Need help, trying to reset a fault - Address 52
Looking for some help. I'm having trouble resetting a fault that I receive after scanning my 2006 A6 (Chassis type 4F0). The fault code occurs at controller address 52 which maps to my "Door Elect, Pass". The fault points to "NO or Incorrect Basic setting / Adaptation" (see log file).
The passanger door itself functions properly along with its window and lock functions. The coding is 0035435, which is the same coding used on the driver door.
I received my VAG-COM interface about a week ago. So, I'm new at this and simply wanting a clean scan to occur. At the moment, I'm feeling a little uncertain.
Audi A6 (4F) Door Electronics Passenger
From Ross-Tech Wiki
Coding
* +0000002 = Interior Door Handle Illumination
* +0000004 = Insulated Glass installed (PR-4KR/4KV)
* +0000008 = Door Warning Lights installed
* +0000016 = Right Hand Steering (PR-L0R)
* +0000032 = Lighting Package (Interior Lighting - PR-QQ1)
* +0000064 = Lighting Package (Exterior Lighting - PR-QQ1)
* +0000128 = Outside Mirror Adjustment (Memory - PR-6XF/6XL)
* +0000256 = Mirror Heating NOT installed
* +0000512 = Interior Lock Switch installed
* +0001024 = Avant (Wagon)
* +0002048 = Electrical Child Safety Lock (PR-4H5)
* +0004096 = Opening Assistance
* +0008192 = Closing Assistance (PR-GZ2)
* +0016384 = Keyless-Entry installed (PR-4F2/4K5/4K7)
* +0032768 = Safe Function disabled (PR-A8U)
* +0065536 = Window Regulator Comfort Function disabled
* +0131072 = Handicapped Vehicle
* +0262144 = Special Protection Vehicle
* +0524288 = Pinch Protection disabled
Tuesday,07,April,2009,20:42:30:44949
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53
56 61 62 65 72 77
VIN: WAUDH74FX6N193560 Mileage: 95350km/59247miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: None
Part No SW: 4F1 910 559 E HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0070
Revision: --H15--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 02325 785 00200
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 4180510
Coding: 0000002
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000410988
Coding: 0000011
Shop #: WSC 02323 785 00200
Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 T HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 303D8067521140
Coding: 0000003
Shop #: WSC 02335 785 00200
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0170
Revision: 00000030 Serial number: 00000000264267
Coding: 0524326
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0010103
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH12 0090
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF7275648
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D6021880
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0B7W82
Coding: 0013878
Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026061280151
Coding: 0002021
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H12 0660
Revision: 00100000 Serial number: 4R815DR46
Coding: 0019263
Shop #: WSC 03134 444 83894
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008065060074
Coding: 6CFE53C51B3904
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 L
Component: MNS US H48 0990
Revision: 00000000 Serial number: 381KP067515123
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: 3uX
Coding: 0035435
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01013293400000
Coding: 4618301
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 22S00001 Serial number: 00202060217742
Coding: 0000006
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000024248
Coding: 0002114
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: sY
Coding: 0035435
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 95354 km
Time Indication: 0
Date: 2009.04.07
Time: 20:36:52
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 A HW: 4F0 907 801
Component: EPB CA3C0040 H03 0040
Revision: --H03---
Coding: 0005022
Shop #: WSC 02324 785 00200
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394EQ067641522
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000031710
Shop #: WSC 00000 384 00290
Part No: 4F0 915 105 C
Component: von VA0 2604280163
Coding: 344630393135313035432056413032363034323830313633
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0035370
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900022258
Coding: 0062221
Shop #: WSC 02334 785 00200
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H11 0700
Revision: 00000000 Serial number: 00000007538483
Coding: 0010900
From Ross-Tech Wiki
Coding
Chassis Type: 4F0
56 61 62 65 72 77
Coding: 0000002
Coding: 0020895
Coding: 0000011
Coding: 0000003
Coding: 0524326
Coding: 0010103
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0013878
Coding: 0002021
Coding: 0019263
Coding: 0035435
Coding: 4618301
Coding: 0000006
Coding: 0002114
Coding: 0035435
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 95354 km
Time Indication: 0
Date: 2009.04.07
Time: 20:36:52
Revision: --H03---
Coding: 0005022
Coding: 0000002
Coding: 0035370
Coding: 0062221
Coding: 0035370
Coding: 0010900
cardinalfan
10-27-2018 01:31 AM
chicago4.2
05-29-2010 05:18 PM
aklredaudi
01-24-2008 09:30 AM
