No ODB communication
2009 Audi S8 no odbII communication
back story
picked up car at auction as a personal challenge
steering wheel locked
Key locked in ignition
Lights will come on for mileage and clock on dash - nothing else
No MMI function
Passenger seat moves
Drivers seat and windows do not function
Power to ODBII port, but no communication
magic trick (Brake, hazard, headlights, high beam) to wake up ODBII does not work.
in my line of troubleshooting I am thinking either chewed wiring or bad ECU to test first
Thoughts?
back story
No MMI function
Thoughts?
The OBD CAN lines go back directly to the J533. Either it's unpowered or broken or asleep. With who knows what broken on the car, if it's not getting wake signal from anything on the CAN buses, I wonder if pulling and putting back the fuse for it would wake it. But probably need to drop the glove box and confirm 12v on the term 30 (battery) to term 31 (ground) pins on the J533, as well as the OBD-II port. That's pin 1 to pin 11 on the J533 20-pin plug, and pin 16 to pin 4 and pin 5 (both 4 and 5 are ground) on the OBD 16-pin plug. Both devices' term 30 comes from fuses in column brown on the passenger end of the dash: fuse 5 for the J533 and fuse 11 for the OBD. Note, the fuses on the passenger end are counted bottom to top, not top to bottom.
Was looking through wiring diagrams on the J533 but that helps immensely. Glove box is already dropped and I think I verified all circuits for voltage but will double check as I am just getting back to this car. All fuses have been checked and replaced on both cabin sides and trunk and relay carrier. Relays have been tested for function but not replaced. I did not know that about the passenger side fuses. I will re-inspect.
I also replaced the gateway module J533 to see if that was it with no change.
Kessy module looks clean with no water intrusion at all in it or the floorboard area.
Thanks for the ideas
That's why I start small. The scan tool talks to the J533. The whole situation involves term 30 and term 31 to the OBD-II port and to the J533, and the two CAN lines between the devices. If that's not working, that's the whole little world I have to look into; everything else is irrelevant until the scan tool is talking to the J533. If you tried a second J533, then I have to assume it's something with voltage at the plugs or the CAN lines between the plugs. Diagnose Dan did a video where we woke the J533 by jumpering term 30 to the term 15 connection (find the J533 term 15 fuse; the black columns on the dash ends are term 15; pull the fuse and confirm which side of the fuse socket goes to the J533, fuse tap one of the term 30 fuses over to that connection to pass 12v to the J533 term 15 pin). OBD-II port also has a term 15 connection (pin 1) and fuse in passenger end black column, but shouldn't be relevant for the scan tool to work.
zen beer (10-27-2023)
Progress, Huge thanks @SMac770 I was able to jump power and get access to the ODBII system watching Diagnosis DAN and your notes + a wiring diagram. Lots of unable to communicate to different systems and the Auth start stop looks to be triggered with a component protection active code. Based upon how many modules can't communicate and Dan's video I am guessing the Central control module. Can I VIN swap a used CCM and then reset the component protection in VCDS?
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Looks like I will head over to vcds to figure out component protection unless someone else has an idea
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
The J393 is the immobilizer master (ie, key recognition and vehicle access/start authority). So swapping it is never a simple task, unless you happen to have ODIS and the necessary privilege to run the immobilizer adaptation (so same concept as component protection, just more scrutinized). VCDS cannot address component protection or the immobilizer. You'll need a dealership or shop or someone with that specifically identified ability (immobilizer V adaptation).
Which module is that CP active message from? CP active will always be an "annoyance issue", never a core functionality off issue. So comms errors will never be a result of CP.
Cannot communicate would not be specific to the J393 being toast. But, to see if more modules would "wake", you'd want to go to the term 15 relay (under the dash, behind the headlamp switch) and bypass the relay to jumper the term 30 supply to the term 15 output. This is normally controlled by the J393, but if the J393 is out to lunch, we can still do it manually and see what all comes on.
But yet, J393 being non-responsive on the CAN, lot of modules will be displeased, even if they are now awake. Unless I'm misunderstanding something. This best to just always post the complete autoscan log unabridged so there's no confusion on what's being presented.
Code:
Saturday,28,October,2023,14:31:38:41228 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4 Data version: 20230421 DS346.2 www.Ross-Tech.com VIN: WAUPN94E09N007103 License Plate: Mileage: 158930km-98754mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77 VIN: WAUPN94E09N007103 Mileage: 158930km-98754miles 00-Steering Angle Sensor -- Status: Cannot be reached 1100 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: Malfunction 1010 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 1010 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: Cannot be reached 1100 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Sporadic communication error 1000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Cannot be reached 1100 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Sporadic communication error 1000 37-Navigation -- Status: Cannot be reached 1100 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 1010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 1010 53-Parking Brake -- Status: Cannot be reached 1100 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: Malfunction 1010 62-Door, Rear Left -- Status: Malfunction 1010 65-Tire Pressure -- Status: Malfunction 1010 67-Voice Control -- Status: Cannot be reached 1100 6C-Back-up Cam. -- Status: Malfunction 1010 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 1010 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine (BSM) Labels:. 07L-910-552-BSM1.clb Part No SW: 4E0 910 552 K HW: 4E0 907 552 A Component: 5.2L V10/4V FSI 0040 Revision: 5IH03--- Serial number: AUX3Z0H8757274 Coding: 01060009190F0160 Shop #: WSC 02313 785 00200 VCID: 2A0D135EC0F5399A71F-807E VINID: 9D19607891150097800070400C4B333AB1 8 Faults Found: 005715 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent Freeze Frame: Fault Status: 00111000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 158844 km Time Indication: 0 Date: 2022.01.29 Time: 00:36:02 Freeze Frame: RPM: 1392 /min Load: 37.2 % Speed: 0.0 km/h Temperature: 24.0 C Temperature: 26.0 C Absolute Pres.: 990.0 mbar Voltage: 10.922 V 005634 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0 C Temperature: -40.0 C Absolute Pres.: 0.0 mbar Voltage: 0.000 V 008852 - Fuel Pressure Regulator Valve (N276) P2294 - 004 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V 050197 - Implausible Data Received from ABS Control Module U0415 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.684 V 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V 049441 - No Communication with ABS Brake Control Module U0121 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V 049446 - No Communications with Steering Angle Sender (G85) U0126 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V 053250 - Please Check Fault Codes in Comfort System Control Module (J393) U1002 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E2 910 156 C HW: 09E 927 156 B Component: AG6 09E 5,2 FSI USA 0030 Revision: --H04--- Serial number: 0128185 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 2411FD66A2D1EFEA4B3-8070 9 Faults Found: 049448 - No Communications with Parking Brake Control Module U0128 - 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:05:56 049446 - No Communications with Steering Angle Sender (G85) U0126 - 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:05:56 049442 - No Communication with ESP (Vehicle Dynamics) Control Module U0122 - 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:05:56 049682 - Steering Column Control Module U0212 - 000 - No Communications - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 049493 - No Communication with Instrument Cluster U0155 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 049478 - No Communication with Diagnostic Gateway U0146 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 053258 - No Communications with Control Module for Access/Start Authorization U100A - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 006231 - Load Signal P1857 - 001 - Error Message from ECU Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 006246 - Powertrain Data Bus P1866 - 000 - Missing Messages - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Cannot be reached ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 907 181 C Component: FBS AUDID3 H12 0200 Revision: 02005112 Serial number: AUX3Z0H8757274 Coding: 0410624 Shop #: WSC 18248 003 1048576 VCID: 58E99996AE197B0A17B-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 2 Faults Found: 00576 - Terminal 15 006 - Short to Plus Freeze Frame: Fault Status: 01100110 Fault Priority: 2 Fault Frequency: 0 Reset counter: 20 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:30:42 01176 - Key 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:00 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071520 Shop #: WSC 02313 785 00200 VCID: 2411FD66A2D1EFEA4B3-8070 3 Faults Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 14 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:01:33 01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 4 Fault Frequency: 2 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:02:04 01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 4 Fault Frequency: 2 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:02:04 ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000156048 Coding: 0041281 Shop #: WSC 02313 785 00200 VCID: 1C61C5869AA1D72AF33-8048 4 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 5 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:06:09 Freeze Frame: Bin. Bits: 00011111 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 59 Mileage: 0 km Time Indication: 0 Freeze Frame: OFF 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 59 Mileage: 0 km Time Indication: 0 Freeze Frame: OFF 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 59 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Cannot be reached Unable to communicate with address 09. Are you sure the doors are unlocked? ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 11: Engine II Labels:. 07L-910-552-BSM2.clb Part No SW: 4E0 910 552 K HW: 4E0 907 552 A Component: 5.2L V10/4V FSI 0040 Revision: 5IH03--- Serial number: AUX3Z0H8757274 Coding: 01060009190F0160 Shop #: WSC 02313 785 00200 VCID: 2A0D135EC0F5399A71F-807E 8 Faults Found: 012326 - Angle Sensor 1 for Throttle Drive 2 (G297) P3026 - 002 - Signal too Small Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 20.0 C Absolute Pres.: 990.0 mbar Voltage: 11.684 V 012329 - Angle Sensor 2 for Throttle Drive 2 (G298) P3029 - 002 - Signal too Small Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 20.0 C Absolute Pres.: 990.0 mbar Voltage: 11.684 V 004763 - Fuel Pressure Regulator Valve; Bank 2 (N276) P129B - 004 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.430 V 005634 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0 C Temperature: -40.0 C Absolute Pres.: 0.0 mbar Voltage: 0.000 V 050197 - Implausible Data Received from ABS Control Module U0415 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.684 V 049441 - No Communication with ABS Brake Control Module U0121 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V 049446 - No Communications with Steering Angle Sender (G85) U0126 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.557 V 053250 - Please Check Fault Codes in Comfort System Control Module (J393) U1002 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 14.0 C Temperature: 19.0 C Absolute Pres.: 990.0 mbar Voltage: 11.430 V ------------------------------------------------------------------------------- Address 15: Airbags Labels: None Part No SW: 4E0 910 655 F HW: 4E0 959 655 L Component: Airbag 9.41 H01 4230 Revision: 91H01423 Serial number: 003CV00049DT Coding: 0532707 Shop #: WSC 02313 785 00200 VCID: 290FEC52C5F33282785-807C Subsystem 1 - Part No: 4E0 910 339 C Component: BF-Gewichtsens. H02 0040 Subsystem 2 - Serial number: 032BU Subsystem 3 - Serial number: 0001.01.0000H0200000000000 63 Subsystem 4 - Serial number: 000000 63328RB403FD7F30Y 63 Subsystem 5 - Serial number: D7F30Y 63428RB403FDBFD17 63 Subsystem 6 - Serial number: DBFD17 63528RB403FD7E0C1 63 Subsystem 7 - Serial number: D7E0C1 63628RB403FDC00F$ 63 Subsystem 8 - Serial number: DC00F$ 63729RB403F211FBV 63 Subsystem 9 - Serial number: 211FBV 63829RB403F21667O Subsystem 10 - Serial number: 21667O 7 Faults Found: 02095 - Component Protection Active 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:09 01316 - ABS Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:09 00589 - Airbag Igniter 1; Passenger Side (N131) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:11 00590 - Igniter 2 for Passenger Airbag (N132) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:11 01742 - Igniter for Knee Airbag; Drivers Side (N295) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:12 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:12 01743 - Igniter for Knee Airbag; Pass. Side (N296) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:12 ------------------------------------------------------------------------------- Address 16: Steering wheel Cannot be reached ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 N HW: 4E0 920 951 N Component: KOMBIINSTR. VDO H83 0640 Revision: D05 Serial number: AUDID3H7100005 Coding: 0048283 Shop #: WSC 59040 001 1048576 VCID: 30390136E629434ABFB-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0071 Revision: 00H06000 Serial number: 1100B08706807A Coding: F5D5DFFF707A0E00 Shop #: WSC 50324 003 1048576 VCID: 2D071842F11B2EA294D-8078 16 Faults Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 34 Reset counter: 58 Mileage: 158145 km Time Indication: 0 Date: 2021.12.17 Time: 19:35:53 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 58 Mileage: 158844 km Time Indication: 0 Date: 2022.01.29 Time: 00:35:59 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:05:55 01316 - ABS Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:05:55 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:05:55 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:57 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.22 Time: 00:54:36 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:03 01327 - Control Module for Parking Aid (J446) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:03 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:12 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:14:52 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:36:32 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:03 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:26 00457 - Central Electronics Control Module / BCM (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:01:23 02873 - Control Module for Back-Up Camera (J772) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 60 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:01:23 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 L HW: 4E0 907 553 H Component: LUFTFDR.-CDC H07 6340 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2C011546CA0127AA833-8078 2 Faults Found: 01316 - ABS Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:10 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:10 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Cannot be reached ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 38: Roof Electronics Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 801 F Component: T rsteuer.FS BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: 2019F176B6C9F3CA2FB-8074 5 Faults Found: 02114 - Central Locking Key Button (E391) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 60 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:01:46 02124 - Exterior Door Handle Switch 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 60 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:01:26 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 02128 - Door Closing Control Module (J657) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:21:08 01336 - Company Data Bus for Comfort System 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 E HW: 4E0 907 289 E Component: Komfortgeraet H11 0040 Revision: 00400011 Serial number: W040808290096 Coding: 0048686 Shop #: WSC 02313 785 00200 VCID: 2B03165ACF0F20928A9-807E Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 4 Faults Found: 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 20 Mileage: 135224 km Time Indication: 0 Date: 2019.11.13 Time: 20:04:01 00576 - Terminal 15 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 12 Reset counter: 20 Mileage: 0 km Time Indication: 0 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 6 Reset counter: 20 Mileage: 0 km Time Indication: 0 01316 - ABS Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 39 Reset counter: 20 Mileage: 158936 km Time Indication: 0 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000013431 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 1E65CF8E8CBDC53A1D7-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 F Component: T rsteuer.BF BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: 2019F176B6C9F3CA2FB-8074 5 Faults Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 14 Reset counter: 20 Mileage: 154976 km Time Indication: 0 Date: 2021.09.11 Time: 02:07:08 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 60 Mileage: 0 km Time Indication: 0 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 53: Parking Brake Cannot be reached ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 HW: 4L0 907 357 Component: AFS 1 H01 0040 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 698FAC520573F282B85-803C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 4 Faults Found: 01316 - ABS Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:09 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:09 02627 - Dynamic Cornering Light Motor; Left (V318) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:13 01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:13 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000015229 Shop #: WSC 02503 444 59525 VCID: 2019F176B6C9F3CA2FB-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 390306619R Coding: 344530393135313035412056413033393033303636313952 Shop #: WSC 18248 003 1048576 2 Faults Found: 02273 - Quiescent Current Stage 2 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:08 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:27:09 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: T rsteuer.HL BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: 1E65CF8E8CBDC53A1D7-804A 5 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 60 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:01:40 02128 - Door Closing Control Module (J657) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 0 Reset counter: 40 Mileage: 0 km Time Indication: 0 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000900059598 Coding: 0232428 Shop #: WSC 02313 785 00200 VCID: 2019F176B6C9F3CA2FB-8074 4 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent - MIL ON Freeze Frame: Fault Status: 10100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 40 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:07 Freeze Frame: (no units): 0.0 Voltage: 0.00 V (no units): 33.0 Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 58 Mileage: 0 km Time Indication: 0 Freeze Frame: (no units): 0.0 Voltage: 2.30 V (no units): 42.0 Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent - MIL ON Freeze Frame: Fault Status: 10100100 Fault Priority: 3 Fault Frequency: 36 Reset counter: 40 Mileage: 0 km Time Indication: 0 Freeze Frame: (no units): 0.0 Voltage: 0.00 V (no units): 30.0 Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C 01336 - Company Data Bus for Comfort System 014 - Defective - MIL ON Freeze Frame: Fault Status: 11101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 0 Mileage: 0 km Time Indication: 0 Freeze Frame: (no units): 0.0 Voltage: 5.70 V (no units): 31.0 Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C Temperature: 0.0 C ------------------------------------------------------------------------------- Address 67: Voice Control Cannot be reached ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: T rsteuer.HR BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: 1E65CF8E8CBDC53A1D7-804A 5 Faults Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 118 Mileage: 154976 km Time Indication: 0 Date: 2021.09.11 Time: 02:08:06 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 4 Reset counter: 60 Mileage: 0 km Time Indication: 0 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 40 Mileage: 158928 km Time Indication: 0 Date: 2022.02.13 Time: 00:00:48 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 D HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0050 Revision: 00H12000 Serial number: 08740821101130 Coding: 0221208 Shop #: WSC 02313 785 00200 VCID: 2411FD66A2D1EFEA4B3-8070 1 Fault Found: 00576 - Terminal 15 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 20 Mileage: 158936 km Time Indication: 0 Date: 2022.02.13 Time: 00:12:09 ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End----(Elapsed Time: 01:44, VBatt start/end: 11.6V/11.6V. VIgn 11.1V)-----
Oh, I misread that at the start. Was thinking 2009 S5, not 2009 S8. That's quite a different beast, the D3.5 era. That probably has a separate J518 module (05 access/start authorization). My bad.
Audi makes decent high level documentation on new generation releases (the "SSP" documents), but nothing for mid cycle updates. But it would be worth googling for "Audi SSP 287" and checking out the layout on pages 4/5.
I don't see any distance regulation or adaptive cruise type control module listed, so the J533 likely has just the four main CAN buses and the MOST ring. A lot of the cannot reach are on the MOST ring. Understand the MOST ring, in that each device on the ring must be powered and working (to an extent). The light is "in the open", but sent "to the next device". It's up to that device to read that light, do whatever it does, and send the light on to the next device. Any unpowered or dead device on the ring, and the whole thing goes down.
But there's plenty others there too. 03-abs. That's on the drive system CAN, no relation to the J393 (46-central convenience). It could be the J104 is unpowered, etc.
But yeah, you'll want to break down the list by communication bus and then work from those groupings. For example, don't bother with 37-navigation (on the MOST ring) until you're ready to tackle everything on the MOST ring together.
https://cardiagn.com/2003-a8-2007-20...iring-diagram/
J329 terminal 15 voltage supply relay is controlled by the J518 (05-auth). This is integrated into the J393 unit starting with the B8 era (MY08 A4/A5). But it's a separate device in the prior era (such as the D3 A8). Luckily, your J518 is responding and just complaining about term 15 (and low battery voltage in the key fob). But I'd start there, trying to get the J518 happy and turning on term 15 to the rest of the vehicle.
