No ABS or ESP
I just finished installing my new Steering angle sensor.
I was getting the following code:
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 00000
Shop #: WSC 00000
VCID: 356FF6550FE307B0C23
1 Fault Found:
00778 - Steering Angle Sensor (G85)
37-00 - Faulty
After Installation I got this code:
Coding: 00000
Shop #: WSC 00000
3 Faults Found:
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
27-10 - Implausible Signal - Intermittent
So Then I matched it using VCDS, I get this code:
Control Module Part Number: 8D0 907 389 E
Component and/or Version: ABS/ESP allrad D56
Software Coding: 04397
Work Shop Code: WSC 00000
1 Fault Found:
01486 - System Function Test Activated
35-00 - -
I figured the new ($600) Steering angle sensor would get me my ESP and ABS back, but so far the lights are still on in the instrument panel. Anyone have any ideas?
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
37-00 - Faulty
Coding: 00000
Shop #: WSC 00000
3 Faults Found:
35-00 - -
1 Fault Found:
35-00 - -
Have a look here http://wiki.ross-tech.com/wiki/index.php/01486
After 2 years, $600. I finally have my ABS and traction control Working again.
ESP not working
ABS not working
Audi s4 2002 ESP/ ABS lights on.
Steering angle sensor not matching
Steering angle sensor calibration
ABS calibration
Send me a PM on here if you need a hand With these issues. Took me the weekend to figure it out as there is not a lot of material online from start to finish about how to get everything working.
marcogyver
VAG-COM Discussion
06-07-2016 04:06 PM
My2ndS4
08-10-2005 02:44 PM
