No Sirius Band-only AM/FM on MMI Q5
I am currently only seeing AM/FM on my radio bands. When I can the radio in vagcom 56- I get fault error 00003 - basic coding is off. Unit is installed in a 2010 Q5.
Does anyone know the adaptation codes to reset the Sirius portion of the radio back on? Maybe you could provide me with info on your coding?
See error below:
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335D00A7567684
Coding: 020000020100000001
Shop #: WSC 06335 000 00000
VCID: 1D3BC830047966F02A3
1 Fault Found:
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 2
Mileage: 33919 km
Time Indication: 0
Date: 2012.09.10
Time: 23:34:50
Freeze Frame:
Bin. Bits: 00000000 00001000
See error below:
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Mileage: 33919 km
Time Indication: 0
Date: 2012.09.10
Time: 23:34:50
Freeze Frame:
I appears to that you have a faulty module. Based on the fact that your car is a 2010 with only 34,000km it should still be under warranty. If it were my car I would take it to the dealer and let them fix the problem.
hello, I'm trying to figure out if you can help me.. I have an audi a4 b8 2011.. it's the error 03157.. I've done everything but it's impossible to fix it.. Also, my mmi device often freezes and freezes, so I have to reset it to it works normally.. Do you have a solution it would mean a lot to me??
Do you have the actual complete DTC for whatever 03157 is? You'll also have to specify if you have MMI 3G basic or MMI 3G high, as either could be possible over there. If you look in the version info in the menu system, is it BNav, HNav, or HN+? Or something else? Or maybe you're using MMI loosely, and actually just have Chorus or Concert or Symphony radio unit. MMI = navigation. Radio = without navigation.
One thread of 03157 was someone incorrectly playing with the coding on their Concert head unit.
Sami Heikkinen
11-01-2009 12:49 PM
Casablanca Avant
10-03-2007 06:00 AM
BigTT
10-12-2002 09:21 AM
