P1122? What is going on here, O2 sensor?
Re: P1122? What is going on here, O2 sensor?
As seen in the rarely-read FAQ:
<i>When posting questions related to a problem you are having with a particular car, always state the exact make/model/year/engine of the car you are having a problem with. Also state any modifications you have made to the car. Incomplete information will often get you no answer, or worse yet, the wrong answer.
When posting questions involving trouble codes, post the complete code(s), and the text that comes with them. Do not omit anything, and don't drop any digits, not even a leading zero! Make sure to mention which controller (Engine, ABS, etc.) had the fault code(s). VAG codes are 5 digit numbers, unlike Generic OBD-II P-Codes, which are the letter P followed by four numbers. If you have a diagnostics question relating to VAG-COM or one of the factory tools (VAG-1551, VAS-5052, etc.), feel free to post it here. If you have a diagnostics question relating to an Autozone scan, it should be posted in the AudiWorld Autozone Forum ;-) or in a forum relating to your specific vehicle or engine. Any posts that do not pertain to VAG-COM or VAG diagnostics will be locked or moved by moderators.</i>
stewart5564
01-20-2017 05:40 AM
