Ok let's try this again...
Here is the whole scan:
Thursday,11,June,2009,15:50:53:19849
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUJT68E64A137018 Mileage: 52820km/32820miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0020
Coding: 0016581
Shop #: WSC 63351 000 00000
1 Fault Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal
Readiness: 0000 1000
Address 02: Auto Trans Labels:
Note: Excessive Comm Errors
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04499
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1319
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
Address 15: Airbags Labels:
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00231
Shop #: WSC 22199
WAUJT68E64A137018 AUZ6Z0C0346941
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11788
Shop #: WSC 63351
Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0004
Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0004
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0004
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
Address 56: Radio Labels: None
Part No: 8E0 035 186 E
Component: concert II NP2 0400
Coding: 01005
Shop #: WSC 87552
End ---------------------------------------------------------------------
69 75 76 77
Coding: 0016581
1 Fault Found:
Coding: 04499
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 01013
Shop #: WSC 63351
Coding: 02041
Shop #: WSC 63351
Coding: 00231
Shop #: WSC 22199
Coding: 00002
Shop #: WSC 63351
Coding: 11788
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
Coding: 00060
Shop #: WSC 63351
Coding: 01005
Shop #: WSC 87552
Audiworld Premium Sponsor
Did you notice that you cannot talk with the tranny controller? The scan says - "too many communications errors". Looks like the tranny controller has a problem. Check fuses and connections to start.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Given that you've got communications errors with several modules, you should start here:
http://www.ross-tech.com/vag-com/faq_2.html#2.5
-Uwe-
-Uwe-
http://www.Ross-Tech.com
