New Airbag Woes
Happy new 2012 S4 owner here, see how i toiled and got to
the right connections to activate horn, backlight, and MFC:
http://www.audizine.com/forum/showth...-Kandiru/page2
After installing an Audi round airbag # 8J0 880 201 J 6PS to
compliment my R8 V10 steering wheel i get following problems:
1. AIRBAG light on tachymeter
2. "Parking Brake Failure" on center display, but electronic
e-brake works just fine.
Assuming i got the wiring right, see link above for the order
i put them in, is it possible that all i need is to follow the
procedure here to allow the controller to recognize new airbag?
http://www.ross-tech.com/vag-com/car...ag-coding.html
Or am i dealing with a faulty or miswired airbag? Those who know can check my pinouts on page 1 of above post:
http://www.audizine.com/forum/showth...-Kandiru/page1
Also, if i clear codes and reassign the 2 digit "Airbag Index", will the codes come back if the bag where truly defective?
Your input much apprecited, i will fire up VCDS tonight and look around the modules. VCDS virgin BTW
OK, brand new airbag, same part number with an "L" instead of the J before the final 3 digits and a nice silver ring around the 4 rings, same errors, i am desperate.
On the bright side it appears that the ABS and Parking Brake errors are related to the airbag, so i did not fry any modules. I did insert the key all the way in again every time after battery disconnect.
From what i read faulty wiring can do this, but i did my best using VAG specific tools to repin the new airbag into the S4 connector.
I have full horn, MFC, but get Airbag and Parking Brake Malfunction errors.
HELP!!!
$349 later, here is the spitout, FYI the intermittent contact at radio went away after i stuffed soft wire insulation into the purple retaining rod's tract, no way it could be reinserted without fracture after the brutal pin extractions, i also rechecked the pins for shorts and contact:
Saturday,20,August,2011,13:27:44:39785
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 8T0
Scan: 01 03 05 08 09 15 16 17 19 22 2E 36 42 46 47 52 53 55 56 62
72 77
VIN: WAUDGBFL2CA017467 Mileage: 480km/298miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CCBA) Labels: None
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H08 0001
Revision: --H08---
Coding: 0104000A180F0128
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001001
ROD: N/A
VCID: 32611EB2D4BF
No ASAM data for: "EV_ECM30TFS0218K0907551D" (AU48)
No fault code found.
Readiness: 1110 1101
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 280D1A
VCID: 82010E72A49F
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 482 km
Time Indication: 0
Date: 2010.01.22
Time: 00:45:21
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0032
Hex Value: 0x02AE
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 0B0100
Shop #: WSC 06325 000 00000
VCID: 76E9E2A27857
Part No SW: 8T0 959 754 AD HW: 8T0 959 754 AD
Component: FBSAUDIB8 IDG H60 0072
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01220620110698
Coding: 66002000
VCID: 8005047AAA93
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 65
Mileage: 482 km
Time Indication: 0
Date: 2010.01.22
Time: 00:00:55
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000952773
Coding: 26001091063CAF212600080300003D0D0F1C92480201016100 0000
VCID: 3C7D308A06FB
Part No SW: 8K1 955 119 A HW: 8T1 955 119
Component: WWS 220611 H07 0070
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0NN7CW
Coding: 303937354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 458B556E7531
Seat occupied recognition:
Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R11000045GK
Driver's Airbag Crash Sensor:
Serial number: 6334MSME611555512
Passenger Side Airbag Crash Sensor:
Serial number: 6344MSME5F66246CU
Driver's Rear Airbag Crash Sensor:
Serial number: 6352QSME240C2B7AP
Passenger's Rear Airbag Crash Sensor:
Serial number: 6362QSME2E0D0172H
Driver's Front Airbag Crash Sensor:
Serial number: 63732SME250D2042R
Passenger's Front Airbag Crash Sensor:
Serial number: 63832SME250D2252V
2 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 482 km
Date: 2010.01.22
Time: 00:52:12
9437467 - Igniter 2 for Driver's Airbag
B1001 1B [136] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 482 km
Date: 2010.01.22
Time: 00:00:56
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KFN000LA
Coding: 000016
VCID: 3E793A8210E7
Component: E221 - MFL H06 0003
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Time Indication: 0
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 981 R HW: 8K0 920 981 R
Component: KOMBIINSTR. H05 0258
Revision: 00100000 Serial number: EJ723FH6C
Coding: 8B1509008300D705020000
VCID: 42814E72641F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G11604856B
Coding: 00C303
VCID: 8103017EA199
Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
Component: 4 Wheel Drive H12 0025
Serial number: 001406110001020
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2E590AC2C087
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 3973299E09C9
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00000006311385
Coding: 00581300000000000000
VCID: 3B7F339603F5
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C03204E00410001
VCID: 53AF7B368B65
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0152572387
Coding: 0106023A00FA444480B0013200000000
VCID: 76E9E2A27857
Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H07 0041
Address 47: Sound System (J525) Labels: None
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34816000520502
Coding: 0203010302
VCID: 7EF9FA825067
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52A17E32B47F
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000814565
Shop #: WSC 00000 000 00000
VCID: 346D18AA2EAB
1 Fault Found:
01321 - Control Module for Airbags (J234)
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 2
Reset counter: 25
Mileage: 482 km
Time Indication: 0
Date: 2010.01.22
Time: 00:47:59
Freeze Frame:
Voltage: 14.10 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 3973299E09C9
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000010 Serial number: AUZ5Z6K1604565
Coding: 040300020101850043D9070804
VCID: 468952624837
Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1501
Coding: 010C03204000210001
VCID: 56A982229897
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1501
VCID: 56A982229897
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005230802
Coding: 0010370
VCID: 3E793A8210E7
End ---------------------------------------------------------------------
HELP!!!
Chassis Type: 8T0
72 77
Revision: --H08---
ROD: N/A
VCID: 32611EB2D4BF
Coding: 280D1A
VCID: 82010E72A49F
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 482 km
Time Indication: 0
Date: 2010.01.22
Time: 00:45:21
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0032
Hex Value: 0x02AE
Hex Value: 0x00FF
Revision: 00002001
Coding: 0B0100
VCID: 76E9E2A27857
Coding: 66002000
VCID: 8005047AAA93
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 65
Mileage: 482 km
Time Indication: 0
Date: 2010.01.22
Time: 00:00:55
VCID: 3C7D308A06FB
Coding: 00FD11
Coding: 025028
VCID: 458B556E7531
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 482 km
Date: 2010.01.22
Time: 00:52:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 482 km
Date: 2010.01.22
Time: 00:00:56
Coding: 000016
VCID: 3E793A8210E7
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Time Indication: 0
VCID: 42814E72641F
Coding: 00C303
VCID: 8103017EA199
VCID: 2E590AC2C087
Revision: 00000000
Coding: 020302
VCID: 3973299E09C9
VCID: 3B7F339603F5
VCID: 53AF7B368B65
VCID: 76E9E2A27857
Coding: 0203010302
VCID: 7EF9FA825067
VCID: 52A17E32B47F
VCID: 346D18AA2EAB
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 25
Mileage: 482 km
Time Indication: 0
Date: 2010.01.22
Time: 00:47:59
Freeze Frame:
Voltage: 14.10 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Coding: 0000004
VCID: 3973299E09C9
VCID: 468952624837
Component: Display
VCID: 56A982229897
VCID: 56A982229897
Coding: 0010370
VCID: 3E793A8210E7
Eureka!!!
Igniter #1 and 2 at module 15 showed "resistance too high", reading a lot, and out of desperation i took the airbag off again and did a "tuneup" on my pin reinstall job, painstakingly cleaning every pin on the clockspring and MMI connectors using wire insulation dipped in alcohol
then used a small drill to enlarge the diameter of the harness openings just a bit, then rubbed inside the females (yum) with alcohol then very little rosin. The pin extraction business is a messy job, even with VAG specific tools, as the micro molex females have a spine to snap into the middle groove and permanently rest there, extraction breaks this off.
I then did reattach, but alas, still codes. Then VCDS with fault deletion, and off went the airbag error, followed by the parking brake, lastly a third sweep killed the ABS error. Now i am left with a misterious sound system error that is enumerated initially but failed to show up in the log,
$344 well deserved to Ross-Tech, knowing also all the little additions that will follow.
Here is the 4th and final spitout, reproducible x2, after the VAG "code laundry":
Sunday,21,August,2011,20:34:36:39785
Chassis Type: 8T0
72 77
VIN: WAUDGBFL2CA017467 Mileage: 530km/329miles
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
Revision: --H08---
ROD: N/A
VCID: 32611EB2D4BF
Coding: 280D1A
VCID: 82010E72A49F
Revision: 00002001
Coding: 0B0100
VCID: 76E9E2A27857
Coding: 66002000
VCID: 8005047AAA93
VCID: 3C7D308A06FB
Coding: 00FD11
Coding: 025028
VCID: 458B556E7531
Coding: 000016
VCID: 3E793A8210E7
VCID: 42814E72641F
Coding: 00C303
VCID: 8103017EA199
VCID: 2E590AC2C087
Revision: 00000000
Coding: 020302
VCID: 3973299E09C9
VCID: 3B7F339603F5
VCID: 53AF7B368B65
VCID: 76E9E2A27857
Coding: 0203010302
VCID: 7EF9FA825067
VCID: 52A17E32B47F
VCID: 346D18AA2EAB
Coding: 0000004
VCID: 3973299E09C9
VCID: 468952624837
Component: Display
VCID: 56A982229897
VCID: 56A982229897
Coding: 0010370
VCID: 3E793A8210E7
Chassis Type: 8T0
72 77
Revision: --H08---
ROD: N/A
VCID: 32611EB2D4BF
Coding: 280D1A
VCID: 82010E72A49F
Revision: 00002001
Coding: 0B0100
VCID: 76E9E2A27857
Coding: 66002000
VCID: 8005047AAA93
VCID: 3C7D308A06FB
Coding: 00FD11
Coding: 025028
VCID: 458B556E7531
Coding: 000016
VCID: 3E793A8210E7
VCID: 42814E72641F
Coding: 00C303
VCID: 8103017EA199
VCID: 2E590AC2C087
Revision: 00000000
Coding: 020302
VCID: 3973299E09C9
VCID: 3B7F339603F5
VCID: 53AF7B368B65
VCID: 76E9E2A27857
Coding: 0203010302
VCID: 7EF9FA825067
VCID: 52A17E32B47F
VCID: 346D18AA2EAB
Coding: 0000004
VCID: 3973299E09C9
VCID: 468952624837
Component: Display
VCID: 56A982229897
VCID: 56A982229897
Coding: 0010370
VCID: 3E793A8210E7
Coding: 0203010302
VCID: 7EF9FA825067
Coding: 0203010302
VCID: 7EF9FA825067
The fault listed in the 19-CAN Gateway installation list may be a fluke. Try the [Clear All DTCs] feature on the Auto-Scan screen followed by a key cycle, and possibly operating the radio/amp, and see if it returns. The Address 47-Sound System itself would have a fault code if something was actually wrong.
tipo158
09-25-2006 09:43 PM
i8pancit
04-29-2004 09:42 PM
