'o4toureg Accident aftermath in China... HeEeeElp!
Upon clearing codes (After noting them) and a secondary test drive, I "auto-scanned" it again. Here's what I came up with...
Info: Eng#AXQ01696
VIN#WVGCM77L84D04????*
VAG-COM 4DO 907 560 DA
SHOP 11070
HARDWARE 8E 0907560
Why so many DTC's? New ECU, how do I recode with the VAG?
LAST CURRENT CODES:
18107 - STEERING ANGLE SENS.
17887 - BRAKE BOOST VAC. , MECH. FAILURE (BUT I TEST AND IT'S OPERATING?)
18032 - MIL REQUEST SIGN. ACTIVE (P1624)
(TCM)
AD-02 CODING 0004153
17099 - INPUT SPEED SENS.
17104 - OUTPUT
ADDRESS 05
01315
01220
01229
00165
00230 - THERE HAS TO BE A PR9OBLEM BECAUSE ALL THE PRNDS1 LIGHTS ARE LIT UP.
ADDRESS 06
00466 - CONT. MOD. STEERING ELECT. INTERMIT.
ADDRESS 08 , CODING 000130
01810 - (V159)
01596 - (V154)
01336 DATA BUS COMFORT SYS. NO SIG.
01044 - needs coding (It sez)
How do I code?????HeeEEEeEElp!
Your helping an American in China and I really appreciate it to whoever takes the time. If your in L.A. I'll set ya up with lunch!
Peace.....
Info: Eng#AXQ01696
SHOP 11070
HARDWARE 8E 0907560
LAST CURRENT CODES:
(TCM)
17104 - OUTPUT
ADDRESS 05
01315
01220
01229
00165
ADDRESS 06
01810 - (V159)
01596 - (V154)
Peace.....
I only listed the addresses that faults were found in. The other addresses said "No fault found". What missing information are you talking about? My laptop works about 10 times faster than the 10 year old Seimans unit (W\a 286CPU)at the dealer that the guys (they don't speak English)don't quite know how to use other than pull codes and check components. (It's a small town here) Keep in mind I've only started using the VAG so can you tell me what you need to know?
Battery charged, codes cleared, results....
auto run
VAG-COM Version: Beta 506.0-UD
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 15 16 17 18 19 1C 22 29 34 36 37 39
46 47 56 65 68 69 6E 75 77
VIN Number: WVGCM77L84D046986
Address 01: Engine
Controller: 4D0 907 560 DA
Component: 4.2L V8/5V G 0020
Coding: 0007875
Shop #: WSC 11070
3 Faults Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 008 - Implausible Signal
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
Readiness: 0000 1100
Address 02: Auto Trans
Controller: 09D 927 750 N
Component: AL 600 6Q 0423
Coding: 0004153
Shop #: WSC 31414
2 Faults Found:
17104 - Transmission Output Speed Sensor (G195): Circuit Malfunction
P0720 - 012 - Electrical Fault in Circuit - Intermittent
17099 - Transmission Input Speed Sensor (G182): Circuit Malfunction
P0715 - 012 - Electrical Fault in Circuit
Address 03: ABS Brakes
Controller: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0014593
Shop #: WSC 01002
2 Faults Found:
00778 - Steering Angle Sensor (G85)
000 - - - Intermittent
003 - Mechanical Failure
Address 05: Acc/Start Auth.
Controller: 3D0 909 135 M
Component: Kessy 6400
Coding: 0131304
Shop #: WSC 31414
No fault code found.
Address 06: Seat Mem. Pass
Controller: 7L0 959 760
Component: Sitzverstellung 0701
Coding: 0000000
Shop #: WSC 00000
Address 08: Auto HVAC
Controller: 7L6 907 040 D
Component: CLIMAtronic R/L X 2714
Coding: 0001030
Shop #: WSC 31414
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
01596 - Motor for Outside/Recirculated Air Flap (V154)
000 - -
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect.
Controller: 7L6 937 049 K
Component: 2703
Coding: 0105724
Shop #: WSC 11070
3 Faults Found:
00062 - Suspension Function Request
007 - Short to Ground - Intermittent
00907 - Intervention load Management
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication - Intermittent
Address 15: Airbags
Controller: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Coding: 0012341
Shop #: WSC 01002
3 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded
01587 - Igniter 2 for Airbag; Drivers Side (N250)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
Address 16: Steering wheel
Controller: 7L6 953 549 D
Component: Lenks鼟lenmodul 3301
Coding: 0000001
Shop #: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments
Controller: 7L6 920 980 M
Component: KOMBIINSTRUMENT RB4 2921
Coding: 0007231
Shop #: WSC 31414
2 Faults Found:
01314 - Engine Control Module
01315 - Transmission Control Module
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 31414
3 Faults Found:
00908 - Control Module for Wiper Motor
Address 1C: Position Sensing
Controller: 7L6 919 879
Component: JCI PathPoint 1600
Coding: 0000000
Shop #: WSC 00000
Address 22: AWD
Controller: 0AD 927 755 AB
Component: TRANSFERCASE 0094
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 34: Level Control
Controller: 7L6 907 553 B
Component: LUFTFDR.-CDC- 3C1P1 3650
Coding: 0015520
Shop #: WSC 31414
2 Faults Found:
01398 - Signal Conductor for Central Locking; Doors Open
Address 36: Seat Mem. Drvr
Coding: 0000000
Shop #: WSC 00000
Address 37: Navigation
Controller: 7L6 919 887 D
Component: Navigation 0628
Coding: 0000002
Shop #: WSC 31414
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Address 39: Right Light
Controller: OBD-II/EOBD, Protocol Keyword: $E955
Address 46: Central Conv.
Controller: 7L0 959 933 E
Component: 2M HSG 0201
Coding: 0000085
Shop #: WSC 01002
4 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
00668 - Supply Voltage Terminal 30
Address 47: Sound System
Controller: 7L6 035 466
Component: 12K-AUDIOVERST 0108
Coding: 0000000
Shop #: WSC 00000
Address 56: Radio
Controller: 7L6 035 186 A
Component: Radio 0628
Coding: 0005055
Shop #: WSC 31414
Address 65: Tire Pressure
Controller: 7L0 907 273 H
Component: Reifendruckueberw. 0016
Coding: 0012339
Shop #: WSC 31414
1 Fault Found:
Address 6E: Ctrl Head Roof
Controller: 7L6 919 044 F
Component: DACHDISPLAY 0530
Coding: 0000000
Shop #: WSC 31414
End -------------------------------------------------------------------------
auto run
Address 01: Engine
Coding: 0007875
Shop #: WSC 11070
3 Faults Found:
Coding: 0004153
Shop #: WSC 31414
2 Faults Found:
Coding: 0014593
Shop #: WSC 01002
2 Faults Found:
Coding: 0131304
Shop #: WSC 31414
Coding: 0000000
Shop #: WSC 00000
Coding: 0001030
Shop #: WSC 31414
3 Faults Found:
000 - -
000 - -
Component: 2703
Coding: 0105724
Shop #: WSC 11070
3 Faults Found:
Address 15: Airbags
Coding: 0012341
Shop #: WSC 01002
3 Faults Found:
Coding: 0000001
Shop #: WSC 00000
2 Faults Found:
000 - -
014 - Defective
Coding: 0007231
Shop #: WSC 31414
2 Faults Found:
Coding: 0000006
Shop #: WSC 31414
3 Faults Found:
Coding: 0000000
Shop #: WSC 00000
Address 22: AWD
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
Coding: 0015520
Shop #: WSC 31414
2 Faults Found:
Coding: 0000000
Shop #: WSC 00000
Coding: 0000002
Shop #: WSC 31414
1 Fault Found:
011 - Open Circuit
Coding: 0000085
Shop #: WSC 01002
4 Faults Found:
00926 - Terminal 30
Coding: 0000000
Shop #: WSC 00000
Address 56: Radio
Coding: 0005055
Shop #: WSC 31414
Coding: 0012339
Shop #: WSC 31414
1 Fault Found:
Coding: 0000000
Shop #: WSC 31414
allroadnick
VAG-COM Discussion
02-10-2015 08:10 PM
JMS-Four
Pacific Northwest Discussion
01-02-2007 09:40 AM
footwerk
02-08-2006 01:31 PM
Muhammad
13
08-13-2005 02:02 PM
