my question is ..how to perform bassic settings on ecu digifant 1.72?
on the measuring blocks 08 in line 006 field 1,2 apear mixture less than 88 .on the baloon up of the field apear that its seems to be between 88 and 166. how i can to change the value? thank and ssory for my bad english
"digifant 1.72" doesn't tell us much of anything.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
engine code AAF. i have one more question about it ...there in 3 field on the same group is IDLE AIR CONTROl learned value 40 ,it must be max 30 how can i change it? tell me how can i reset the ecu and write the new corect values values ? thanks
thak you for advice . is it the way to reset the ecu like diskonect the cables and touch them? but when i open basic settings and run chanel 000 for awhile then open measuring 08 in 006 the values increase to 100 but idle control doesnt change still in 40. can i damage something ,do i something wrong? is it usualy posible to regulate the idle valve or fuel mixture with vag com . my vag version is new ....607.3release
ECU question- if I unplug the ECU on my A3 for 30 minutes, will it reset the ECU and clear any codes
allegro
01-19-2008 07:02 PM
Big Nodge
09-11-2003 12:42 PM
JoeyJoJoeJrShabadoo
03-31-2003 08:39 AM
Wakeboarder_Boy
09-16-2002 10:58 AM
