Need Help....
The following is the code:
Address 01: Engine
Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0004
Coding: 0016581
Shop #: WSC 63351
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - MIL ON
Readiness: 0000 0000
Based on STFA, I have printed out the Boost Pressure and Vaccum Regulation diagram from Bentley and will be checking for any leaks in the hoses this weekend. Any additional recommendations as to whatelse to look for?
I have some additional non-related codes which I will cover in another posting.
Address 01: Engine
Coding: 0016581
Shop #: WSC 63351
1 Fault Found:
Ok, I am very new at this... Just received the USB interface last night. I guess what I need to do is go to "Measuring Block" and type 115 for group, click "Go" and then "Log" data from 2k to redline while the car is running and parked? Sorry, if I sound too amateur. Thanks for your help.
In the highest gear possible. 2nd is OK, 3rd is better.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Friday,27,October,2006,15:47:35
8E0 909 518 AK,,1.8L R4/5VT G 0004,
,Group A:,'115,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure,,,,,,,,,,
,TIME,(G28),,(specified),(actual),TIME,,,,,TIME,,, ,
Marker,STAMP, /min, %, mbar, mbar,STAMP,,,,,STAMP,,,,
,0.10,720,26.3,1000.0,1000.0,,,,,,,,,,
,0.28,720,26.3,1000.0,1000.0,,,,,,,,,,
,0.45,720,26.3,1000.0,1000.0,,,,,,,,,,
,0.62,720,26.3,1000.0,1000.0,,,,,,,,,,
,0.79,720,26.3,1000.0,1000.0,,,,,,,,,,
,0.96,720,27.1,1000.0,1000.0,,,,,,,,,,
,1.14,720,27.1,1000.0,1000.0,,,,,,,,,,
,1.31,720,27.1,1000.0,1000.0,,,,,,,,,,
,1.48,720,27.1,1000.0,1000.0,,,,,,,,,,
,1.65,720,27.1,1000.0,1000.0,,,,,,,,,,
,1.82,720,27.1,1000.0,1000.0,,,,,,,,,,
,1.99,720,26.3,1000.0,1000.0,,,,,,,,,,
,2.17,720,27.1,1000.0,1000.0,,,,,,,,,,
,2.34,720,26.3,1000.0,1000.0,,,,,,,,,,
,2.51,720,26.3,1000.0,1000.0,,,,,,,,,,
,2.68,720,26.3,1000.0,1000.0,,,,,,,,,,
,2.85,720,27.1,1000.0,1000.0,,,,,,,,,,
,3.03,720,27.1,1000.0,1000.0,,,,,,,,,,
,3.20,720,27.1,1000.0,1000.0,,,,,,,,,,
,3.37,720,27.1,1000.0,1000.0,,,,,,,,,,
,3.54,720,27.1,1000.0,1000.0,,,,,,,,,,
,3.71,720,27.1,1000.0,1000.0,,,,,,,,,,
,3.88,720,27.1,1000.0,1000.0,,,,,,,,,,
,4.06,720,27.1,1000.0,1000.0,,,,,,,,,,
,4.23,720,26.3,1000.0,1000.0,,,,,,,,,,
,4.40,720,26.3,1000.0,1000.0,,,,,,,,,,
,4.57,720,26.3,1000.0,1000.0,,,,,,,,,,
,4.74,720,27.1,1000.0,1000.0,,,,,,,,,,
,4.92,720,27.1,1000.0,1000.0,,,,,,,,,,
,5.09,720,27.1,1000.0,1000.0,,,,,,,,,,
,5.26,720,27.1,1000.0,1000.0,,,,,,,,,,
,5.43,720,26.3,1000.0,1000.0,,,,,,,,,,
,5.61,720,26.3,1000.0,1000.0,,,,,,,,,,
,5.78,720,26.3,1000.0,1000.0,,,,,,,,,,
,5.95,720,26.3,1000.0,1000.0,,,,,,,,,,
,6.12,720,26.3,1000.0,1000.0,,,,,,,,,,
,6.29,720,26.3,1000.0,1000.0,,,,,,,,,,
,6.46,720,26.3,1000.0,1000.0,,,,,,,,,,
,6.63,720,26.3,1000.0,1000.0,,,,,,,,,,
,6.81,720,26.3,1000.0,1000.0,,,,,,,,,,
,6.98,720,26.3,1000.0,1000.0,,,,,,,,,,
,7.15,720,26.3,1000.0,1000.0,,,,,,,,,,
,7.32,720,26.3,1000.0,1000.0,,,,,,,,,,
,7.49,720,26.3,1000.0,1000.0,,,,,,,,,,
,7.67,720,26.3,1000.0,1000.0,,,,,,,,,,
,7.84,720,26.3,1000.0,1000.0,,,,,,,,,,
,8.01,720,26.3,1000.0,1000.0,,,,,,,,,,
,8.18,720,26.3,1000.0,1000.0,,,,,,,,,,
,8.35,720,26.3,1000.0,1000.0,,,,,,,,,,
,8.53,720,26.3,1000.0,1000.0,,,,,,,,,,
,8.70,720,26.3,1000.0,1000.0,,,,,,,,,,
,8.87,720,26.3,1000.0,1000.0,,,,,,,,,,
,9.04,720,26.3,1000.0,1000.0,,,,,,,,,,
,9.21,720,26.3,1000.0,1000.0,,,,,,,,,,
,9.39,720,26.3,1000.0,1000.0,,,,,,,,,,
,9.56,720,26.3,1000.0,1000.0,,,,,,,,,,
,9.73,720,26.3,1000.0,1000.0,,,,,,,,,,
,9.90,720,26.3,1000.0,1000.0,,,,,,,,,,
,10.07,720,26.3,1000.0,1000.0,,,,,,,,,,
,10.25,720,26.3,1000.0,1000.0,,,,,,,,,,
,10.42,720,29.3,1000.0,1000.0,,,,,,,,,,
,10.59,760,62.4,1320.0,990.0,,,,,,,,,,
,10.76,1240,65.4,1350.0,990.0,,,,,,,,,,
,10.93,1800,67.7,1610.0,970.0,,,,,,,,,,
,11.10,2120,68.4,1800.0,960.0,,,,,,,,,,
,11.28,2240,67.7,1770.0,960.0,,,,,,,,,,
,11.45,2360,66.9,1750.0,960.0,,,,,,,,,,
,11.62,2440,66.2,1730.0,950.0,,,,,,,,,,
,11.79,2480,67.7,1720.0,950.0,,,,,,,,,,
,11.96,2520,66.9,1720.0,950.0,,,,,,,,,,
,12.14,2560,67.7,1690.0,940.0,,,,,,,,,,
,12.31,2560,67.7,1690.0,950.0,,,,,,,,,,
,12.48,2600,68.4,1680.0,950.0,,,,,,,,,,
,12.65,2680,68.4,1670.0,940.0,,,,,,,,,,
,12.82,2800,69.2,1660.0,930.0,,,,,,,,,,
,12.99,2880,69.2,1650.0,930.0,,,,,,,,,,
,13.17,2960,69.9,1640.0,930.0,,,,,,,,,,
,13.34,3040,69.9,1630.0,920.0,,,,,,,,,,
,13.51,3120,69.9,1650.0,920.0,,,,,,,,,,
,13.68,3200,69.2,1650.0,920.0,,,,,,,,,,
,13.85,3320,69.2,1650.0,920.0,,,,,,,,,,
,14.03,3520,67.7,1650.0,910.0,,,,,,,,,,
,14.20,3640,66.9,1650.0,900.0,,,,,,,,,,
,14.37,3800,66.2,1640.0,900.0,,,,,,,,,,
,14.54,3960,64.7,1650.0,900.0,,,,,,,,,,
,14.71,4080,59.4,1650.0,910.0,,,,,,,,,,
,14.89,4200,58.6,1640.0,910.0,,,,,,,,,,
,15.06,4320,57.1,1640.0,910.0,,,,,,,,,,
,15.23,4440,57.1,1630.0,920.0,,,,,,,,,,
,15.40,4560,55.6,1630.0,920.0,,,,,,,,,,
,15.57,4640,54.9,1630.0,930.0,,,,,,,,,,
,15.74,4760,53.4,1620.0,930.0,,,,,,,,,,
,15.92,4840,51.9,1630.0,930.0,,,,,,,,,,
,16.09,4960,51.9,1630.0,930.0,,,,,,,,,,
,16.26,5040,50.4,1620.0,930.0,,,,,,,,,,
,16.43,5080,48.9,1610.0,930.0,,,,,,,,,,
,16.60,5160,47.4,1590.0,940.0,,,,,,,,,,
,16.78,5240,45.9,1570.0,940.0,,,,,,,,,,
,16.95,5280,44.4,1550.0,940.0,,,,,,,,,,
,17.12,5360,42.9,1540.0,950.0,,,,,,,,,,
,17.29,5400,42.1,1530.0,950.0,,,,,,,,,,
,17.47,5440,41.4,1530.0,950.0,,,,,,,,,,
,17.64,5480,59.4,1540.0,950.0,,,,,,,,,,
,17.81,5400,70.7,1550.0,950.0,,,,,,,,,,
,17.98,5400,48.9,1530.0,950.0,,,,,,,,,,
,18.15,5360,68.4,1530.0,950.0,,,,,,,,,,
,18.32,5120,62.4,1550.0,950.0,,,,,,,,,,
,18.50,5520,46.6,1520.0,950.0,,,,,,,,,,
,18.67,5480,68.4,1510.0,950.0,,,,,,,,,,
,18.84,5280,72.9,1540.0,950.0,,,,,,,,,,
,19.01,5240,73.7,1550.0,950.0,,,,,,,,,,
,19.18,5400,73.7,1530.0,950.0,,,,,,,,,,
,19.35,5600,72.9,1530.0,950.0,,,,,,,,,,
,19.53,5480,73.7,1500.0,950.0,,,,,,,,,,
,19.70,5480,72.9,1510.0,960.0,,,,,,,,,,
,19.87,5520,73.7,1500.0,960.0,,,,,,,,,,
,20.04,5520,72.9,1490.0,960.0,,,,,,,,,,
,20.22,5520,72.9,1490.0,960.0,,,,,,,,,,
,20.38,5560,72.9,1500.0,960.0,,,,,,,,,,
,20.56,5560,72.9,1500.0,960.0,,,,,,,,,,
,20.73,5560,72.9,1500.0,960.0,,,,,,,,,,
,20.90,5560,72.9,1500.0,960.0,,,,,,,,,,
,21.07,5560,72.9,1500.0,960.0,,,,,,,,,,
,21.25,5560,72.9,1500.0,960.0,,,,,,,,,,
,21.42,5560,72.9,1000.0,960.0,,,,,,,,,,
,21.59,5280,52.6,1000.0,950.0,,,,,,,,,,
,21.76,5120,22.6,1000.0,990.0,,,,,,,,,,
,21.93,4880,14.3,1000.0,1000.0,,,,,,,,,,
,22.11,4840,27.8,1000.0,980.0,,,,,,,,,,
,22.28,4840,46.6,1000.0,930.0,,,,,,,,,,
,22.45,4800,63.9,1240.0,920.0,,,,,,,,,,
,22.62,4800,68.4,1390.0,930.0,,,,,,,,,,
,22.79,4760,71.4,1530.0,930.0,,,,,,,,,,
,22.97,4680,72.9,1620.0,940.0,,,,,,,,,,
,23.14,4320,61.7,1630.0,940.0,,,,,,,,,,
,23.31,4080,54.9,1620.0,940.0,,,,,,,,,,
,23.48,4000,55.6,1630.0,940.0,,,,,,,,,,
,23.65,3920,56.4,1630.0,940.0,,,,,,,,,,
,23.82,3880,56.4,1640.0,930.0,,,,,,,,,,
,24.00,3920,56.4,1660.0,930.0,,,,,,,,,,
,24.17,4280,54.1,1640.0,940.0,,,,,,,,,,
,24.34,4640,50.4,1630.0,940.0,,,,,,,,,,
,24.51,4760,48.1,1620.0,950.0,,,,,,,,,,
,24.68,4880,45.9,1620.0,950.0,,,,,,,,,,
,24.86,4960,43.6,1600.0,950.0,,,,,,,,,,
,25.03,5040,42.9,1590.0,950.0,,,,,,,,,,
,25.20,5080,42.1,1580.0,950.0,,,,,,,,,,
,25.37,5120,41.4,1570.0,950.0,,,,,,,,,,
,25.54,5160,63.9,1590.0,950.0,,,,,,,,,,
,25.71,5080,72.2,1600.0,950.0,,,,,,,,,,
,25.89,5120,73.7,1570.0,950.0,,,,,,,,,,
,26.06,5120,73.7,1560.0,950.0,,,,,,,,,,
,26.23,5200,73.7,1560.0,960.0,,,,,,,,,,
,26.40,5200,73.7,1550.0,960.0,,,,,,,,,,
,26.57,5240,73.7,1540.0,960.0,,,,,,,,,,
,26.74,5280,73.7,1540.0,960.0,,,,,,,,,,
,26.91,5320,72.9,1530.0,960.0,,,,,,,,,,
,27.07,5320,73.7,1530.0,960.0,,,,,,,,,,
,27.25,5360,73.7,1520.0,960.0,,,,,,,,,,
,27.42,5360,72.9,1520.0,960.0,,,,,,,,,,
,27.59,5400,73.7,1520.0,960.0,,,,,,,,,,
,27.76,5400,72.9,1510.0,960.0,,,,,,,,,,
,27.93,5440,73.7,1510.0,960.0,,,,,,,,,,
,28.11,5440,72.9,1510.0,960.0,,,,,,,,,,
,28.28,5440,72.9,1510.0,960.0,,,,,,,,,,
,28.45,5480,72.9,1510.0,960.0,,,,,,,,,,
,28.62,5480,72.9,1510.0,960.0,,,,,,,,,,
,28.79,5480,72.9,1500.0,960.0,,,,,,,,,,
,28.97,5520,72.9,1510.0,960.0,,,,,,,,,,
,29.14,5520,72.9,1500.0,960.0,,,,,,,,,,
,29.31,5520,72.9,1510.0,960.0,,,,,,,,,,
,29.48,5520,72.9,1500.0,960.0,,,,,,,,,,
,29.65,5520,72.9,1500.0,960.0,,,,,,,,,,
,29.83,5560,72.9,1500.0,960.0,,,,,,,,,,
,30.00,5520,72.9,1510.0,960.0,,,,,,,,,,
,30.17,5480,72.9,1000.0,960.0,,,,,,,,,,
,30.34,5440,39.8,1000.0,970.0,,,,,,,,,,
,30.51,5160,17.3,1000.0,990.0,,,,,,,,,,
,30.68,5120,34.6,1000.0,950.0,,,,,,,,,,
,30.85,5120,64.7,1240.0,930.0,,,,,,,,,,
,31.03,5000,69.9,1420.0,950.0,,,,,,,,,,
,31.20,4600,72.9,1610.0,950.0,,,,,,,,,,
,31.37,4280,73.7,1610.0,950.0,,,,,,,,,,
,31.54,4160,73.7,1600.0,950.0,,,,,,,,,,
,31.72,4040,73.7,1600.0,950.0,,,,,,,,,,
,31.89,3960,57.9,1610.0,950.0,,,,,,,,,,
,32.06,4000,54.1,1600.0,950.0,,,,,,,,,,
,32.23,4040,53.4,1610.0,950.0,,,,,,,,,,
,32.40,4400,50.4,1620.0,950.0,,,,,,,,,,
,32.58,4720,46.6,1600.0,950.0,,,,,,,,,,
,32.75,4800,44.4,1600.0,950.0,,,,,,,,,,
,32.92,4920,42.1,1600.0,950.0,,,,,,,,,,
,33.09,5000,57.1,1600.0,960.0,,,,,,,,,,
,33.26,4960,70.7,1610.0,960.0,,,,,,,,,,
,33.43,5000,73.7,1600.0,960.0,,,,,,,,,,
,33.61,5040,73.7,1590.0,960.0,,,,,,,,,,
,33.78,5080,73.7,1580.0,960.0,,,,,,,,,,
,33.95,5120,73.7,1570.0,960.0,,,,,,,,,,
,34.12,5160,73.7,1570.0,960.0,,,,,,,,,,
,34.29,5200,73.7,1560.0,960.0,,,,,,,,,,
,34.47,5240,73.7,1550.0,960.0,,,,,,,,,,
,34.64,5240,73.7,1550.0,960.0,,,,,,,,,,
,34.81,5280,73.7,1550.0,960.0,,,,,,,,,,
,34.98,5280,73.7,1540.0,960.0,,,,,,,,,,
,35.15,5320,73.7,1540.0,960.0,,,,,,,,,,
,35.32,5320,73.7,1540.0,960.0,,,,,,,,,,
,35.49,5360,73.7,1530.0,960.0,,,,,,,,,,
,35.66,5360,73.7,1530.0,960.0,,,,,,,,,,
,35.83,5400,73.7,1530.0,960.0,,,,,,,,,,
,36.00,5400,73.7,1530.0,960.0,,,,,,,,,,
,36.17,5400,72.9,1520.0,960.0,,,,,,,,,,
,36.35,5440,73.7,1520.0,960.0,,,,,,,,,,
,36.53,5480,72.9,1510.0,960.0,,,,,,,,,,
,36.70,5480,73.7,1510.0,960.0,,,,,,,,,,
,36.86,5480,72.9,1520.0,960.0,,,,,,,,,,
,37.03,5480,72.9,1510.0,960.0,,,,,,,,,,
,37.21,5520,72.9,1500.0,960.0,,,,,,,,,,
,37.38,5520,73.7,1490.0,960.0,,,,,,,,,,
,37.55,5560,73.7,1490.0,960.0,,,,,,,,,,
,37.73,5520,73.7,1490.0,960.0,,,,,,,,,,
,37.89,5520,73.7,1490.0,960.0,,,,,,,,,,
,38.07,5560,73.7,1500.0,960.0,,,,,,,,,,
,38.24,5560,73.7,1500.0,960.0,,,,,,,,,,
,38.41,5560,72.9,1500.0,960.0,,,,,,,,,,
,38.58,5560,73.7,1500.0,960.0,,,,,,,,,,
,38.75,5600,73.7,1500.0,960.0,,,,,,,,,,
,38.92,5600,73.7,1500.0,960.0,,,,,,,,,,
,39.10,5640,72.9,1500.0,960.0,,,,,,,,,,
,39.27,5600,73.7,1500.0,960.0,,,,,,,,,,
,39.44,5640,73.7,1500.0,960.0,,,,,,,,,,
,39.61,5640,72.9,1490.0,960.0,,,,,,,,,,
,39.78,5640,73.7,1490.0,960.0,,,,,,,,,,
,39.96,5640,73.7,1490.0,960.0,,,,,,,,,,
,40.13,5640,73.7,1490.0,960.0,,,,,,,,,,
,40.30,5640,73.7,1490.0,960.0,,,,,,,,,,
,40.47,5640,73.7,1490.0,960.0,,,,,,,,,,
,40.64,5680,72.9,1490.0,960.0,,,,,,,,,,
,40.82,5640,72.9,1490.0,960.0,,,,,,,,,,
,40.99,5640,72.9,1490.0,960.0,,,,,,,,,,
,41.16,5640,72.9,1490.0,960.0,,,,,,,,,,
,41.33,5680,73.7,1490.0,960.0,,,,,,,,,,
,41.50,5680,72.9,1490.0,960.0,,,,,,,,,,
,41.69,5680,72.9,1490.0,960.0,,,,,,,,,,
,41.85,5680,72.9,1490.0,960.0,,,,,,,,,,
,42.02,5680,72.9,1490.0,960.0,,,,,,,,,,
,42.19,5680,73.7,1490.0,960.0,,,,,,,,,,
,42.36,5640,70.7,1000.0,960.0,,,,,,,,,,
,42.53,5560,28.6,1000.0,990.0,,,,,,,,,,
,42.71,5320,17.3,1000.0,990.0,,,,,,,,,,
,42.88,5280,36.8,1000.0,940.0,,,,,,,,,,
,43.05,5200,66.2,1210.0,940.0,,,,,,,,,,
,43.22,4960,69.9,1400.0,950.0,,,,,,,,,,
,43.39,4720,72.9,1560.0,950.0,,,,,,,,,,
,43.56,4560,73.7,1540.0,950.0,,,,,,,,,,
,43.75,4480,73.7,1550.0,950.0,,,,,,,,,,
,43.91,4440,74.4,1560.0,950.0,,,,,,,,,,
,44.08,4400,51.9,1550.0,950.0,,,,,,,,,,
,44.25,4400,47.4,1560.0,950.0,,,,,,,,,,
,44.43,4440,47.4,1570.0,950.0,,,,,,,,,,
,44.60,4440,46.6,1570.0,950.0,,,,,,,,,,
,44.77,4440,46.6,1590.0,950.0,,,,,,,,,,
,44.94,4400,47.4,1590.0,950.0,,,,,,,,,,
,45.11,4400,47.4,1610.0,950.0,,,,,,,,,,
,45.28,4440,47.4,1610.0,950.0,,,,,,,,,,
,45.46,4440,46.6,1610.0,950.0,,,,,,,,,,
,45.63,4440,46.6,1620.0,950.0,,,,,,,,,,
,45.80,4480,46.6,1620.0,950.0,,,,,,,,,,
,45.97,4480,45.9,1620.0,950.0,,,,,,,,,,
,46.14,4520,45.1,1610.0,950.0,,,,,,,,,,
,46.32,4520,45.1,1610.0,960.0,,,,,,,,,,
,46.49,4560,45.1,1610.0,960.0,,,,,,,,,,
,46.66,4560,45.1,1610.0,960.0,,,,,,,,,,
,46.83,4600,44.4,1610.0,960.0,,,,,,,,,,
,47.00,4600,44.4,1610.0,960.0,,,,,,,,,,
,47.18,4640,44.4,1610.0,960.0,,,,,,,,,,
,47.35,4640,43.6,1600.0,960.0,,,,,,,,,,
,47.52,4640,43.6,1610.0,960.0,,,,,,,,,,
,47.69,4680,43.6,1600.0,960.0,,,,,,,,,,
,47.86,4680,42.9,1610.0,960.0,,,,,,,,,,
,48.03,4720,43.6,1610.0,960.0,,,,,,,,,,
,48.21,4720,47.4,1610.0,960.0,,,,,,,,,,
,48.38,4680,59.4,1610.0,960.0,,,,,,,,,,
,48.55,4720,54.9,1600.0,960.0,,,,,,,,,,
,48.72,4680,70.7,1610.0,960.0,,,,,,,,,,
,48.90,4640,48.9,1600.0,960.0,,,,,,,,,,
,49.07,4720,62.4,1600.0,960.0,,,,,,,,,,
,49.24,4680,72.2,1600.0,960.0,,,,,,,,,,
,49.41,4720,45.1,1590.0,960.0,,,,,,,,,,
,49.58,4840,65.4,1590.0,960.0,,,,,,,,,,
,49.75,4680,72.9,1600.0,960.0,,,,,,,,,,
,49.93,4640,74.4,1590.0,960.0,,,,,,,,,,
,50.10,4760,74.4,1600.0,960.0,,,,,,,,,,
,50.27,4840,74.4,1590.0,960.0,,,,,,,,,,
,50.44,4880,74.4,1590.0,960.0,,,,,,,,,,
,50.61,4920,74.4,1580.0,960.0,,,,,,,,,,
,50.78,4920,74.4,1580.0,960.0,,,,,,,,,,
,50.96,4960,74.4,1580.0,960.0,,,,,,,,,,
,51.13,4960,74.4,1580.0,960.0,,,,,,,,,,
,51.30,4960,74.4,1580.0,960.0,,,,,,,,,,
,51.47,5000,74.4,1570.0,960.0,,,,,,,,,,
,51.64,5000,74.4,1570.0,960.0,,,,,,,,,,
,51.82,5000,74.4,1570.0,960.0,,,,,,,,,,
,51.99,5040,74.4,1570.0,960.0,,,,,,,,,,
,52.16,5040,74.4,1570.0,960.0,,,,,,,,,,
,52.33,5040,74.4,1560.0,960.0,,,,,,,,,,
,52.50,5080,74.4,1560.0,960.0,,,,,,,,,,
,52.68,5080,74.4,1560.0,960.0,,,,,,,,,,
,52.85,5080,74.4,1560.0,960.0,,,,,,,,,,
,53.02,5080,73.7,1560.0,960.0,,,,,,,,,,
,53.19,5120,74.4,1560.0,960.0,,,,,,,,,,
,53.36,5120,74.4,1550.0,960.0,,,,,,,,,,
,53.54,5120,73.7,1550.0,960.0,,,,,,,,,,
,53.71,5160,73.7,1550.0,960.0,,,,,,,,,,
,53.88,5160,74.4,1550.0,960.0,,,,,,,,,,
,54.05,5160,74.4,1550.0,960.0,,,,,,,,,,
,54.22,5160,73.7,1550.0,960.0,,,,,,,,,,
,54.40,5160,73.7,1550.0,960.0,,,,,,,,,,
,54.57,5160,73.7,1540.0,960.0,,,,,,,,,,
,54.74,5200,73.7,1540.0,960.0,,,,,,,,,,
,54.91,5200,73.7,1540.0,960.0,,,,,,,,,,
,55.08,5200,73.7,1550.0,960.0,,,,,,,,,,
,55.25,5240,73.7,1550.0,960.0,,,,,,,,,,
,55.43,5240,73.7,1550.0,960.0,,,,,,,,,,
,55.60,5200,73.7,1550.0,960.0,,,,,,,,,,
,55.77,5200,74.4,1550.0,960.0,,,,,,,,,,
,55.94,5240,73.7,1550.0,960.0,,,,,,,,,,
,56.11,5240,73.7,1540.0,960.0,,,,,,,,,,
,56.29,5240,73.7,1540.0,960.0,,,,,,,,,,
,56.46,5280,73.7,1540.0,960.0,,,,,,,,,,
,56.63,5280,73.7,1530.0,960.0,,,,,,,,,,
,56.80,5280,73.7,1540.0,960.0,,,,,,,,,,
,56.97,5280,73.7,1530.0,960.0,,,,,,,,,,
,57.15,5280,73.7,1530.0,960.0,,,,,,,,,,
,57.32,5320,73.7,1530.0,960.0,,,,,,,,,,
,57.49,5320,73.7,1530.0,960.0,,,,,,,,,,
,57.66,5360,73.7,1530.0,960.0,,,,,,,,,,
,57.83,5320,73.7,1520.0,960.0,,,,,,,,,,
,58.00,5360,73.7,1520.0,960.0,,,,,,,,,,
,58.18,5360,73.7,1520.0,960.0,,,,,,,,,,
,58.35,5360,73.7,1520.0,960.0,,,,,,,,,,
,58.52,5400,73.7,1520.0,960.0,,,,,,,,,,
,58.69,5400,73.7,1510.0,960.0,,,,,,,,,,
,58.86,5360,73.7,1510.0,960.0,,,,,,,,,,
,59.04,5400,73.7,1520.0,960.0,,,,,,,,,,
,59.21,5400,73.7,1520.0,960.0,,,,,,,,,,
,59.37,5360,73.7,1520.0,960.0,,,,,,,,,,
,59.54,5400,73.7,1520.0,960.0,,,,,,,,,,
,59.70,5400,73.7,1510.0,960.0,,,,,,,,,,
,59.86,5400,73.7,1510.0,960.0,,,,,,,,,,
,60.04,5400,73.7,1510.0,960.0,,,,,,,,,,
,60.21,5400,73.7,1510.0,960.0,,,,,,,,,,
,60.38,5440,73.7,1510.0,960.0,,,,,,,,,,
,60.55,5400,73.7,1510.0,960.0,,,,,,,,,,
,60.72,5440,73.7,1500.0,960.0,,,,,,,,,,
,60.90,5480,73.7,1510.0,960.0,,,,,,,,,,
,61.07,5440,73.7,1500.0,960.0,,,,,,,,,,
,61.24,5440,73.7,1500.0,960.0,,,,,,,,,,
,61.41,5480,73.7,1510.0,960.0,,,,,,,,,,
,61.58,5440,73.7,1510.0,960.0,,,,,,,,,,
,61.75,5480,73.7,1500.0,960.0,,,,,,,,,,
,61.93,5480,73.7,1500.0,960.0,,,,,,,,,,
,62.10,5480,73.7,1500.0,960.0,,,,,,,,,,
,62.27,5440,73.7,1500.0,960.0,,,,,,,,,,
,62.44,5480,73.7,1490.0,960.0,,,,,,,,,,
,62.62,5480,73.7,1500.0,960.0,,,,,,,,,,
,62.79,5480,73.7,1500.0,960.0,,,,,,,,,,
,62.96,5480,74.4,1500.0,960.0,,,,,,,,,,
,63.13,5480,73.7,1500.0,960.0,,,,,,,,,,
,63.30,5480,74.4,1000.0,960.0,,,,,,,,,,
,63.47,5360,45.1,1000.0,970.0,,,,,,,,,,
,63.64,5240,18.0,1000.0,990.0,,,,,,,,,,
,63.82,5000,16.5,1000.0,980.0,,,,,,,,,,
,63.99,4880,24.1,1000.0,980.0,,,,,,,,,,
,64.16,4800,50.4,1000.0,930.0,,,,,,,,,,
,64.33,4760,60.2,1000.0,940.0,,,,,,,,,,
,64.51,4440,63.2,1140.0,950.0,,,,,,,,,,
,64.68,4320,69.2,1280.0,950.0,,,,,,,,,,
,64.85,4080,69.9,1080.0,950.0,,,,,,,,,,
,65.02,3960,63.9,1530.0,950.0,,,,,,,,,,
,65.19,4080,54.1,1620.0,950.0,,,,,,,,,,
,65.37,4240,51.9,1620.0,950.0,,,,,,,,,,
,65.54,4280,50.4,1630.0,950.0,,,,,,,,,,
,65.71,4280,49.6,1630.0,950.0,,,,,,,,,,
,65.88,4320,49.6,1630.0,950.0,,,,,,,,,,
,66.05,4360,48.9,1630.0,950.0,,,,,,,,,,
,66.22,4560,46.6,1620.0,950.0,,,,,,,,,,
,66.40,4760,43.6,1610.0,960.0,,,,,,,,,,
,66.57,4880,42.1,1610.0,960.0,,,,,,,,,,
,66.74,4920,61.7,1610.0,960.0,,,,,,,,,,
,66.91,4920,72.2,1600.0,960.0,,,,,,,,,,
,67.08,4960,73.7,1600.0,960.0,,,,,,,,,,
,67.26,4960,74.4,1460.0,960.0,,,,,,,,,,
,67.43,4880,54.9,1000.0,960.0,,,,,,,,,,
,67.60,4720,41.4,1000.0,960.0,,,,,,,,,,
,67.77,4560,42.1,1000.0,960.0,,,,,,,,,,
,67.94,4360,42.9,1000.0,960.0,,,,,,,,,,
,68.11,4080,44.4,1000.0,960.0,,,,,,,,,,
,68.29,3840,45.1,1000.0,970.0,,,,,,,,,,
,68.46,3760,45.1,1000.0,970.0,,,,,,,,,,
,68.63,3640,48.1,1000.0,970.0,,,,,,,,,,
,68.80,3560,36.8,1000.0,1000.0,,,,,,,,,,
,68.97,3440,20.3,1000.0,1000.0,,,,,,,,,,
,69.15,3360,18.0,1000.0,1000.0,,,,,,,,,,
,69.32,3280,18.0,1000.0,1000.0,,,,,,,,,,
,69.49,3240,17.3,1000.0,1000.0,,,,,,,,,,
,69.66,3240,16.5,1000.0,1000.0,,,,,,,,,,
,69.83,3200,16.5,1000.0,1000.0,,,,,,,,,,
,70.01,3160,16.5,1000.0,1000.0,,,,,,,,,,
,70.18,3120,16.5,1000.0,1000.0,,,,,,,,,,
,70.35,3080,16.5,1000.0,1000.0,,,,,,,,,,
,70.52,3040,16.5,1000.0,1000.0,,,,,,,,,,
,70.69,3000,15.8,1000.0,1000.0,,,,,,,,,,
,70.86,2960,16.5,1000.0,1000.0,,,,,,,,,,
,71.04,2920,16.5,1000.0,1000.0,,,,,,,,,,
,71.20,2880,16.5,1000.0,1000.0,,,,,,,,,,
,71.37,2840,16.5,1000.0,1000.0,,,,,,,,,,
,71.54,2800,16.5,1000.0,1000.0,,,,,,,,,,
,71.70,2760,17.3,1000.0,1000.0,,,,,,,,,,
,71.87,2760,16.5,1000.0,1000.0,,,,,,,,,,
,72.04,2720,16.5,1000.0,1000.0,,,,,,,,,,
,72.21,2640,17.3,1000.0,1000.0,,,,,,,,,,
,72.38,2640,16.5,1000.0,1000.0,,,,,,,,,,
,72.55,2600,16.5,1000.0,1000.0,,,,,,,,,,
,72.73,2560,16.5,1000.0,1000.0,,,,,,,,,,
,72.90,2520,16.5,1000.0,1000.0,,,,,,,,,,
,73.07,2480,16.5,1000.0,1000.0,,,,,,,,,,
,73.24,2440,17.3,1000.0,1000.0,,,,,,,,,,
,73.41,2440,17.3,1000.0,1000.0,,,,,,,,,,
,73.58,2360,17.3,1000.0,1000.0,,,,,,,,,,
,73.76,2320,17.3,1000.0,1000.0,,,,,,,,,,
,73.93,2280,17.3,1000.0,1000.0,,,,,,,,,,
,74.10,2240,17.3,1000.0,1000.0,,,,,,,,,,
,74.27,2200,17.3,1000.0,1000.0,,,,,,,,,,
,74.44,2160,18.0,1000.0,1000.0,,,,,,,,,,
,74.62,2080,18.0,1000.0,1000.0,,,,,,,,,,
,74.79,2040,18.0,1000.0,1000.0,,,,,,,,,,
,74.96,2000,18.0,1000.0,1000.0,,,,,,,,,,
,75.13,1960,17.3,1000.0,1000.0,,,,,,,,,,
,75.30,1920,16.5,1000.0,1000.0,,,,,,,,,,
,75.48,1880,16.5,1000.0,1000.0,,,,,,,,,,
,75.65,1880,18.0,1000.0,1000.0,,,,,,,,,,
,75.82,1920,32.3,1000.0,1000.0,,,,,,,,,,
,75.99,1880,44.4,1000.0,990.0,,,,,,,,,,
,76.16,1960,56.4,1000.0,980.0,,,,,,,,,,
,76.33,1920,56.4,1000.0,980.0,,,,,,,,,,
,76.51,1800,48.1,1000.0,990.0,,,,,,,,,,
,76.68,1720,36.8,1000.0,1000.0,,,,,,,,,,
,76.85,1680,26.3,1000.0,1000.0,,,,,,,,,,
,77.02,1640,20.3,1000.0,1000.0,,,,,,,,,,
,77.19,1640,18.0,1000.0,1000.0,,,,,,,,,,
,77.37,1640,15.8,1000.0,1000.0,,,,,,,,,,
,77.54,1600,17.3,1000.0,1000.0,,,,,,,,,,
,77.71,1560,18.0,1000.0,1000.0,,,,,,,,,,
,77.88,1560,18.8,1000.0,1000.0,,,,,,,,,,
,78.05,1520,19.5,1000.0,1000.0,,,,,,,,,,
,78.23,1520,18.8,1000.0,1000.0,,,,,,,,,,
,78.40,1520,18.0,1000.0,1000.0,,,,,,,,,,
,78.57,1480,17.3,1000.0,1000.0,,,,,,,,,,
,78.74,1440,15.8,1000.0,1000.0,,,,,,,,,,
,78.91,1440,16.5,1000.0,1000.0,,,,,,,,,,
,79.08,1400,17.3,1000.0,1000.0,,,,,,,,,,
,79.26,1440,16.5,1000.0,1000.0,,,,,,,,,,
,79.43,1400,16.5,1000.0,1000.0,,,,,,,,,,
,79.60,1400,16.5,1000.0,1000.0,,,,,,,,,,
,79.77,1360,16.5,1000.0,1000.0,,,,,,,,,,
,79.94,1360,16.5,1000.0,1000.0,,,,,,,,,,
,80.12,1360,17.3,1000.0,1000.0,,,,,,,,,,
,80.29,1320,17.3,1000.0,1000.0,,,,,,,,,,
,80.46,1320,18.8,1000.0,1000.0,,,,,,,,,,
,80.63,1360,21.1,1000.0,1000.0,,,,,,,,,,
,80.80,1280,21.8,1000.0,1000.0,,,,,,,,,,
,80.97,1280,21.1,1000.0,1000.0,,,,,,,,,,
,81.15,1240,21.1,1000.0,1000.0,,,,,,,,,,
,81.32,1200,21.1,1000.0,1000.0,,,,,,,,,,
,81.49,1200,21.1,1000.0,1000.0,,,,,,,,,,
,81.66,1240,24.8,1000.0,1000.0,,,,,,,,,,
,81.83,1200,26.3,1000.0,1000.0,,,,,,,,,,
,82.01,1200,22.6,1000.0,1000.0,,,,,,,,,,
,82.18,1160,21.8,1000.0,1000.0,,,,,,,,,,
,82.35,1160,22.6,1000.0,1000.0,,,,,,,,,,
,82.52,1160,22.6,1000.0,1000.0,,,,,,,,,,
,82.69,1120,22.6,1000.0,1000.0,,,,,,,,,,
,82.87,1120,23.3,1000.0,1000.0,,,,,,,,,,
,83.04,1200,27.1,1000.0,1000.0,,,,,,,,,,
,83.21,1160,27.8,1000.0,1000.0,,,,,,,,,,
,83.38,1160,21.8,1000.0,1000.0,,,,,,,,,,
,83.55,1160,24.8,1000.0,1000.0,,,,,,,,,,
,83.73,1240,35.3,1000.0,1000.0,,,,,,,,,,
,83.90,1240,39.1,1000.0,1000.0,,,,,,,,,,
,84.07,1320,40.6,1000.0,1000.0,,,,,,,,,,
,84.24,1360,40.6,1000.0,1000.0,,,,,,,,,,
,84.41,1400,39.1,1000.0,1000.0,,,,,,,,,,
,84.59,1400,38.3,1000.0,1000.0,,,,,,,,,,
,84.76,1400,32.3,1000.0,1000.0,,,,,,,,,,
,84.93,1280,28.6,1000.0,1000.0,,,,,,,,,,
,85.10,1240,28.6,1000.0,1000.0,,,,,,,,,,
,85.27,1240,33.8,1000.0,1000.0,,,,,,,,,,
,85.45,1280,36.1,1000.0,1000.0,,,,,,,,,,
,85.62,1240,34.6,1000.0,1000.0,,,,,,,,,,
,85.79,1200,33.8,1000.0,1000.0,,,,,,,,,,
,85.96,1200,33.1,1000.0,1000.0,,,,,,,,,,
,86.13,1240,30.8,1000.0,1000.0,,,,,,,,,,
,86.30,1280,28.6,1000.0,1000.0,,,,,,,,,,
,86.47,1320,27.8,1000.0,1000.0,,,,,,,,,,
,86.65,1360,27.1,1000.0,1000.0,,,,,,,,,,
,86.82,1400,26.3,1000.0,1000.0,,,,,,,,,,
,86.99,1400,26.3,1000.0,1000.0,,,,,,,,,,
,87.16,1400,25.6,1000.0,1000.0,,,,,,,,,,
,87.34,1400,22.6,1000.0,1000.0,,,,,,,,,,
,87.51,1400,21.1,1000.0,1000.0,,,,,,,,,,
,87.68,1360,18.8,1000.0,1000.0,,,,,,,,,,
,87.85,1320,18.8,1000.0,1000.0,,,,,,,,,,
,88.02,1280,16.5,1000.0,1000.0,,,,,,,,,,
,88.19,1240,16.5,1000.0,1000.0,,,,,,,,,,
,88.37,1200,17.3,1000.0,1000.0,,,,,,,,,,
,88.54,1160,19.5,1000.0,1000.0,,,,,,,,,,
,88.71,1200,22.6,1000.0,1000.0,,,,,,,,,,
,88.88,1240,22.6,1000.0,1000.0,,,,,,,,,,
,89.05,1240,19.5,1000.0,1000.0,,,,,,,,,,
,89.23,1160,19.5,1000.0,1000.0,,,,,,,,,,
,89.40,1120,21.1,1000.0,1000.0,,,,,,,,,,
,89.57,1120,23.3,1000.0,1000.0,,,,,,,,,,
,89.74,1120,24.8,1000.0,1000.0,,,,,,,,,,
,89.91,1080,25.6,1000.0,1000.0,,,,,,,,,,
,90.09,1080,25.6,1000.0,1000.0,,,,,,,,,,
,90.26,1080,25.6,1000.0,1000.0,,,,,,,,,,
,90.43,1040,26.3,1000.0,1000.0,,,,,,,,,,
,90.60,1040,27.8,1000.0,1000.0,,,,,,,,,,
,90.77,1160,33.1,1000.0,1000.0,,,,,,,,,,
,90.94,1160,34.6,1000.0,1000.0,,,,,,,,,,
,91.12,1120,34.6,1000.0,1000.0,,,,,,,,,,
,91.29,1120,35.3,1000.0,1000.0,,,,,,,,,,
,91.46,1320,52.6,1280.0,990.0,,,,,,,,,,
,91.63,1800,60.2,1410.0,970.0,,,,,,,,,,
,91.80,1920,68.4,1460.0,970.0,,,,,,,,,,
,91.98,1960,69.2,1280.0,970.0,,,,,,,,,,
,92.15,1960,65.4,1180.0,970.0,,,,,,,,,,
,92.32,1920,65.4,1240.0,970.0,,,,,,,,,,
,92.49,1960,65.4,1240.0,970.0,,,,,,,,,,
,92.66,1960,66.2,1480.0,970.0,,,,,,,,,,
,92.84,2080,69.2,1480.0,960.0,,,,,,,,,,
,93.01,2240,67.7,1370.0,960.0,,,,,,,,,,
,93.18,2320,65.4,1100.0,970.0,,,,,,,,,,
,93.35,2480,63.2,1000.0,960.0,,,,,,,,,,
,93.52,2600,62.4,1000.0,960.0,,,,,,,,,,
,93.69,2640,61.7,1000.0,950.0,,,,,,,,,,
,93.87,2440,63.2,1000.0,960.0,,,,,,,,,,
,94.04,2240,64.7,1000.0,970.0,,,,,,,,,,
,94.21,2200,64.7,1000.0,970.0,,,,,,,,,,
,94.38,2240,62.4,1000.0,970.0,,,,,,,,,,
,94.55,2280,60.9,1000.0,970.0,,,,,,,,,,
,94.73,2320,60.2,1000.0,970.0,,,,,,,,,,
,94.90,2360,60.2,1000.0,970.0,,,,,,,,,,
,95.07,2400,60.2,1020.0,960.0,,,,,,,,,,
,95.24,2200,63.9,1100.0,970.0,,,,,,,,,,
,95.41,1920,65.4,1140.0,970.0,,,,,,,,,,
,95.59,1880,65.4,1120.0,970.0,,,,,,,,,,
,95.76,1880,66.9,1150.0,980.0,,,,,,,,,,
,95.93,1880,65.4,1290.0,980.0,,,,,,,,,,
,96.10,1880,66.9,1360.0,970.0,,,,,,,,,,
,96.27,1880,68.4,1370.0,970.0,,,,,,,,,,
,96.45,1920,69.2,1400.0,970.0,,,,,,,,,,
,96.62,1960,69.2,1410.0,970.0,,,,,,,,,,
,96.79,1960,69.2,1410.0,970.0,,,,,,,,,,
,96.96,1920,69.2,1410.0,970.0,,,,,,,,,,
,97.13,1720,69.2,1470.0,980.0,,,,,,,,,,
,97.31,1600,68.4,1520.0,980.0,,,,,,,,,,
,97.48,1600,68.4,1520.0,980.0,,,,,,,,,,
,97.65,1560,68.4,1510.0,980.0,,,,,,,,,,
,97.82,1560,68.4,1510.0,980.0,,,,,,,,,,
,97.99,1560,68.4,1520.0,980.0,,,,,,,,,,
,98.16,1560,69.2,1530.0,980.0,,,,,,,,,,
,98.34,1600,69.2,1540.0,980.0,,,,,,,,,,
,98.51,1600,68.4,1540.0,980.0,,,,,,,,,,
,98.68,1600,68.4,1550.0,980.0,,,,,,,,,,
,98.85,1640,68.4,1560.0,980.0,,,,,,,,,,
,99.02,1640,68.4,1570.0,980.0,,,,,,,,,,
,99.20,1680,67.7,1570.0,980.0,,,,,,,,,,
,99.37,1920,67.7,1590.0,970.0,,,,,,,,,,
,99.54,2280,66.9,1680.0,960.0,,,,,,,,,,
,99.71,2760,66.9,1660.0,940.0,,,,,,,,,,
,99.88,3000,69.2,1600.0,930.0,,,,,,,,,,
,100.06,3240,68.4,1620.0,920.0,,,,,,,,,,
,100.23,3400,67.7,1630.0,910.0,,,,,,,,,,
,100.40,3520,66.2,1640.0,910.0,,,,,,,,,,
,100.57,3640,66.2,1640.0,910.0,,,,,,,,,,
,100.74,3720,65.4,1640.0,910.0,,,,,,,,,,
,100.91,3800,64.7,1640.0,900.0,,,,,,,,,,
,101.09,3880,60.9,1640.0,910.0,,,,,,,,,,
,101.26,3960,57.9,1640.0,910.0,,,,,,,,,,
,101.43,4040,57.9,1640.0,910.0,,,,,,,,,,
,101.60,4080,57.1,1640.0,910.0,,,,,,,,,,
,101.77,4160,57.1,1620.0,920.0,,,,,,,,,,
,101.95,4200,56.4,1620.0,920.0,,,,,,,,,,
,102.12,4240,55.6,1620.0,920.0,,,,,,,,,,
,102.29,4280,55.6,1610.0,930.0,,,,,,,,,,
,102.46,4360,55.6,1610.0,930.0,,,,,,,,,,
,102.63,4400,54.9,1610.0,930.0,,,,,,,,,,
,102.81,4440,54.9,1610.0,930.0,,,,,,,,,,
,102.98,4520,54.1,1610.0,930.0,,,,,,,,,,
,103.15,4560,54.1,1600.0,930.0,,,,,,,,,,
,103.32,4600,53.4,1600.0,930.0,,,,,,,,,,
,103.49,4640,52.6,1600.0,930.0,,,,,,,,,,
,103.66,4680,52.6,1600.0,930.0,,,,,,,,,,
,103.84,4720,51.9,1600.0,930.0,,,,,,,,,,
,104.01,4760,51.1,1600.0,940.0,,,,,,,,,,
,104.18,4800,50.4,1600.0,940.0,,,,,,,,,,
,104.35,4840,49.6,1590.0,940.0,,,,,,,,,,
,104.52,4880,48.9,1590.0,940.0,,,,,,,,,,
,104.70,4920,48.1,1590.0,940.0,,,,,,,,,,
,104.87,4960,47.4,1590.0,940.0,,,,,,,,,,
,105.04,4960,46.6,1590.0,950.0,,,,,,,,,,
,105.21,5000,45.9,1590.0,950.0,,,,,,,,,,
,105.38,5000,45.9,1570.0,950.0,,,,,,,,,,
,105.55,5040,45.1,1570.0,950.0,,,,,,,,,,
,105.72,5080,44.4,1570.0,950.0,,,,,,,,,,
,105.90,5080,43.6,1560.0,950.0,,,,,,,,,,
,106.07,5120,43.6,1560.0,950.0,,,,,,,,,,
,106.24,5120,43.6,1560.0,950.0,,,,,,,,,,
,106.41,5160,42.1,1560.0,950.0,,,,,,,,,,
,106.59,5200,54.9,1550.0,950.0,,,,,,,,,,
,106.76,5120,69.9,1560.0,950.0,,,,,,,,,,
,106.93,5080,72.9,1570.0,950.0,,,,,,,,,,
,107.10,5120,43.6,1560.0,950.0,,,,,,,,,,
,107.27,5200,66.2,1560.0,950.0,,,,,,,,,,
,107.45,4960,72.9,1570.0,950.0,,,,,,,,,,
,107.62,5080,46.6,1580.0,950.0,,,,,,,,,,
,107.79,5240,57.1,1550.0,960.0,,,,,,,,,,
,107.96,5080,69.9,1550.0,960.0,,,,,,,,,,
,108.13,4880,53.4,1590.0,950.0,,,,,,,,,,
,108.31,5120,45.9,1560.0,960.0,,,,,,,,,,
,108.48,5080,68.4,1560.0,960.0,,,,,,,,,,
,108.65,4800,73.7,1580.0,950.0,,,,,,,,,,
,108.82,5040,42.9,1560.0,960.0,,,,,,,,,,
,108.99,5160,62.4,1560.0,960.0,,,,,,,,,,
,109.17,4920,72.2,1570.0,960.0,,,,,,,,,,
,109.34,4840,53.4,1580.0,960.0,,,,,,,,,,
,109.51,5120,54.9,1560.0,960.0,,,,,,,,,,
,109.68,5040,69.9,1560.0,960.0,,,,,,,,,,
,109.85,4880,52.6,1580.0,960.0,,,,,,,,,,
,110.02,5080,61.7,1570.0,960.0,,,,,,,,,,
,110.20,4800,72.2,1570.0,960.0,,,,,,,,,,
,110.37,5000,57.1,1560.0,960.0,,,,,,,,,,
,110.54,4960,71.4,1590.0,960.0,,,,,,,,,,
,110.71,4840,73.7,1580.0,960.0,,,,,,,,,,
,110.88,4800,74.4,1580.0,960.0,,,,,,,,,,
,111.06,5040,74.4,1580.0,960.0,,,,,,,,,,
,111.23,5080,73.7,1560.0,960.0,,,,,,,,,,
,111.40,5080,73.7,1560.0,960.0,,,,,,,,,,
,111.57,5080,73.7,1560.0,960.0,,,,,,,,,,
,111.75,5120,73.7,1560.0,960.0,,,,,,,,,,
,111.92,5120,74.4,1560.0,960.0,,,,,,,,,,
,112.08,5120,73.7,1550.0,960.0,,,,,,,,,,
,112.26,5120,73.7,1550.0,960.0,,,,,,,,,,
,112.43,5160,73.7,1550.0,960.0,,,,,,,,,,
,112.60,5160,73.7,1550.0,960.0,,,,,,,,,,
,112.77,5160,73.7,1550.0,960.0,,,,,,,,,,
,112.95,5160,73.7,1550.0,960.0,,,,,,,,,,
,113.12,5160,73.7,1550.0,960.0,,,,,,,,,,
,113.29,5200,73.7,1550.0,960.0,,,,,,,,,,
,113.46,5200,73.7,1550.0,960.0,,,,,,,,,,
,113.63,5200,73.7,1540.0,960.0,,,,,,,,,,
,113.81,5200,73.7,1540.0,960.0,,,,,,,,,,
,113.98,5200,73.7,1540.0,960.0,,,,,,,,,,
,114.15,5200,73.7,1540.0,960.0,,,,,,,,,,
,114.32,5200,73.7,1540.0,960.0,,,,,,,,,,
,114.49,5240,73.7,1540.0,960.0,,,,,,,,,,
,114.67,5200,73.7,1540.0,960.0,,,,,,,,,,
,114.84,5200,73.7,1540.0,960.0,,,,,,,,,,
,115.01,5240,73.7,1540.0,960.0,,,,,,,,,,
,115.18,5240,73.7,1540.0,960.0,,,,,,,,,,
,115.35,5240,73.7,1530.0,960.0,,,,,,,,,,
,115.53,5240,73.7,1540.0,960.0,,,,,,,,,,
,115.70,5240,73.7,1540.0,960.0,,,,,,,,,,
,115.87,5240,73.7,1540.0,960.0,,,,,,,,,,
,116.04,5240,73.7,1540.0,960.0,,,,,,,,,,
,116.21,5240,73.7,1530.0,960.0,,,,,,,,,,
,116.39,5240,73.7,1530.0,960.0,,,,,,,,,,
,116.55,5240,73.7,1540.0,960.0,,,,,,,,,,
,116.73,5240,73.7,1530.0,960.0,,,,,,,,,,
,116.90,5240,74.4,1530.0,960.0,,,,,,,,,,
,117.07,5240,74.4,1540.0,960.0,,,,,,,,,,
,117.24,5280,74.4,1540.0,960.0,,,,,,,,,,
,117.41,5280,74.4,1540.0,960.0,,,,,,,,,,
,117.59,5240,74.4,1540.0,960.0,,,,,,,,,,
,117.76,5280,74.4,1530.0,960.0,,,,,,,,,,
,117.93,5280,74.4,1540.0,960.0,,,,,,,,,,
,118.10,5280,74.4,1530.0,960.0,,,,,,,,,,
,118.27,5240,74.4,1540.0,960.0,,,,,,,,,,
,118.45,5240,74.4,1540.0,960.0,,,,,,,,,,
,118.62,5240,74.4,1540.0,960.0,,,,,,,,,,
,118.79,5240,74.4,1540.0,960.0,,,,,,,,,,
,118.96,5240,74.4,1540.0,960.0,,,,,,,,,,
,119.14,5240,74.4,1530.0,960.0,,,,,,,,,,
,119.31,5240,74.4,1540.0,960.0,,,,,,,,,,
,119.48,5240,74.4,1540.0,960.0,,,,,,,,,,
,119.65,5240,74.4,1540.0,960.0,,,,,,,,,,
,119.82,5240,74.4,1540.0,960.0,,,,,,,,,,
,119.99,5240,74.4,1530.0,960.0,,,,,,,,,,
,120.17,5240,74.4,1540.0,960.0,,,,,,,,,,
,120.34,5240,74.4,1540.0,960.0,,,,,,,,,,
,120.51,5240,74.4,1540.0,960.0,,,,,,,,,,
,120.68,5240,74.4,1540.0,960.0,,,,,,,,,,
,120.85,5240,74.4,1540.0,960.0,,,,,,,,,,
,121.03,5240,74.4,1540.0,960.0,,,,,,,,,,
,121.20,5240,74.4,1540.0,960.0,,,,,,,,,,
,121.37,5240,74.4,1540.0,960.0,,,,,,,,,,
,121.54,5240,74.4,1540.0,960.0,,,,,,,,,,
,121.71,5240,74.4,1540.0,960.0,,,,,,,,,,
,121.89,5240,74.4,1540.0,960.0,,,,,,,,,,
,122.06,5240,74.4,1540.0,960.0,,,,,,,,,,
,122.23,5240,74.4,1540.0,960.0,,,,,,,,,,
,122.40,5200,74.4,1540.0,960.0,,,,,,,,,,
,122.57,5120,66.2,1000.0,960.0,,,,,,,,,,
,122.74,5120,18.8,1000.0,1000.0,,,,,,,,,,
,122.92,5200,25.6,1000.0,970.0,,,,,,,,,,
,123.09,5280,49.6,1000.0,940.0,,,,,,,,,,
,123.26,5200,68.4,1200.0,950.0,,,,,,,,,,
,123.43,5080,70.7,1220.0,950.0,,,,,,,,,,
,123.60,5040,70.7,1230.0,960.0,,,,,,,,,,
,123.78,4960,66.9,1000.0,960.0,,,,,,,,,,
,123.94,4760,42.1,1000.0,970.0,,,,,,,,,,
,124.11,4560,19.5,1000.0,990.0,,,,,,,,,,
,124.28,4360,24.1,1000.0,990.0,,,,,,,,,,
,124.45,4240,54.9,1090.0,930.0,,,,,,,,,,
,124.63,4040,54.9,1430.0,940.0,,,,,,,,,,
,124.80,3720,57.1,1600.0,930.0,,,,,,,,,,
,124.98,3720,57.1,1620.0,930.0,,,,,,,,,,
,125.14,3720,57.1,1620.0,940.0,,,,,,,,,,
,125.31,3720,56.4,1630.0,930.0,,,,,,,,,,
,125.48,3720,57.1,1640.0,940.0,,,,,,,,,,
,125.67,3840,56.4,1660.0,940.0,,,,,,,,,,
,125.83,4120,54.1,1650.0,940.0,,,,,,,,,,
,126.00,4400,51.9,1620.0,950.0,,,,,,,,,,
,126.17,4600,48.1,1600.0,950.0,,,,,,,,,,
,126.34,4840,45.1,1610.0,950.0,,,,,,,,,,
,126.52,5000,42.1,1610.0,960.0,,,,,,,,,,
,126.69,5160,45.9,1590.0,960.0,,,,,,,,,,
,126.86,5200,67.7,1580.0,960.0,,,,,,,,,,
,127.03,5240,72.9,1570.0,960.0,,,,,,,,,,
,127.20,5280,73.7,1570.0,960.0,,,,,,,,,,
,127.37,5320,73.7,1550.0,960.0,,,,,,,,,,
,127.56,5360,74.4,1550.0,960.0,,,,,,,,,,
,127.72,5360,74.4,1540.0,960.0,,,,,,,,,,
,127.89,5400,74.4,1520.0,960.0,,,,,,,,,,
,128.06,5400,74.4,1520.0,960.0,,,,,,,,,,
,128.24,5400,73.7,1510.0,960.0,,,,,,,,,,
,128.41,5400,74.4,1520.0,960.0,,,,,,,,,,
,128.58,5400,74.4,1520.0,960.0,,,,,,,,,,
,128.75,5400,74.4,1510.0,960.0,,,,,,,,,,
,128.93,5400,74.4,1510.0,960.0,,,,,,,,,,
,129.10,5360,74.4,1520.0,960.0,,,,,,,,,,
,129.27,5400,74.4,1510.0,960.0,,,,,,,,,,
,129.44,5360,74.4,1520.0,960.0,,,,,,,,,,
,129.61,5360,74.4,1520.0,960.0,,,,,,,,,,
,129.78,5360,74.4,1520.0,960.0,,,,,,,,,,
,129.95,5360,73.7,1520.0,960.0,,,,,,,,,,
,130.12,5360,74.4,1520.0,960.0,,,,,,,,,,
,130.30,5360,74.4,1520.0,960.0,,,,,,,,,,
,130.47,5360,74.4,1520.0,960.0,,,,,,,,,,
,130.64,5320,74.4,1000.0,960.0,,,,,,,,,,
,130.81,5200,48.9,1000.0,960.0,,,,,,,,,,
,130.98,5320,16.5,1000.0,990.0,,,,,,,,,,
,131.16,5320,13.5,1000.0,990.0,,,,,,,,,,
,131.33,5240,13.5,1000.0,1000.0,,,,,,,,,,
,131.50,5160,13.5,1000.0,990.0,,,,,,,,,,
,131.67,4920,14.3,1000.0,1000.0,,,,,,,,,,
,131.84,4680,14.3,1000.0,1000.0,,,,,,,,,,
,132.02,4440,14.3,1000.0,1000.0,,,,,,,,,,
,132.19,4240,14.3,1000.0,1000.0,,,,,,,,,,
,132.35,4040,15.0,1000.0,1000.0,,,,,,,,,,
,132.52,3920,18.0,1000.0,1000.0,,,,,,,,,,
,132.69,3640,18.8,1000.0,1000.0,,,,,,,,,,
,132.86,3400,18.0,1000.0,1000.0,,,,,,,,,,
,133.03,3160,18.0,1000.0,1000.0,,,,,,,,,,
,133.20,2920,18.0,1000.0,1000.0,,,,,,,,,,
,133.38,2760,17.3,1000.0,1000.0,,,,,,,,,,
,133.55,2720,17.3,1000.0,1000.0,,,,,,,,,,
,133.72,2640,17.3,1000.0,1000.0,,,,,,,,,,
,133.89,2600,16.5,1000.0,1000.0,,,,,,,,,,
,134.06,2520,17.3,1000.0,1000.0,,,,,,,,,,
,134.24,2480,17.3,1000.0,1000.0,,,,,,,,,,
,134.41,2440,17.3,1000.0,1000.0,,,,,,,,,,
,134.58,2440,17.3,1000.0,1000.0,,,,,,,,,,
,134.75,2400,17.3,1000.0,1000.0,,,,,,,,,,
,134.92,2400,17.3,1000.0,1000.0,,,,,,,,,,
,135.09,2360,17.3,1000.0,1000.0,,,,,,,,,,
,135.27,2360,17.3,1000.0,1000.0,,,,,,,,,,
,135.44,2360,17.3,1000.0,1000.0,,,,,,,,,,
,135.61,2320,17.3,1000.0,1000.0,,,,,,,,,,
,135.78,2320,17.3,1000.0,1000.0,,,,,,,,,,
,135.95,2320,17.3,1000.0,1000.0,,,,,,,,,,
,136.13,2280,17.3,1000.0,1000.0,,,,,,,,,,
,136.30,2280,17.3,1000.0,1000.0,,,,,,,,,,
,136.47,2280,17.3,1000.0,1000.0,,,,,,,,,,
,136.64,2280,17.3,1000.0,1000.0,,,,,,,,,,
,136.81,2240,17.3,1000.0,1000.0,,,,,,,,,,
,136.98,2200,17.3,1000.0,1000.0,,,,,,,,,,
,137.16,2200,17.3,1000.0,1000.0,,,,,,,,,,
,137.33,2160,17.3,1000.0,1000.0,,,,,,,,,,
,137.50,2160,18.0,1000.0,1000.0,,,,,,,,,,
,137.67,2120,17.3,1000.0,1000.0,,,,,,,,,,
,137.84,2120,18.0,1000.0,1000.0,,,,,,,,,,
,138.02,2080,17.3,1000.0,1000.0,,,,,,,,,,
,138.19,2040,17.3,1000.0,1000.0,,,,,,,,,,
,138.36,2040,17.3,1000.0,1000.0,,,,,,,,,,
,138.53,2000,18.0,1000.0,1000.0,,,,,,,,,,
,138.70,1960,18.0,1000.0,1000.0,,,,,,,,,,
,138.88,1920,17.3,1000.0,1000.0,,,,,,,,,,
,139.05,1920,17.3,1000.0,1000.0,,,,,,,,,,
,139.22,1880,17.3,1000.0,1000.0,,,,,,,,,,
,139.39,1840,17.3,1000.0,1000.0,,,,,,,,,,
,139.56,1800,17.3,1000.0,1000.0,,,,,,,,,,
,139.74,1760,17.3,1000.0,1000.0,,,,,,,,,,
,139.91,1720,17.3,1000.0,1000.0,,,,,,,,,,
,140.08,1680,17.3,1000.0,1000.0,,,,,,,,,,
,140.25,1600,17.3,1000.0,1000.0,,,,,,,,,,
,140.42,1560,17.3,1000.0,1000.0,,,,,,,,,,
,140.60,1480,17.3,1000.0,1000.0,,,,,,,,,,
,140.77,1440,17.3,1000.0,1000.0,,,,,,,,,,
,140.94,1400,18.0,1000.0,1000.0,,,,,,,,,,
,141.11,1360,18.0,1000.0,1000.0,,,,,,,,,,
,141.28,1320,18.8,1000.0,1000.0,,,,,,,,,,
,141.46,1240,20.3,1000.0,1000.0,,,,,,,,,,
,141.63,1280,20.3,1000.0,1000.0,,,,,,,,,,
,141.80,1360,19.5,1000.0,1000.0,,,,,,,,,,
,141.97,1400,18.8,1000.0,1000.0,,,,,,,,,,
,142.14,1400,18.8,1000.0,1000.0,,,,,,,,,,
,142.31,1360,18.8,1000.0,1000.0,,,,,,,,,,
,142.49,1360,19.5,1000.0,1000.0,,,,,,,,,,
,142.66,1320,21.8,1000.0,1000.0,,,,,,,,,,
,142.83,1280,22.6,1000.0,1000.0,,,,,,,,,,
,143.00,1240,22.6,1000.0,1000.0,,,,,,,,,,
,143.17,1200,23.3,1000.0,1000.0,,,,,,,,,,
,143.35,1200,25.6,1000.0,1000.0,,,,,,,,,,
,143.52,1240,24.1,1000.0,1000.0,,,,,,,,,,
,143.69,1240,21.1,1000.0,1000.0,,,,,,,,,,
,143.86,1240,20.3,1000.0,1000.0,,,,,,,,,,
,144.03,1200,20.3,1000.0,1000.0,,,,,,,,,,
,144.21,1160,22.6,1000.0,1000.0,,,,,,,,,,
,144.38,1200,24.1,1000.0,1000.0,,,,,,,,,,
,144.55,1200,24.8,1000.0,1000.0,,,,,,,,,,
,144.72,1120,23.3,1000.0,1000.0,,,,,,,,,,
,144.89,1080,24.1,1000.0,1000.0,,,,,,,,,,
,145.06,1120,26.3,1000.0,1000.0,,,,,,,,,,
,145.24,1120,27.1,1000.0,1000.0,,,,,,,,,,
,145.41,1080,25.6,1000.0,1000.0,,,,,,,,,,
,145.58,1040,24.8,1000.0,1000.0,,,,,,,,,,
,145.75,960,22.6,1000.0,1000.0,,,,,,,,,,
,145.92,920,22.6,1000.0,1000.0,,,,,,,,,,
,146.10,880,24.1,1000.0,1000.0,,,,,,,,,,
,146.27,840,26.3,1000.0,1000.0,,,,,,,,,,
,146.44,840,27.8,1000.0,1000.0,,,,,,,,,,
,146.61,840,27.8,1000.0,1000.0,,,,,,,,,,
,146.78,800,27.1,1000.0,1000.0,,,,,,,,,,
,146.96,800,27.8,1000.0,1000.0,,,,,,,,,,
,147.13,800,27.8,1000.0,1000.0,,,,,,,,,,
,147.30,800,27.8,1000.0,1000.0,,,,,,,,,,
,147.47,760,27.8,1000.0,1000.0,,,,,,,,,,
,147.64,760,27.8,1000.0,1000.0,,,,,,,,,,
,147.81,760,27.8,1000.0,1000.0,,,,,,,,,,
,147.99,760,27.8,1000.0,1000.0,,,,,,,,,,
,148.16,760,29.3,1000.0,1000.0,,,,,,,,,,
,148.33,760,28.6,1000.0,1000.0,,,,,,,,,,
,148.50,800,28.6,1000.0,1000.0,,,,,,,,,,
,148.68,760,28.6,1000.0,1000.0,,,,,,,,,,
,148.84,760,28.6,1000.0,1000.0,,,,,,,,,,
,149.02,760,28.6,1000.0,1000.0,,,,,,,,,,
,149.19,760,29.3,1000.0,1000.0,,,,,,,,,,
,149.36,760,29.3,1000.0,1000.0,,,,,,,,,,
,149.53,800,36.8,1000.0,1000.0,,,,,,,,,,
,149.70,880,44.4,1000.0,1000.0,,,,,,,,,,
,149.88,1000,43.6,1000.0,1000.0,,,,,,,,,,
,150.05,880,37.6,1000.0,1000.0,,,,,,,,,,
,150.22,840,38.3,1000.0,1000.0,,,,,,,,,,
,150.39,840,38.3,1000.0,1000.0,,,,,,,,,,
,150.56,800,33.8,1000.0,1000.0,,,,,,,,,,
,150.74,760,30.8,1000.0,1000.0,,,,,,,,,,
,150.91,760,28.6,1000.0,1000.0,,,,,,,,,,
,151.08,760,29.3,1000.0,1000.0,,,,,,,,,,
,151.25,760,30.1,1000.0,1000.0,,,,,,,,,,
,151.42,760,29.3,1000.0,1000.0,,,,,,,,,,
,151.60,760,29.3,1000.0,1000.0,,,,,,,,,,
,151.77,760,29.3,1000.0,1000.0,,,,,,,,,,
,151.94,800,29.3,1000.0,1000.0,,,,,,,,,,
,152.11,800,29.3,1000.0,1000.0,,,,,,,,,,
,152.28,760,29.3,1000.0,1000.0,,,,,,,,,,
,152.46,800,29.3,1000.0,1000.0,,,,,,,,,,
,152.63,800,29.3,1000.0,1000.0,,,,,,,,,,
,152.80,800,29.3,1000.0,1000.0,,,,,,,,,,
,152.97,760,29.3,1000.0,1000.0,,,,,,,,,,
,153.14,760,28.6,1000.0,1000.0,,,,,,,,,,
,153.32,760,28.6,1000.0,1000.0,,,,,,,,,,
,153.49,800,28.6,1000.0,1000.0,,,,,,,,,,
,153.66,800,28.6,1000.0,1000.0,,,,,,,,,,
,153.83,800,28.6,1000.0,1000.0,,,,,,,,,,
,154.00,800,28.6,1000.0,1000.0,,,,,,,,,,
,154.17,800,28.6,1000.0,1000.0,,,,,,,,,,
,154.35,800,27.8,1000.0,1000.0,,,,,,,,,,
,154.52,760,27.8,1000.0,1000.0,,,,,,,,,,
,154.69,760,27.8,1000.0,1000.0,,,,,,,,,,
,154.86,760,27.8,1000.0,1000.0,,,,,,,,,,
,155.03,760,28.6,1000.0,1000.0,,,,,,,,,,
,155.21,760,28.6,1000.0,1000.0,,,,,,,,,,
,155.38,760,28.6,1000.0,1000.0,,,,,,,,,,
,155.55,800,27.8,1000.0,1000.0,,,,,,,,,,
,155.72,800,27.8,1000.0,1000.0,,,,,,,,,,
,155.89,760,28.6,1000.0,1000.0,,,,,,,,,,
,156.07,760,28.6,1000.0,1000.0,,,,,,,,,,
,156.24,800,28.6,1000.0,1000.0,,,,,,,,,,
,156.41,760,28.6,1000.0,1000.0,,,,,,,,,,
,156.58,760,28.6,1000.0,1000.0,,,,,,,,,,
,156.75,760,27.8,1000.0,1000.0,,,,,,,,,,
,156.92,760,27.8,1000.0,1000.0,,,,,,,,,,
,157.10,800,27.8,1000.0,1000.0,,,,,,,,,,
,157.27,760,28.6,1000.0,1000.0,,,,,,,,,,
,157.44,760,28.6,1000.0,1000.0,,,,,,,,,,
,157.61,760,28.6,1000.0,1000.0,,,,,,,,,,
,157.78,800,28.6,1000.0,1000.0,,,,,,,,,,
,157.96,760,27.8,1000.0,1000.0,,,,,,,,,,
,158.13,760,27.8,1000.0,1000.0,,,,,,,,,,
,158.30,760,27.8,1000.0,1000.0,,,,,,,,,,
,158.47,800,27.8,1000.0,1000.0,,,,,,,,,,
,158.64,800,27.8,1000.0,1000.0,,,,,,,,,,
,158.82,760,28.6,1000.0,1000.0,,,,,,,,,,
,158.99,760,28.6,1000.0,1000.0,,,,,,,,,,
,159.16,800,28.6,1000.0,1000.0,,,,,,,,,,
,159.33,800,39.1,1130.0,1000.0,,,,,,,,,,
,159.50,1000,63.9,1040.0,990.0,,,,,,,,,,
,159.67,1240,63.9,1000.0,990.0,,,,,,,,,,
,159.85,1160,66.2,1000.0,990.0,,,,,,,,,,
,160.02,1160,66.2,1000.0,990.0,,,,,,,,,,
,160.19,1200,65.4,1000.0,990.0,,,,,,,,,,
,160.36,1240,64.7,1000.0,990.0,,,,,,,,,,
,160.53,1280,64.7,1000.0,990.0,,,,,,,,,,
,160.71,1440,65.4,1040.0,990.0,,,,,,,,,,
,160.88,1440,66.2,1070.0,990.0,,,,,,,,,,
,161.05,1520,66.2,1020.0,980.0,,,,,,,,,,
,161.22,1560,66.2,1000.0,990.0,,,,,,,,,,
,161.39,1680,65.4,1000.0,980.0,,,,,,,,,,
,161.57,1800,63.9,1000.0,980.0,,,,,,,,,,
,161.73,1960,64.7,1000.0,970.0,,,,,,,,,,
,161.91,2080,64.7,1000.0,970.0,,,,,,,,,,
,162.08,2240,63.9,1000.0,970.0,,,,,,,,,,
,162.25,2400,63.2,1000.0,960.0,,,,,,,,,,
,162.42,2520,62.4,1000.0,960.0,,,,,,,,,,
,162.60,2680,61.7,1000.0,950.0,,,,,,,,,,
,162.77,2840,60.9,1000.0,960.0,,,,,,,,,,
,162.94,2960,54.1,1000.0,970.0,,,,,,,,,,
,163.11,3040,50.4,1000.0,970.0,,,,,,,,,,
,163.28,3240,57.1,1030.0,950.0,,,,,,,,,,
,163.46,3360,61.7,1020.0,920.0,,,,,,,,,,
,163.63,3520,62.4,1090.0,920.0,,,,,,,,,,
,163.80,3640,61.7,1070.0,920.0,,,,,,,,,,
,163.97,3800,60.9,1090.0,910.0,,,,,,,,,,
,164.14,3960,60.9,1060.0,900.0,,,,,,,,,,
,164.32,4080,60.2,1000.0,900.0,,,,,,,,,,
,164.49,4280,59.4,1000.0,900.0,,,,,,,,,,
,164.66,4400,55.6,1000.0,900.0,,,,,,,,,,
,164.83,4280,50.4,1000.0,960.0,,,,,,,,,,
,165.00,4280,24.8,1000.0,1000.0,,,,,,,,,,
,165.18,4200,41.4,1000.0,950.0,,,,,,,,,,
,165.35,4120,60.9,1330.0,900.0,,,,,,,,,,
,165.52,3840,63.2,1490.0,890.0,,,,,,,,,,
,165.69,3520,65.4,1610.0,910.0,,,,,,,,,,
,165.86,3400,66.9,1590.0,910.0,,,,,,,,,,
,166.03,3480,65.4,1560.0,910.0,,,,,,,,,,
,166.21,3520,65.4,1500.0,920.0,,,,,,,,,,
,166.38,3480,63.9,1400.0,920.0,,,,,,,,,,
,166.55,3600,61.7,1420.0,920.0,,,,,,,,,,
,166.72,3640,61.7,1670.0,920.0,,,,,,,,,,
,166.89,3640,60.9,1670.0,920.0,,,,,,,,,,
,167.07,3720,60.2,1660.0,920.0,,,,,,,,,,
,167.24,3800,59.4,1660.0,920.0,,,,,,,,,,
,167.41,3880,58.6,1660.0,920.0,,,,,,,,,,
,167.58,3920,58.6,1650.0,910.0,,,,,,,,,,
,167.75,3960,57.9,1650.0,920.0,,,,,,,,,,
,167.93,4000,57.1,1640.0,920.0,,,,,,,,,,
,168.10,4080,57.1,1640.0,920.0,,,,,,,,,,
,168.27,4120,56.4,1640.0,920.0,,,,,,,,,,
,168.44,4160,56.4,1630.0,920.0,,,,,,,,,,
,168.61,4240,56.4,1630.0,920.0,,,,,,,,,,
,168.78,4280,56.4,1630.0,930.0,,,,,,,,,,
,168.96,4320,55.6,1610.0,930.0,,,,,,,,,,
,169.13,4400,54.9,1610.0,930.0,,,,,,,,,,
,169.30,4440,54.1,1610.0,930.0,,,,,,,,,,
,169.47,4480,54.1,1600.0,930.0,,,,,,,,,,
,169.64,4520,53.4,1600.0,930.0,,,,,,,,,,
,169.82,4560,53.4,1600.0,930.0,,,,,,,,,,
,169.99,4600,52.6,1600.0,930.0,,,,,,,,,,
,170.16,4640,51.9,1600.0,930.0,,,,,,,,,,
,170.33,4680,51.1,1590.0,940.0,,,,,,,,,,
,170.50,4760,50.4,1590.0,940.0,,,,,,,,,,
,170.68,4760,50.4,1590.0,940.0,,,,,,,,,,
,170.85,4840,48.9,1580.0,940.0,,,,,,,,,,
,171.02,4840,48.1,1580.0,940.0,,,,,,,,,,
,171.19,4880,48.1,1580.0,940.0,,,,,,,,,,
,171.36,4920,46.6,1580.0,940.0,,,,,,,,,,
,171.53,4960,46.6,1580.0,950.0,,,,,,,,,,
,171.71,4960,45.9,1580.0,950.0,,,,,,,,,,
,171.88,5000,45.1,1570.0,950.0,,,,,,,,,,
,172.05,5040,44.4,1570.0,950.0,,,,,,,,,,
,172.22,5040,44.4,1560.0,950.0,,,,,,,,,,
,172.40,5000,45.9,1000.0,950.0,,,,,,,,,,
,172.56,4960,41.4,1000.0,960.0,,,,,,,,,,
,172.73,4960,33.8,1000.0,980.0,,,,,,,,,,
,172.90,4960,47.4,1000.0,930.0,,,,,,,,,,
,173.07,5080,48.1,1210.0,940.0,,,,,,,,,,
,173.24,5160,45.9,1380.0,940.0,,,,,,,,,,
,173.41,5160,44.4,1550.0,950.0,,,,,,,,,,
,173.58,5280,42.1,1540.0,950.0,,,,,,,,,,
,173.75,5320,41.4,1530.0,950.0,,,,,,,,,,
,173.93,5280,54.1,1550.0,950.0,,,,,,,,,,
,174.10,5280,44.4,1550.0,950.0,,,,,,,,,,
,174.27,5240,66.9,1560.0,950.0,,,,,,,,,,
,174.44,5080,51.9,1570.0,950.0,,,,,,,,,,
,174.61,5120,46.6,1000.0,950.0,,,,,,,,,,
,174.78,5120,42.1,1000.0,950.0,,,,,,,,,,
,174.96,5120,33.1,1000.0,980.0,,,,,,,,,,
,175.13,5000,24.1,1000.0,990.0,,,,,,,,,,
,175.30,4800,21.8,1000.0,990.0,,,,,,,,,,
,175.47,4560,21.8,1000.0,990.0,,,,,,,,,,
,175.65,4360,21.1,1000.0,990.0,,,,,,,,,,
,175.82,4160,21.1,1000.0,990.0,,,,,,,,,,
,175.99,3960,20.3,1000.0,1000.0,,,,,,,,,,
,176.16,3800,18.8,1000.0,1000.0,,,,,,,,,,
,176.33,3680,18.0,1000.0,1000.0,,,,,,,,,,
,176.50,3600,18.0,1000.0,1000.0,,,,,,,,,,
,176.68,3520,17.3,1000.0,1000.0,,,,,,,,,,
,176.85,3240,17.3,1000.0,1000.0,,,,,,,,,,
,177.02,3040,17.3,1000.0,1000.0,,,,,,,,,,
,177.19,2840,17.3,1000.0,1000.0,,,,,,,,,,
,177.36,2640,15.8,1000.0,1000.0,,,,,,,,,,
,177.54,2440,16.5,1000.0,1000.0,,,,,,,,,,
,177.71,2240,16.5,1000.0,1000.0,,,,,,,,,,
,177.88,2000,17.3,1000.0,1000.0,,,,,,,,,,
,178.05,1840,15.8,1000.0,1000.0,,,,,,,,,,
,178.22,1720,15.8,1000.0,1000.0,,,,,,,,,,
,178.40,1600,15.8,1000.0,1000.0,,,,,,,,,,
,178.57,1600,15.8,1000.0,1000.0,,,,,,,,,,
,178.73,1520,15.8,1000.0,1000.0,,,,,,,,,,
,178.90,1520,15.8,1000.0,1000.0,,,,,,,,,,
,179.07,1480,15.8,1000.0,1000.0,,,,,,,,,,
,179.24,1480,15.8,1000.0,1000.0,,,,,,,,,,
,179.41,1480,15.8,1000.0,1000.0,,,,,,,,,,
,179.58,1480,15.8,1000.0,1000.0,,,,,,,,,,
,179.75,1480,15.8,1000.0,1000.0,,,,,,,,,,
,179.93,1480,15.8,1000.0,1000.0,,,,,,,,,,
,180.10,1440,15.8,1000.0,1000.0,,,,,,,,,,
,180.27,1440,15.8,1000.0,1000.0,,,,,,,,,,
,180.44,1480,15.8,1000.0,1000.0,,,,,,,,,,
,180.61,1480,15.0,1000.0,1000.0,,,,,,,,,,
,180.79,1480,15.0,1000.0,1000.0,,,,,,,,,,
,180.96,1480,15.0,1000.0,1000.0,,,,,,,,,,
,181.13,1440,15.0,1000.0,1000.0,,,,,,,,,,
,181.30,1440,15.8,1000.0,1000.0,,,,,,,,,,
,181.47,1440,15.8,1000.0,1000.0,,,,,,,,,,
,181.65,1400,15.8,1000.0,1000.0,,,,,,,,,,
,181.82,1400,15.0,1000.0,1000.0,,,,,,,,,,
,181.99,1400,15.0,1000.0,1000.0,,,,,,,,,,
,182.16,1400,15.0,1000.0,1000.0,,,,,,,,,,
,182.33,1400,15.0,1000.0,1000.0,,,,,,,,,,
,182.51,1400,15.0,1000.0,1000.0,,,,,,,,,,
,182.68,1400,15.0,1000.0,1000.0,,,,,,,,,,
,182.85,1360,15.0,1000.0,1000.0,,,,,,,,,,
,183.02,1360,15.0,1000.0,1000.0,,,,,,,,,,
,183.19,1360,15.0,1000.0,1000.0,,,,,,,,,,
,183.37,1360,15.0,1000.0,1000.0,,,,,,,,,,
,183.54,1360,15.0,1000.0,1000.0,,,,,,,,,,
,183.71,1360,15.0,1000.0,1000.0,,,,,,,,,,
,183.88,1360,15.0,1000.0,1000.0,,,,,,,,,,
,184.05,1360,15.0,1000.0,1000.0,,,,,,,,,,
,184.22,1360,15.0,1000.0,1000.0,,,,,,,,,,
,184.40,1360,15.0,1000.0,1000.0,,,,,,,,,,
,184.57,1360,15.0,1000.0,1000.0,,,,,,,,,,
,184.74,1360,15.0,1000.0,1000.0,,,,,,,,,,
,184.91,1360,15.0,1000.0,1000.0,,,,,,,,,,
,185.08,1360,15.0,1000.0,1000.0,,,,,,,,,,
,185.26,1320,15.0,1000.0,1000.0,,,,,,,,,,
,185.43,1320,15.0,1000.0,1000.0,,,,,,,,,,
,185.60,1320,15.0,1000.0,1000.0,,,,,,,,,,
,185.77,1320,15.0,1000.0,1000.0,,,,,,,,,,
,185.94,1320,15.0,1000.0,1000.0,,,,,,,,,,
,186.12,1320,15.0,1000.0,1000.0,,,,,,,,,,
,186.29,1320,15.0,1000.0,1000.0,,,,,,,,,,
,186.46,1320,15.0,1000.0,1000.0,,,,,,,,,,
,186.63,1320,15.0,1000.0,1000.0,,,,,,,,,,
,186.80,1320,15.0,1000.0,1000.0,,,,,,,,,,
,186.97,1320,15.0,1000.0,1000.0,,,,,,,,,,
,187.15,1280,15.0,1000.0,1000.0,,,,,,,,,,
,187.32,1280,15.0,1000.0,1000.0,,,,,,,,,,
,187.49,1280,14.3,1000.0,1000.0,,,,,,,,,,
,187.66,1280,14.3,1000.0,1000.0,,,,,,,,,,
,187.83,1320,14.3,1000.0,1000.0,,,,,,,,,,
,188.00,1320,14.3,1000.0,1000.0,,,,,,,,,,
,188.18,1320,14.3,1000.0,1000.0,,,,,,,,,,
,188.35,1320,14.3,1000.0,1000.0,,,,,,,,,,
,188.52,1320,14.3,1000.0,1000.0,,,,,,,,,,
,188.69,1320,14.3,1000.0,1000.0,,,,,,,,,,
,188.87,1280,15.0,1000.0,1000.0,,,,,,,,,,
,189.04,1280,15.0,1000.0,1000.0,,,,,,,,,,
,189.21,1320,15.0,1000.0,1000.0,,,,,,,,,,
,189.38,1320,15.0,1000.0,1000.0,,,,,,,,,,
,189.55,1320,15.8,1000.0,1000.0,,,,,,,,,,
,189.72,1320,16.5,1000.0,1000.0,,,,,,,,,,
,189.90,1280,15.8,1000.0,1000.0,,,,,,,,,,
,190.07,1280,15.0,1000.0,1000.0,,,,,,,,,,
,190.24,1280,14.3,1000.0,1000.0,,,,,,,,,,
,190.41,1240,14.3,1000.0,1000.0,,,,,,,,,,
,190.58,1240,14.3,1000.0,1000.0,,,,,,,,,,
,190.75,1240,14.3,1000.0,1000.0,,,,,,,,,,
,190.92,1240,14.3,1000.0,1000.0,,,,,,,,,,
,191.09,1240,14.3,1000.0,1000.0,,,,,,,,,,
,191.26,1200,14.3,1000.0,1000.0,,,,,,,,,,
,191.43,1200,14.3,1000.0,1000.0,,,,,,,,,,
,191.60,1200,14.3,1000.0,1000.0,,,,,,,,,,
,191.77,1200,14.3,1000.0,1000.0,,,,,,,,,,
,191.94,1200,15.0,1000.0,1000.0,,,,,,,,,,
,192.11,1200,15.0,1000.0,1000.0,,,,,,,,,,
,192.29,1200,15.0,1000.0,1000.0,,,,,,,,,,
,192.46,1160,15.0,1000.0,1000.0,,,,,,,,,,
,192.63,1160,15.0,1000.0,1000.0,,,,,,,,,,
,192.80,1160,15.0,1000.0,1000.0,,,,,,,,,,
,192.97,1160,15.8,1000.0,1000.0,,,,,,,,,,
,193.15,1160,19.5,1000.0,1000.0,,,,,,,,,,
,193.32,1200,19.5,1000.0,1000.0,,,,,,,,,,
,193.49,1160,21.1,1000.0,1000.0,,,,,,,,,,
,193.66,1160,21.1,1000.0,1000.0,,,,,,,,,,
,193.83,1120,18.8,1000.0,1000.0,,,,,,,,,,
,194.01,1200,21.8,1000.0,1000.0,,,,,,,,,,
,194.18,1200,23.3,1000.0,1000.0,,,,,,,,,,
,194.35,1160,24.1,1000.0,1000.0,,,,,,,,,,
,194.52,1160,26.3,1000.0,1000.0,,,,,,,,,,
,194.69,1200,27.8,1000.0,1000.0,,,,,,,,,,
,194.87,1200,30.1,1000.0,1000.0,,,,,,,,,,
,195.04,1200,33.1,1000.0,1000.0,,,,,,,,,,
,195.21,1240,35.3,1000.0,1000.0,,,,,,,,,,
,195.38,1280,35.3,1000.0,1000.0,,,,,,,,,,
,195.55,1320,35.3,1000.0,1000.0,,,,,,,,,,
,195.72,1360,41.4,1000.0,1000.0,,,,,,,,,,
,195.90,1440,45.9,1000.0,1000.0,,,,,,,,,,
,196.07,1480,47.4,1000.0,990.0,,,,,,,,,,
,196.24,1520,50.4,1000.0,990.0,,,,,,,,,,
,196.41,1520,45.9,1000.0,1000.0,,,,,,,,,,
,196.58,1480,37.6,1000.0,1000.0,,,,,,,,,,
,196.76,1400,35.3,1000.0,1000.0,,,,,,,,,,
,196.93,1320,36.8,1000.0,1000.0,,,,,,,,,,
,197.10,1360,44.4,1040.0,990.0,,,,,,,,,,
,197.27,1440,51.1,1000.0,990.0,,,,,,,,,,
,197.44,1480,54.9,1010.0,990.0,,,,,,,,,,
,197.62,1560,58.6,1030.0,990.0,,,,,,,,,,
,197.79,1560,62.4,1050.0,990.0,,,,,,,,,,
,197.96,1560,63.9,1290.0,980.0,,,,,,,,,,
,198.13,1560,66.2,1330.0,980.0,,,,,,,,,,
,198.30,1600,69.9,1360.0,980.0,,,,,,,,,,
,198.48,1640,69.9,1380.0,970.0,,,,,,,,,,
,198.65,1720,69.2,1360.0,970.0,,,,,,,,,,
,198.82,1760,68.4,1340.0,980.0,,,,,,,,,,
,198.99,1800,68.4,1340.0,970.0,,,,,,,,,,
,199.16,1800,67.7,1330.0,970.0,,,,,,,,,,
,199.33,1840,67.7,1350.0,970.0,,,,,,,,,,
,199.51,1840,68.4,1360.0,970.0,,,,,,,,,,
,199.68,1840,69.2,1370.0,970.0,,,,,,,,,,
,199.85,1880,69.2,1360.0,970.0,,,,,,,,,,
,200.02,1880,69.2,1370.0,970.0,,,,,,,,,,
,200.19,1880,69.2,1360.0,970.0,,,,,,,,,,
,200.37,1920,69.2,1330.0,970.0,,,,,,,,,,
,200.54,1920,68.4,1260.0,970.0,,,,,,,,,,
,200.71,1920,65.4,1000.0,970.0,,,,,,,,,,
,200.88,1800,58.6,1000.0,990.0,,,,,,,,,,
,201.05,1560,45.1,1000.0,1000.0,,,,,,,,,,
,201.23,1520,29.3,1000.0,1000.0,,,,,,,,,,
,201.40,1520,30.1,1000.0,1000.0,,,,,,,,,,
,201.57,1560,42.9,1000.0,990.0,,,,,,,,,,
,201.74,1680,49.6,1000.0,990.0,,,,,,,,,,
,201.91,1560,53.4,1000.0,990.0,,,,,,,,,,
,202.08,1520,47.4,1000.0,1000.0,,,,,,,,,,
,202.26,1400,37.6,1000.0,1000.0,,,,,,,,,,
,202.43,1400,27.8,1000.0,1000.0,,,,,,,,,,
,202.60,1400,27.1,1000.0,1000.0,,,,,,,,,,
,202.77,1360,30.8,1000.0,1000.0,,,,,,,,,,
,202.95,1360,33.1,1000.0,1000.0,,,,,,,,,,
,203.12,1360,33.8,1000.0,1000.0,,,,,,,,,,
,203.29,1360,27.8,1000.0,1000.0,,,,,,,,,,
,203.46,1320,21.8,1000.0,1000.0,,,,,,,,,,
,203.63,1280,18.0,1000.0,1000.0,,,,,,,,,,
,203.80,1320,15.8,1000.0,1000.0,,,,,,,,,,
,203.98,1320,13.5,1000.0,1000.0,,,,,,,,,,
,204.15,1320,12.8,1000.0,1000.0,,,,,,,,,,
,204.32,1320,12.8,1000.0,1000.0,,,,,,,,,,
,204.49,1320,13.5,1000.0,1000.0,,,,,,,,,,
,204.66,1320,13.5,1000.0,1000.0,,,,,,,,,,
,204.83,1320,13.5,1000.0,1000.0,,,,,,,,,,
,205.01,1320,13.5,1000.0,1000.0,,,,,,,,,,
,205.18,1320,13.5,1000.0,1000.0,,,,,,,,,,
,205.35,1320,13.5,1000.0,1000.0,,,,,,,,,,
,205.52,1280,13.5,1000.0,1000.0,,,,,,,,,,
,205.69,1280,13.5,1000.0,1000.0,,,,,,,,,,
,205.87,1320,13.5,1000.0,1000.0,,,,,,,,,,
,206.04,1320,13.5,1000.0,1000.0,,,,,,,,,,
,206.21,1320,13.5,1000.0,1000.0,,,,,,,,,,
,206.38,1280,13.5,1000.0,1000.0,,,,,,,,,,
,206.55,1280,13.5,1000.0,1000.0,,,,,,,,,,
,206.73,1320,13.5,1000.0,1000.0,,,,,,,,,,
,206.90,1320,13.5,1000.0,1000.0,,,,,,,,,,
,207.07,1280,14.3,1000.0,1000.0,,,,,,,,,,
,207.24,1320,15.0,1000.0,1000.0,,,,,,,,,,
,207.41,1320,15.0,1000.0,1000.0,,,,,,,,,,
,207.59,1280,15.8,1000.0,1000.0,,,,,,,,,,
,207.76,1280,15.8,1000.0,1000.0,,,,,,,,,,
,207.93,1240,15.8,1000.0,1000.0,,,,,,,,,,
,208.10,1240,15.0,1000.0,1000.0,,,,,,,,,,
,208.27,1240,14.3,1000.0,1000.0,,,,,,,,,,
,208.44,1200,13.5,1000.0,1000.0,,,,,,,,,,
,208.62,1200,14.3,1000.0,1000.0,,,,,,,,,,
,208.79,1200,14.3,1000.0,1000.0,,,,,,,,,,
,208.96,1200,14.3,1000.0,1000.0,,,,,,,,,,
,209.13,1200,14.3,1000.0,1000.0,,,,,,,,,,
,209.30,1160,14.3,1000.0,1000.0,,,,,,,,,,
,209.48,1200,15.8,1000.0,1000.0,,,,,,,,,,
,209.65,1160,15.8,1000.0,1000.0,,,,,,,,,,
,209.81,1160,15.0,1000.0,1000.0,,,,,,,,,,
,209.99,1120,17.3,1000.0,1000.0,,,,,,,,,,
,210.16,1160,18.8,1000.0,1000.0,,,,,,,,,,
,210.34,1160,21.1,1000.0,1000.0,,,,,,,,,,
,210.51,1160,21.8,1000.0,1000.0,,,,,,,,,,
,210.68,1120,20.3,1000.0,1000.0,,,,,,,,,,
,210.85,1160,19.5,1000.0,1000.0,,,,,,,,,,
,211.02,1120,19.5,1000.0,1000.0,,,,,,,,,,
,211.19,1080,19.5,1000.0,1000.0,,,,,,,,,,
,211.37,1080,19.5,1000.0,1000.0,,,,,,,,,,
,211.53,1120,22.6,1000.0,1000.0,,,,,,,,,,
,211.71,1120,26.3,1000.0,1000.0,,,,,,,,,,
,211.88,1120,27.1,1000.0,1000.0,,,,,,,,,,
,212.05,1120,27.8,1000.0,1000.0,,,,,,,,,,
,212.21,1160,28.6,1000.0,1000.0,,,,,,,,,,
,212.39,1200,29.3,1000.0,1000.0,,,,,,,,,,
,212.57,1160,29.3,1000.0,1000.0,,,,,,,,,,
,212.73,1160,26.3,1000.0,1000.0,,,,,,,,,,
,212.90,1120,24.1,1000.0,1000.0,,,,,,,,,,
,213.08,1120,23.3,1000.0,1000.0,,,,,,,,,,
,213.25,1080,21.8,1000.0,1000.0,,,,,,,,,,
,213.42,1000,21.1,1000.0,1000.0,,,,,,,,,,
,213.59,960,21.1,1000.0,1000.0,,,,,,,,,,
,213.76,920,20.3,1000.0,1000.0,,,,,,,,,,
,213.93,840,19.5,1000.0,1000.0,,,,,,,,,,
,214.11,720,23.3,1000.0,1000.0,,,,,,,,,,
,214.28,680,30.8,1000.0,1000.0,,,,,,,,,,
,214.45,800,33.8,1000.0,1000.0,,,,,,,,,,
,214.62,840,27.8,1000.0,1000.0,,,,,,,,,,
,214.79,840,24.1,1000.0,1000.0,,,,,,,,,,
,214.97,840,20.3,1000.0,1000.0,,,,,,,,,,
,215.14,800,18.8,1000.0,1000.0,,,,,,,,,,
,215.31,760,18.8,1000.0,1000.0,,,,,,,,,,
,215.48,760,18.8,1000.0,1000.0,,,,,,,,,,
,215.65,760,18.8,1000.0,1000.0,,,,,,,,,,
,215.83,800,19.5,1000.0,1000.0,,,,,,,,,,
,216.00,800,19.5,1000.0,1000.0,,,,,,,,,,
,216.17,800,19.5,1000.0,1000.0,,,,,,,,,,
,216.34,800,18.8,1000.0,1000.0,,,,,,,,,,
,216.51,800,18.0,1000.0,1000.0,,,,,,,,,,
,216.68,760,18.0,1000.0,1000.0,,,,,,,,,,
,216.86,760,18.0,1000.0,1000.0,,,,,,,,,,
,217.03,760,18.0,1000.0,1000.0,,,,,,,,,,
,217.20,760,18.0,1000.0,1000.0,,,,,,,,,,
,217.37,760,18.0,1000.0,1000.0,,,,,,,,,,
,217.54,760,18.0,1000.0,1000.0,,,,,,,,,,
,217.72,760,18.0,1000.0,1000.0,,,,,,,,,,
,217.89,800,18.0,1000.0,1000.0,,,,,,,,,,
,218.06,800,18.0,1000.0,1000.0,,,,,,,,,,
,218.23,760,18.0,1000.0,1000.0,,,,,,,,,,
,218.40,800,18.0,1000.0,1000.0,,,,,,,,,,
,218.58,800,18.0,1000.0,1000.0,,,,,,,,,,
,218.75,800,18.0,1000.0,1000.0,,,,,,,,,,
,218.92,760,18.0,1000.0,1000.0,,,,,,,,,,
,219.09,760,18.0,1000.0,1000.0,,,,,,,,,,
,219.26,760,17.3,1000.0,1000.0,,,,,,,,,,
,219.44,760,17.3,1000.0,1000.0,,,,,,,,,,
,219.61,760,17.3,1000.0,1000.0,,,,,,,,,,
,219.78,760,18.0,1000.0,1000.0,,,,,,,,,,
,219.96,760,18.0,1000.0,1000.0,,,,,,,,,,
Monday,30,October,2006,10:09:06
,0.01,2040,36.1,1010.0,990.0,,,,,,,,,,
,0.17,2120,58.6,1350.0,970.0,,,,,,,,,,
,0.35,2200,68.4,1530.0,960.0,,,,,,,,,,
,0.53,2240,69.2,1730.0,960.0,,,,,,,,,,
,0.70,2440,66.9,1740.0,950.0,,,,,,,,,,
,0.87,2760,69.2,1720.0,930.0,,,,,,,,,,
,1.05,3200,70.7,1650.0,920.0,,,,,,,,,,
,1.22,3400,68.4,1650.0,910.0,,,,,,,,,,
,1.39,3640,68.4,1650.0,900.0,,,,,,,,,,
,1.56,3800,66.9,1640.0,890.0,,,,,,,,,,
,1.73,4000,66.2,1640.0,880.0,,,,,,,,,,
,1.91,4240,66.2,1630.0,870.0,,,,,,,,,,
,2.08,4400,64.7,1620.0,870.0,,,,,,,,,,
,2.25,4520,64.7,1610.0,870.0,,,,,,,,,,
,2.42,4600,58.6,1610.0,900.0,,,,,,,,,,
,2.60,4720,57.9,1600.0,910.0,,,,,,,,,,
,2.78,4840,57.1,1600.0,910.0,,,,,,,,,,
,2.95,4920,55.6,1600.0,920.0,,,,,,,,,,
,3.12,5000,55.6,1590.0,920.0,,,,,,,,,,
,3.30,5080,54.1,1570.0,920.0,,,,,,,,,,
,3.47,5200,52.6,1560.0,920.0,,,,,,,,,,
,3.64,5280,51.9,1540.0,920.0,,,,,,,,,,
,3.81,5360,50.4,1530.0,920.0,,,,,,,,,,
,3.98,5440,48.9,1520.0,930.0,,,,,,,,,,
,4.16,5480,48.1,1490.0,930.0,,,,,,,,,,
,4.33,5320,48.9,1490.0,930.0,,,,,,,,,,
,4.50,5080,50.4,1530.0,930.0,,,,,,,,,,
,4.67,4680,52.6,1560.0,930.0,,,,,,,,,,
,4.84,4160,56.4,1560.0,940.0,,,,,,,,,,
,5.02,4040,57.9,1570.0,930.0,,,,,,,,,,
,5.19,4000,57.9,1580.0,930.0,,,,,,,,,,
,5.36,4040,57.9,1580.0,920.0,,,,,,,,,,
,5.53,4040,57.9,1590.0,930.0,,,,,,,,,,
,5.70,4080,57.9,1610.0,930.0,,,,,,,,,,
,5.87,4120,57.1,1610.0,920.0,,,,,,,,,,
,6.05,4160,57.1,1600.0,930.0,,,,,,,,,,
,6.22,4200,57.1,1600.0,930.0,,,,,,,,,,
,6.39,4240,57.1,1590.0,930.0,,,,,,,,,,
,6.57,4320,56.4,1600.0,930.0,,,,,,,,,,
,6.75,4360,56.4,1590.0,930.0,,,,,,,,,,
,6.92,4400,55.6,1580.0,930.0,,,,,,,,,,
,7.09,4440,55.6,1580.0,930.0,,,,,,,,,,
,7.27,4520,55.6,1580.0,930.0,,,,,,,,,,
,7.44,4560,54.9,1580.0,930.0,,,,,,,,,,
,7.61,4600,54.1,1580.0,930.0,,,,,,,,,,
,7.78,4640,54.1,1580.0,930.0,,,,,,,,,,
,7.96,4680,53.4,1570.0,930.0,,,,,,,,,,
,8.14,4720,53.4,1570.0,930.0,,,,,,,,,,
,8.31,4760,53.4,1570.0,930.0,,,,,,,,,,
,8.49,4800,52.6,1570.0,930.0,,,,,,,,,,
,8.66,4840,51.9,1570.0,930.0,,,,,,,,,,
,8.83,4880,51.9,1010.0,930.0,,,,,,,,,,
,9.00,4760,44.4,1010.0,960.0,,,,,,,,,,
,9.17,4760,32.3,1010.0,980.0,,,,,,,,,,
,9.34,4680,20.3,1010.0,1000.0,,,,,,,,,,
,9.52,4720,18.8,1010.0,990.0,,,,,,,,,,
,9.69,4720,20.3,1010.0,980.0,,,,,,,,,,
,9.86,4760,50.4,1010.0,910.0,,,,,,,,,,
,10.03,4960,55.6,1310.0,910.0,,,,,,,,,,
,10.21,5040,54.1,1460.0,920.0,,,,,,,,,,
,10.39,5000,52.6,1560.0,930.0,,,,,,,,,,
,10.56,5040,51.9,1560.0,930.0,,,,,,,,,,
,10.74,5040,51.1,1560.0,930.0,,,,,,,,,,
,10.91,5080,50.4,1570.0,930.0,,,,,,,,,,
,11.08,5080,50.4,1570.0,930.0,,,,,,,,,,
,11.25,5080,50.4,1570.0,930.0,,,,,,,,,,
,11.42,5120,49.6,1560.0,940.0,,,,,,,,,,
,11.59,5160,48.9,1560.0,940.0,,,,,,,,,,
,11.77,5200,48.1,1550.0,940.0,,,,,,,,,,
,11.94,5200,47.4,1540.0,940.0,,,,,,,,,,
,12.11,5240,46.6,1520.0,940.0,,,,,,,,,,
,12.28,5280,45.9,1520.0,940.0,,,,,,,,,,
,12.45,5320,45.1,1510.0,940.0,,,,,,,,,,
,12.64,5360,44.4,1510.0,940.0,,,,,,,,,,
,12.82,5360,44.4,1510.0,950.0,,,,,,,,,,
,12.99,5400,43.6,1500.0,950.0,,,,,,,,,,
,13.16,5400,43.6,1500.0,950.0,,,,,,,,,,
,13.33,5400,43.6,1500.0,950.0,,,,,,,,,,
,13.51,5440,42.9,1490.0,950.0,,,,,,,,,,
,13.68,5480,42.1,1490.0,950.0,,,,,,,,,,
,13.85,5480,42.1,1490.0,950.0,,,,,,,,,,
,14.02,5520,41.4,1490.0,950.0,,,,,,,,,,
,14.19,5520,55.6,1480.0,950.0,,,,,,,,,,
,14.36,5520,55.6,1480.0,950.0,,,,,,,,,,
,14.54,5440,45.1,1480.0,950.0,,,,,,,,,,
,14.71,5480,40.6,1480.0,950.0,,,,,,,,,,
,14.88,5560,53.4,1480.0,950.0,,,,,,,,,,
,15.05,5440,70.7,1480.0,950.0,,,,,,,,,,
,15.22,5480,43.6,1480.0,950.0,,,,,,,,,,
,15.39,5560,65.4,1480.0,950.0,,,,,,,,,,
,15.57,5480,42.9,1470.0,950.0,,,,,,,,,,
,15.74,5520,63.9,1490.0,950.0,,,,,,,,,,
,15.91,5440,43.6,1480.0,950.0,,,,,,,,,,
,16.08,5480,66.9,1490.0,950.0,,,,,,,,,,
,16.25,5240,73.7,1500.0,950.0,,,,,,,,,,
,16.43,5200,74.4,1520.0,950.0,,,,,,,,,,
,16.60,5400,74.4,1500.0,950.0,,,,,,,,,,
,16.77,5560,73.7,1490.0,950.0,,,,,,,,,,
,16.94,5560,73.7,1480.0,950.0,,,,,,,,,,
,17.11,5560,73.7,1480.0,950.0,,,,,,,,,,
,17.30,5520,73.7,1480.0,950.0,,,,,,,,,,
,17.48,5560,73.7,1480.0,960.0,,,,,,,,,,
,17.65,5560,73.7,1480.0,950.0,,,,,,,,,,
,17.82,5560,73.7,1480.0,950.0,,,,,,,,,,
,17.99,5560,73.7,1480.0,960.0,,,,,,,,,,
,18.16,5560,73.7,1480.0,960.0,,,,,,,,,,
,18.34,5560,73.7,1480.0,950.0,,,,,,,,,,
,18.50,5560,73.7,1480.0,960.0,,,,,,,,,,
,18.68,5560,73.7,1480.0,960.0,,,,,,,,,,
,18.85,5560,73.7,1480.0,960.0,,,,,,,,,,
,19.02,5560,73.7,1480.0,960.0,,,,,,,,,,
,19.20,5600,73.7,1470.0,960.0,,,,,,,,,,
,19.37,5560,73.7,1470.0,960.0,,,,,,,,,,
,19.54,5600,73.7,1470.0,960.0,,,,,,,,,,
,19.71,5600,73.7,1470.0,960.0,,,,,,,,,,
,19.88,5600,73.7,1470.0,960.0,,,,,,,,,,
,20.06,5600,73.7,1470.0,960.0,,,,,,,,,,
,20.23,5600,73.7,1470.0,960.0,,,,,,,,,,
,20.40,5600,73.7,1470.0,960.0,,,,,,,,,,
,20.57,5560,73.7,1470.0,960.0,,,,,,,,,,
,20.74,5600,74.4,1470.0,960.0,,,,,,,,,,
,20.91,5600,73.7,1470.0,960.0,,,,,,,,,,
,21.09,5600,73.7,1470.0,960.0,,,,,,,,,,
,21.26,5600,73.7,1460.0,960.0,,,,,,,,,,
,21.43,5600,73.7,1460.0,960.0,,,,,,,,,,
,21.60,5600,73.7,1460.0,960.0,,,,,,,,,,
,21.77,5600,74.4,1460.0,960.0,,,,,,,,,,
,21.94,5600,73.7,1460.0,960.0,,,,,,,,,,
,22.12,5600,74.4,1460.0,960.0,,,,,,,,,,
,22.29,5600,74.4,1460.0,960.0,,,,,,,,,,
,22.46,5600,74.4,1460.0,960.0,,,,,,,,,,
,22.63,5600,74.4,1460.0,960.0,,,,,,,,,,
,22.81,5600,74.4,1460.0,960.0,,,,,,,,,,
,22.98,5600,73.7,1460.0,960.0,,,,,,,,,,
,23.15,5600,74.4,1460.0,960.0,,,,,,,,,,
,23.32,5600,74.4,1460.0,960.0,,,,,,,,,,
,23.49,5600,74.4,1460.0,960.0,,,,,,,,,,
,23.66,5600,73.7,1460.0,960.0,,,,,,,,,,
,23.84,5600,73.7,1460.0,960.0,,,,,,,,,,
,24.01,5560,74.4,1460.0,960.0,,,,,,,,,,
,24.18,5560,74.4,1460.0,960.0,,,,,,,,,,
,24.35,5560,74.4,1460.0,960.0,,,,,,,,,,
,24.52,5560,73.7,1460.0,960.0,,,,,,,,,,
,24.69,5600,74.4,1460.0,960.0,,,,,,,,,,
,24.87,5560,73.7,1460.0,960.0,,,,,,,,,,
,25.04,5560,74.4,1460.0,960.0,,,,,,,,,,
,25.21,5560,74.4,1460.0,960.0,,,,,,,,,,
,25.39,5560,73.7,1460.0,960.0,,,,,,,,,,
,25.57,5560,74.4,1460.0,960.0,,,,,,,,,,
,25.74,5560,74.4,1460.0,960.0,,,,,,,,,,
,25.91,5560,74.4,1460.0,960.0,,,,,,,,,,
,26.09,5560,74.4,1460.0,960.0,,,,,,,,,,
,26.26,5560,74.4,1460.0,960.0,,,,,,,,,,
,26.43,5560,74.4,1460.0,960.0,,,,,,,,,,
,26.60,5560,74.4,1460.0,960.0,,,,,,,,,,
,26.77,5520,74.4,1460.0,960.0,,,,,,,,,,
,26.95,5560,74.4,1460.0,960.0,,,,,,,,,,
,27.12,5560,74.4,1460.0,960.0,,,,,,,,,,
,27.29,5520,74.4,1460.0,960.0,,,,,,,,,,
,27.46,5520,74.4,1460.0,960.0,,,,,,,,,,
,27.63,5560,74.4,1330.0,960.0,,,,,,,,,,
,27.81,5280,57.9,1010.0,960.0,,,,,,,,,,
,27.98,5480,18.0,1010.0,1000.0,,,,,,,,,,
,28.15,5480,14.3,1010.0,1000.0,,,,,,,,,,
,28.32,5440,13.5,1010.0,1000.0,,,,,,,,,,
,28.49,5400,13.5,1010.0,1000.0,,,,,,,,,,
,28.66,5360,13.5,1010.0,1000.0,,,,,,,,,,
,28.84,5320,13.5,1010.0,1000.0,,,,,,,,,,
,29.01,5280,13.5,1010.0,1000.0,,,,,,,,,,
,29.18,5240,13.5,1010.0,1000.0,,,,,,,,,,
,29.35,5200,13.5,1010.0,1000.0,,,,,,,,,,
,29.52,5160,17.3,1010.0,990.0,,,,,,,,,,
,29.70,5120,18.0,1010.0,990.0,,,,,,,,,,
,29.87,5080,17.3,1010.0,990.0,,,,,,,,,,
,30.04,5040,16.5,1010.0,990.0,,,,,,,,,,
,30.21,5000,16.5,1010.0,1000.0,,,,,,,,,,
,30.38,4960,15.8,1010.0,1000.0,,,,,,,,,,
,30.55,4960,15.8,1010.0,1000.0,,,,,,,,,,
,30.73,4920,15.8,1010.0,1000.0,,,,,,,,,,
,30.90,4880,15.8,1010.0,1000.0,,,,,,,,,,
,31.07,4840,15.8,1010.0,1000.0,,,,,,,,,,
,31.24,4800,15.8,1010.0,1000.0,,,,,,,,,,
,31.41,4760,15.8,1010.0,1000.0,,,,,,,,,,
,31.59,4720,15.8,1010.0,1000.0,,,,,,,,,,
,31.76,4720,15.8,1010.0,1000.0,,,,,,,,,,
,31.93,4680,15.8,1010.0,1000.0,,,,,,,,,,
,32.10,4640,15.8,1010.0,1000.0,,,,,,,,,,
,32.27,4600,15.8,1010.0,1000.0,,,,,,,,,,
,32.45,4560,15.8,1010.0,1000.0,,,,,,,,,,
,32.62,4520,15.8,1010.0,1000.0,,,,,,,,,,
,32.79,4440,15.8,1010.0,1000.0,,,,,,,,,,
,32.96,4400,15.8,1010.0,1000.0,,,,,,,,,,
,33.13,4360,15.8,1010.0,1000.0,,,,,,,,,,
,33.31,4320,15.8,1010.0,1000.0,,,,,,,,,,
,33.48,4320,18.8,1010.0,990.0,,,,,,,,,,
,33.65,4320,23.3,1010.0,990.0,,,,,,,,,,
,33.82,4240,21.8,1010.0,990.0,,,,,,,,,,
,33.99,4240,18.8,1010.0,1000.0,,,,,,,,,,
,34.16,4160,17.3,1010.0,1000.0,,,,,,,,,,
,34.34,4160,15.8,1010.0,1000.0,,,,,,,,,,
,34.51,4200,24.8,1010.0,980.0,,,,,,,,,,
,34.68,4280,36.1,1010.0,980.0,,,,,,,,,,
,34.85,4280,36.1,1010.0,980.0,,,,,,,,,,
,35.02,4280,36.1,1010.0,980.0,,,,,,,,,,
,35.20,4280,33.1,1010.0,980.0,,,,,,,,,,
,35.37,4200,19.5,1010.0,1000.0,,,,,,,,,,
,35.54,4160,16.5,1010.0,1000.0,,,,,,,,,,
,35.71,4120,14.3,1010.0,1000.0,,,,,,,,,,
,35.88,4080,13.5,1010.0,1000.0,,,,,,,,,,
,36.06,4080,13.5,1010.0,1000.0,,,,,,,,,,
,36.23,4080,13.5,1010.0,1000.0,,,,,,,,,,
,36.40,4120,21.1,1010.0,990.0,,,,,,,,,,
,36.57,4200,37.6,1010.0,970.0,,,,,,,,,,
,36.74,4200,43.6,1010.0,960.0,,,,,,,,,,
,36.91,4240,45.1,1010.0,960.0,,,,,,,,,,
,37.09,4280,45.1,1010.0,960.0,,,,,,,,,,
,37.26,4280,44.4,1010.0,960.0,,,,,,,,,,
,37.43,4240,39.8,1010.0,970.0,,,,,,,,,,
,37.60,4240,36.8,1010.0,970.0,,,,,,,,,,
,37.77,4240,37.6,1010.0,980.0,,,,,,,,,,
,37.95,4280,37.6,1010.0,970.0,,,,,,,,,,
,38.12,4280,36.1,1010.0,980.0,,,,,,,,,,
,38.29,4360,56.4,1560.0,910.0,,,,,,,,,,
,38.46,4480,63.2,1660.0,870.0,,,,,,,,,,
,38.63,4520,60.9,1660.0,890.0,,,,,,,,,,
,38.81,4520,58.6,1440.0,910.0,,,,,,,,,,
,38.98,4480,55.6,1010.0,930.0,,,,,,,,,,
,39.15,4400,33.8,1010.0,990.0,,,,,,,,,,
,39.32,4320,19.5,1010.0,1000.0,,,,,,,,,,
,39.50,4360,18.8,1010.0,990.0,,,,,,,,,,
,39.68,4400,37.6,1010.0,960.0,,,,,,,,,,
,39.85,4520,58.6,1010.0,910.0,,,,,,,,,,
,40.03,4640,60.2,1010.0,880.0,,,,,,,,,,
,40.20,4680,57.1,1010.0,910.0,,,,,,,,,,
,40.37,4600,51.1,1010.0,930.0,,,,,,,,,,
,40.54,4520,26.3,1010.0,990.0,,,,,,,,,,
,40.71,4440,17.3,1010.0,1000.0,,,,,,,,,,
,40.88,4400,14.3,1010.0,1000.0,,,,,,,,,,
,41.06,4400,13.5,1010.0,1000.0,,,,,,,,,,
,41.23,4440,13.5,1010.0,1000.0,,,,,,,,,,
,41.40,4400,13.5,1010.0,1000.0,,,,,,,,,,
,41.57,4400,16.5,1010.0,1000.0,,,,,,,,,,
,41.74,4400,15.8,1010.0,1000.0,,,,,,,,,,
,41.91,4360,15.8,1010.0,1000.0,,,,,,,,,,
,42.09,4320,15.8,1010.0,1000.0,,,,,,,,,,
,42.26,4320,15.8,1010.0,1000.0,,,,,,,,,,
,42.43,4280,15.8,1010.0,1000.0,,,,,,,,,,
,42.60,4240,15.8,1010.0,1000.0,,,,,,,,,,
,42.78,4200,15.8,1010.0,1000.0,,,,,,,,,,
,42.95,4200,15.8,1010.0,1000.0,,,,,,,,,,
,43.12,4160,15.0,1010.0,1000.0,,,,,,,,,,
,43.29,4120,15.8,1010.0,1000.0,,,,,,,,,,
,43.46,4080,15.8,1010.0,1000.0,,,,,,,,,,
,43.63,4080,15.8,1010.0,1000.0,,,,,,,,,,
,43.81,4040,15.8,1010.0,1000.0,,,,,,,,,,
,43.98,4000,15.8,1010.0,1000.0,,,,,,,,,,
,44.15,3920,15.8,1010.0,1000.0,,,,,,,,,,
,44.32,3920,15.8,1010.0,1000.0,,,,,,,,,,
,44.50,3880,15.8,1010.0,1000.0,,,,,,,,,,
,44.67,3840,15.8,1010.0,1000.0,,,,,,,,,,
,44.84,3800,15.8,1010.0,1000.0,,,,,,,,,,
,45.01,3760,15.8,1010.0,1000.0,,,,,,,,,,
,45.18,3680,15.8,1010.0,1000.0,,,,,,,,,,
,45.35,3640,16.5,1010.0,1000.0,,,,,,,,,,
,45.53,3600,16.5,1010.0,1000.0,,,,,,,,,,
,45.70,3560,16.5,1010.0,1000.0,,,,,,,,,,
,45.87,3480,16.5,1010.0,1000.0,,,,,,,,,,
,46.04,3440,15.8,1010.0,1000.0,,,,,,,,,,
,46.21,3360,16.5,1010.0,1000.0,,,,,,,,,,
,46.38,3320,16.5,1010.0,1000.0,,,,,,,,,,
,46.56,3240,16.5,1010.0,1000.0,,,,,,,,,,
,46.73,3200,16.5,1010.0,1000.0,,,,,,,,,,
8E0 909 518 AK,,1.8L R4/5VT G 0004,
,Group A:,'115,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure,,,,,,,,,,
,TIME,(G28),,(specified),(actual),TIME,,,,,TIME,,, ,
Marker,STAMP, /min, %, mbar, mbar,STAMP,,,,,STAMP,,,,
