Need a little help: "005 - No or Incorrect Basic Setting / Adaptation"
I have a 2007 Q7 that sustained some rear end damage and the body shop ended up replacing one of the two Side-Assist (aka Lane Change) modules for a brand new one.
The Side Assist system won't turn on initially because it wasn't coded properly. I resolved that (I believe) by copying the coding from a prior Auto-Scan of mine.
I'm now getting the fault code "005 - No or Incorrect Basic Setting / Adaptation" but I'm not sure where to go from here. I've stepped through all of the adaptation channels but there isn't a label file for this module. My Bentley doen't make mention about what to do (or I'm just not looking in the right place).
I'm loathe to bring the car back to the body shop since it's about 45 minutes away and I'd probably have to pack up the three kids, take 2 cars and leave the Q7 there so they could try to figure this out (I'd argue they would have coded it properly the first time if they had a clue).
Anyway, here's the fault code. Ideas? Is fixing this strictly a dealer-only thing (e.g. is this related to calibration)
1 Fault Found:
02849 - Control Module for Lane Change Assistance (J769)
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 27704 km
Time Indication: 0
Date: 2008.07.26
Time: 17:50:50
Full Auto Scan below...
VCDS Version: Release 805.0
Data version: 20080625
Saturday,26,July,2008,20:13:34:56696
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 36 37 3C 42 46 47
4F 52 55 56 61 62 65 67 69 6C 6D 6F 72 76 77
VIN: Mileage: 27700km/17211miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0060
Revision: 71H16--- Serial number:
Coding: 01210009190F0160
Shop #: WSC 01115 444 54714
No fault code found.
Readiness: 0010 1100
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FH HW: 09D 927 750 FH
Component: AL 750 6A 0959
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
Address 03: ABS Brakes Labels: 4L0-910-517.lbl
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0017457
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100538356
Coding: 0000135
Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 354IZ067507845
Coding: 0002003
Part No: 4L0 910 609
Component: E0380 BedienteilH02 0060
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Mileage: 27706 km
Time Indication: 0
Date: 2008.07.26
Time: 20:07:18
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---009 Serial number: 00000000065285
Coding: 0786472
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0113123
Part No: 4L1 910 113
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH12 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3045519
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F1041412
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 203
Mileage: 27706 km
Time Indication: 0
Date: 2008.07.26
Time: 17:52:51
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD038R02
Coding: 0014131
Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90026062420303
Coding: 0012242
Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0120
Revision: 00600000 Serial number: 5HH192N96
Coding: 2641203
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06821801F
Coding: F7F7FE77347A02
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---007 Serial number: 00000000072730
Coding: 0000006
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 D
Component: MNS US H48 0970
Revision: 00000000 Serial number: 313HV067505975
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0000001
Shop #: WSC 00266 000 00000
Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 27704 km
Time Indication: 0
Date: 2008.07.26
Time: 17:50:50
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: <em>f</em>7-
Coding: 0051915
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01019572350000
Coding: 7633053
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H02 0150
Revision: PROD_01 Serial number: 00000000016116
Coding: 0000026
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000038285
Coding: 0012001
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: $
Coding: 0051915
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388I.067554532
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000045246
Shop #: WSC 01059 444 83846
Part No: 4F0 915 105 D
Component: von VA0 2609091940
Coding: 344630393135313035442056413032363039303931393430
Address 62: Door,Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900031407
Coding: 0062424
Shop #: WSC 00226 347 116111
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 8
Reset counter: 243
Mileage: 27696 km
Time Indication: 0
Date: 2008.07.26
Time: 16:54:12
Freeze Frame:
(no units): 42.0
Temperature: 32.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000609140038
Shop #: WSC 12336 024 394758
Address 69: Trailer (J345) Labels: None
Part No SW: 4E0 907 383 E HW: 4E0 907 383 E
Component: Anhaenger H14 0080
Revision: 2A002001 Serial number: 00000109325962
Coding: 0100000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J69401N
Coding: 1001101
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Part No: 4L0 910 946
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002013136-----
Coding: 0003595
Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220624703315
Coding: 0221246
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H13 0950
Revision: 00000000 Serial number: 00000007542868
Coding: 0010900
End ---------------------------------------------------------------------
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 27704 km
Time Indication: 0
Date: 2008.07.26
Time: 17:50:50
Chassis Type: 4L0
Coding: 0000504
Revision: 00H21001
Coding: 0017457
Coding: 0000135
Coding: 0002003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Mileage: 27706 km
Time Indication: 0
Date: 2008.07.26
Time: 20:07:18
Coding: 0786472
Coding: 0113123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 203
Mileage: 27706 km
Time Indication: 0
Date: 2008.07.26
Time: 17:52:51
Coding: 0014131
Coding: 0012242
Coding: 2641203
Coding: 0000006
Coding: 0082954
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 27704 km
Time Indication: 0
Date: 2008.07.26
Time: 17:50:50
Coding: 0051915
Coding: 7633053
Coding: 0000026
Coding: 0012001
Coding: 0051915
Coding: 0000021
Coding: 0000002
Coding: 0051722
Coding: 0062424
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 8
Reset counter: 243
Mileage: 27696 km
Time Indication: 0
Date: 2008.07.26
Time: 16:54:12
Freeze Frame:
(no units): 42.0
Temperature: 32.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1001101
Coding: 0003595
Coding: 0051722
Coding: 0221246
Coding: 0010900
..the whole thing involves some pretty expensive additional tools. In other words, due to the missing equipment I doubt that either you or the body shop have access to that and therefor I would consider this a dealer only job. Sorry.
the various VAS 6350 calibration devices necessary to properly calibrate the system. I was hoping that I might be able to kick the system into operation until I get to the dealer for my next scheduled service visit in a few thousand miles (even in an uncalibrated mode). Hopefully my insurance company will reimburse me for the dealer's time/labor.
Thanks again!
Mike
Thanks again!
Mike
Sumners3
A4 (B8 Platform) Discussion
05-31-2019 11:48 PM
