sync. I tried both sets of instructions and couldn't get either one to work.
I've got the Key 1 fault code stored in the ecu. Here is the code:
Address 46: Central Conv.
Part No: 8E0 959 433 BB
Component: Komfortger?t T7B 1612
Coding: 11880
Shop #: WSC 63351
Part No: 8E1959801
Component: T?rsteuer.FS BRM 0205
Part No: 8E1959802E
Component: T?rsteuer.BF BRM 0205
Part No: 8E0959801A
Component: T?rsteuer.HL BRM 0205
Part No: 8E0959802A
Component: T?rsteuer.HR BRM 0205
1 Fault Found:
00955 - Key 1
35-10 - - - Intermittent
Coding: 11880
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
1 Fault Found:
00955 - Key 1
Measuring Block group 007 in the Convenience module
might give you some clues.
Field 1 will be the key number
Field 2 tells you which button it's seeing.
Field 3 tells you which memory positions have a key matched.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
jsvnj2.7t
09-21-2007 11:22 PM
g0speedracer
03-14-2003 03:39 PM
