Need help with cel code 1.8t jetta 2001 wolfsburg edition
1. 17608 Thinking the BPV.
2. 16804 Thinking bad cats.
3. 01314 Thinking battery dying or poor solder on ECU.
I cleared the codes and STFA to see whateveryting means. Just want to confirm what I've read so far. I don't drive this car since it's my girlfriends.I have included the full log we ran on her car. Any help is appreicated.
~Brad
Thursday, 25 August 2005, 18:02:29
VAG-COM Version: Release 504.1-D
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 16 15 17 19 22 35 46 56
Address 01: Engine
Controller: 06A 906 032 DL
Component: 1.8L R4/5VT G 0003
Coding: 07500
Shop #: WSC 13108
2 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00066
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1J0 920 905 J
Component: A4-KOMBIINSTR. VDO V52
Coding: 07232
Shop #: WSC 00066
IMMO-IDENTNR: VWZ7Z0Y2883239
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
Address 46: Central Conv.
Controller: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
End --------------------------------------------------------------------------------------------------
Thursday, 25 August 2005, 18:07:12
Address 01: Engine
Coding: 07500
Shop #: WSC 13108
Readiness: 0110 1101
Coding: 0018945
Shop #: WSC 00066
Coding: 07232
Shop #: WSC 00066
Coding: 00006
Shop #: WSC 00066
Coding: 04096
Shop #: WSC 00066
~Brad
Address 01: Engine
Coding: 07500
Shop #: WSC 13108
2 Faults Found:
P1200 - 35-00 - -
Coding: 0018945
Shop #: WSC 00066
Coding: 07232
Shop #: WSC 00066
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
Coding: 04096
Shop #: WSC 00066
Address 01: Engine
Coding: 07500
Shop #: WSC 13108
Coding: 0018945
Shop #: WSC 00066
Coding: 07232
Shop #: WSC 00066
Coding: 00006
Shop #: WSC 00066
Coding: 04096
Shop #: WSC 00066
If it does, that's why the VAG won't communicate with the ECU. I had the same problem, but if you go to ross tech they will tell you how to fix it. That is, IF she has an aftermarket radio in there.
As far as the cat. You might be right. I don't know how to test them for efficiency.
Take off the BPV and test it, then order a new one if it isn't working. How is the car boosting? Normal?
