P1139 Long Term Fuel Trim 2002 allroad 2.7T
I've been chasing a reoccuring code on our 2002 allroad. The codes it's been throwing are. 11547 Long Term Fuel Trim Too Rich
11545 Long Term Fuel Trim Too Rich (Intermittant)
I looked at the OBD-II Freeze Frame, and here's the result:
Freeze Frame Data for address 10
PID02 DTC that caused freeze frame data storage: P0175
PID03 Fuel system 1/2 status: Closed loop, using O2 sensors
... Closed loop, using O2 sensors
PID04 Calculated load value: 2.7 %
PID05 Engine coolant temperature: 87 °C
PID06 Short Term Trim - Bank 1: 2.3 %
PID07 Long Term Trim - Bank 1: 10.2 %
PID08 Short Term Trim - Bank 2: 2.3 %
PID09 Long Term Trim - Bank 2: 10.2 %
PID12 Engine RPM: 640 /min
PID13 Vehicle speed: 3 km/h
I read the great piece about Fuel Trim, and the long term trim looks like it's just over 10%
I don't have a complete autoscan on this computer. Any chance you can help me identify what the cause is?
Thanks,
Tony<ul><li><a href="https://forums.audiworld.com/vag/msgs/456.phtml">https://forums.audiworld.com/vag/msgs/456.phtml</a</li></ul>
Thanks,
VCDS Version: Release 805.1
Data version: 20081017
Friday,14,November,2008,11:39:12:11761
Chassis Type: 4F - Audi A6 C6
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 13 15 16 17 18 19 1E 20 28
34 36 37 3D 42 46 47 4C 4F 52 53 55 56 57 5F 61 62 65 67 69
6D 72 76 77
VIN: WA1YD64B42N152658
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 4000
Coding: 06752
Shop #: WSC 03109
WA1YD64B42N152658 AUZ7Z0B2142955
2 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 4Z7 927 156 F
Component: AG5 01V 2.7l5VT USA 1818
Coding: 01002
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06497
Shop #: WSC 00000
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0103
Coding: 00003
Shop #: WSC 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 E
Component: Airbag 8.4E 5000
Coding: 0000307
Shop #: WSC 02325 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 00000
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 06264
Shop #: WSC 20108
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00001
Shop #: WSC 00000
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 J
Component: symphony II NP2 0050
Coding: 00205
Shop #: WSC 00000
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 00000
End ---------------------------------------------------------------------
6D 72 76 77
Coding: 06752
Shop #: WSC 03109
2 Faults Found:
P1139 - 35-00 - -
Coding: 01002
Shop #: WSC 00000
Coding: 06497
Shop #: WSC 00000
Coding: 00003
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
Coding: 0000307
Coding: 01012
Shop #: WSC 00000
Coding: 06264
Shop #: WSC 20108
Coding: 25500
Shop #: WSC 09999
Coding: 00001
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 00000
Coding: 00205
Shop #: WSC 00000
Coding: 01186
Shop #: WSC 00000
code reappeared two days later. I'm thinking Fuel Pressure Regulator. I can't find any vacuum leak, and the idle is smooth. I'm stumped.
when was the last time you replaced your plugs and air filter, check for boost leaks (though that should show up...)
1.8tScreemer
08-02-2004 09:59 AM
Marin S4
03-25-2003 12:33 PM
