Need Help - Cannot get Anything to Work
Just upgraded to a new Dell 410N laptop running Windows XP Professional. Also, the computer is running Novel networking software which cannot be removed. When I start up the computer, I log onto local work station only, and don't activate any networking feature. I need to change my registered VAG-COM to the new computer. Running VAG-COM software version 409.1-S with a Twin-Com cable having a serial connection. I have the Windows XP Firewall turned off. I've searched this board, and looked through the FAQ on the Ross-Tech site. I give up.
When I test Com Port 3, I get the message:
Port Status - OK
Interface: Found!
Type: Serial Pass-Through
Opto/Iso: No
Ross-Tech Design: No
After this, I hit the save button. However, no serial number for the software becomes visible. Also, when I exit the Vag-Com program and start it up, it indicates that it has never been tested/saved.
When I try to check any controller on the car, it cannot connect. Suggestions please. Thanks in advance.
Port Status - OK
Interface: Found!
Opto/Iso: No
Dell laptops almost always have the serial port on COM1. COM3 is most likely a Modem. Please check in Device Manager.
What does VAG-COM say when you sent the port to COM1 and click TEST?
-Uwe-
-Uwe-
http://www.Ross-Tech.com
When I test the Com 1 port with the VAG-COM cable connected, and car turned on, I get the message:
Port Status: OK
Interface: Not Found!
(The green LED is lit on the cable interface.)
That is why I have been messing with Com 3 which was of no use. Now, it seems like I need to do some tuning on Com 1. Any thoughts?
Port Status: OK
Go to device manager and set port settings for your com to 4800 baud, also hit advanced settings and lower the connection speeds. Then save and try it again. I had trouble with mine too.
You can install it in a different folder. We've had a couple of reports that the TWIN-COM doesn't work with 409 on a few PC's. You might have a PC like that. Anyway, I'd like to know if 311.2 behaves the same or differently.
-Uwe-
-Uwe-
Unfortunately, we've never had a PC here that behaves this way (i.e. works with 311.2 but not 409) so we've not been able to get a handle on the problem.
Yes, you can register 311.2.
-Uwe-
-Uwe-
LCP
VAG-COM Discussion
04-12-2006 10:22 AM
