NAV + Airbag: Internal Control Module Error?
I am using HEX-USB with release 805. Car is a 2000 A4 2.8 Q M.
I found the below two fault codes after a scan. The first is expected as I have an Airbag light in the dashboard. I understand that this code generally means replacement of the airbag module is required.
The second code I can't explain because the Navigation system is functional. Has anyone seen the 65535 error in relation to the Nav? Could it be somehow linked to the Airbag error?
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 0002
Coding: 00304
Shop #: WSC 06335
1 Fault Found:
<b>65535 - Internal Control Module Memory Error
00-10 - - - Intermittent</b>
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 A
Component: Navigation 0001
1 Fault Found:
00-00 - -</b>
Coding: 00304
Shop #: WSC 06335
1 Fault Found:
1 Fault Found:
00-00 - -</b>
before but they worked fine. I would clear that and ignore it.
Shouldn't be any relation to the airbag.
Bob
Bob
roughyear
01-10-2009 11:13 AM
