Need help with VAG codes... 2000 Audi A6 2.7t
VAG-COM Version: Release 409.1-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 4B0 907 551 L
Component: 2.7l V6/5VT G 0003
Coding: 06652
Shop #: WSC 02335
2 Faults Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 4B0 927 156 BD
Component: AG5 01V 2.7l5VT USA 3131
Coding: 00032
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08: Auto HVAC
Controller: 4B0 820 043 K
Component: A6-Klimavoll
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 4B0 907 487
Component: E Lenkrad Elektronik D03
Address 17: Instruments
Controller: 4B0 920 980 M
Component: C5-KOMBIINSTR. VDO D09
Coding: 02264
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02335
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 A
Component: Sitzmemory D05
Address 45: Inter. Monitor
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02335
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00006
Shop #: WSC 02335
1 Fault Found:
00774 - Level Control System Sensor: Left Rear (G76)
31-00 - Open or Short to Ground
Address 56: Radio
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 02335
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 06652
Shop #: WSC 02335
2 Faults Found:
Coding: 00032
Shop #: WSC 00000
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
Coding: 02264
Shop #: WSC 00000
Coding: 15885
Shop #: WSC 02335
Coding: 00101
Shop #: WSC 02335
Coding: 00006
Shop #: WSC 02335
1 Fault Found:
Address 56: Radio
Coding: 00115
Shop #: WSC 02335
1 Fault Found:
00-00 - -
Take a look at our WIKI. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Address 01: Engine
http://wiki.ross-tech.com/index.php/17963/P1555/005461
http://wiki.ross-tech.com/index.php/18014/P1606/005638
http://wiki.ross-tech.com/index.php/01203
http://wiki.ross-tech.com/index.php/00774
Address 56: Radio
http://wiki.ross-tech.com/index.php/65535
Address 01: Engine
Address 56: Radio
98Quattro
13
05-11-2011 03:31 PM
CvTech
Audi 100 / A6 (C4 Platform)
02-15-2008 05:28 AM
