Number of blinks
Wonder what happened to the "Number of blinks" thread?
Well, here it is again.
My question was if it is possible to change "lane change" blinker to give 4 blinks instead of 3, which I find kind of not enough. Four blinks would be better for me and perhaps for some other folks.
Uwe from Ross-Tech suggested to make "Adaptation Channel Map" from the "09-Central Electric" module to see if there is number 3 as a stored value in a channel.
Below is the Adaptation Map. I removed channels 26-59 and 85-255 as they were lister with error "channel not available".
;Component:ILM Fahrer H22 0320, Coding:0010123
;Monday,29,March,2010,16:25:48:03959
;VCDS Version: Release 908.1 Data version: 20091018
Channel,,Field 1,Field 2,Field 3,Field 4,
01,140,N/A,N/A,N/A,N/A,
02,18,N/A,N/A,N/A,N/A,
03,24,N/A,N/A,N/A,N/A,
04,8,97.0 %,N/A,N/A,N/A,
05,15,97.0 %,N/A,N/A,N/A,
06,38,97.0 %,N/A,N/A,N/A,
07,66,97.0 %,N/A,N/A,N/A,
08,100,98.0 %,N/A,N/A,N/A,
09,40,41.2 s,N/A,N/A,N/A,
10,5,N/A,N/A,N/A,N/A,
11,20,OFF ,N/A,N/A,N/A,
12,60,N/A,N/A,N/A,N/A,
13,50,N/A,N/A,N/A,N/A,
14,1,N/A,N/A,N/A,N/A,
15,1,Enabled,N/A,N/A,N/A,
16,1,N/A,N/A,N/A,N/A,
17,3,N/A,N/A,N/A,N/A,
18,50,N/A,N/A,N/A,N/A,
19,7,N/A,N/A,N/A,N/A,
20,6,N/A,N/A,N/A,N/A,
21,0,N/A,N/A,N/A,N/A,
22,40,N/A,N/A,N/A,N/A,
23,5,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,30,N/A,N/A,N/A,N/A,
60,65535,Adapt Value,Learned,N/A,N/A,
61,65535,Adapt Value,Learned,N/A,N/A,
62,65535,Adapt Value,Learned,N/A,N/A,
63,65535,Adapt Value,Learned,N/A,N/A,
64,65535,Adapt Value,Learned,N/A,N/A,
65,65535,Adapt Value,Learned,N/A,N/A,
66,65535,Adapt Value,Learned,N/A,N/A,
67,65535,Adapt Value,Learned,N/A,N/A,
68,65535,Adapt Value,Learned,N/A,N/A,
69,65535,Adapt Value,Learned,N/A,N/A,
70,65535,Adapt Value,Learned,N/A,N/A,
71,65535,Adapt Value,Learned,N/A,N/A,
72,65535,Adapt Value,Learned,N/A,N/A,
73,65535,Adapt Value,Learned,N/A,N/A,
74,65535,Adapt Value,Learned,N/A,N/A,
75,65535,Adapt Value,Learned,N/A,N/A,
76,65535,Adapt Value,Learned,N/A,N/A,
77,65535,Adapt Value,Learned,N/A,N/A,
78,65535,Adapt Value,Learned,N/A,N/A,
79,65535,Adapt Value,Learned,N/A,N/A,
80,65535,Adapt Value,Learned,N/A,N/A,
81,65535,Adapt Value,Learned,N/A,N/A,
82,65535,Adapt Value,Learned,N/A,N/A,
83,65535,Adapt Value,Learned,N/A,N/A,
84,65535,Adapt Value,Learned,N/A,N/A,
Interestingly channel 17 has a stored value of 3. This also is the only channel with value 3.
Could this be the number of blinks for the lane change "one touch" blinker operation?
Arrie
Arrie
I haven't seen an documentation for channel 17. I don't think there's much harm in changing it to 2 or 4 to see if that produces the desired results. If it does not, I would change it back to 3. However, you do this at your own risk.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
