New cluster.. No NAV. VAG Error
Okay, so I finally took care of that faded dash that I have had for the longest time. I picked up a 2001 S4 Cluster with the old logo so that it matches mine.
I install it no problem, everything works good. Except for my NAV. I looked at the part numbers and its the same. I tried to look at Ross-Tech's page for the coding, and I tried to put it in, but it still is no go.
I am getting this error from VAG:
Block 37:Navigation:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4B0 919 887 B
Component and/or Version: Navigation BNO 0001
Software Coding:
Work Shop Code:
1 Fault Found:
01311 - Information Data Bus
49-10 - No Communications - Intermittent
Anyone have any ideas?
Thanks!
AlexM.
Software Coding:
Work Shop Code:
1 Fault Found:
Thanks!
AlexM.
DTC:
01311
Data Bus Information 2)
No communication
Possible Cause:
The central unit and the navigation unit which are connected to each other via a CAN-bus are located in the navigation control module.
Internal short circuit or short circuit to Ground (GND) of a bus wire between the central unit and the navigation unit in navigation control module.
Corrective Action:
- Navigation control module does not have to be replaced if the system remains functional (the control module then switched to one-wire operation).
- The control module must be replaced if the system no longer functions.
2) This DTC indicates a databus malfunction in the internal data wire between the central unit and navigation unit inside the navigation control module.
01311
No communication
Possible Cause:
Corrective Action:
EuroVWGTi
02-27-2008 11:03 AM
S4Alex
08-07-2005 07:34 PM
Imola Ghost
VAG-COM Discussion
07-12-2003 09:04 AM
